Seat switch
12-27-2006, 05:10
Seat switch
That switch is from an early 70's Chrysler- we took our own tools, and
removed it and paid the 12 bucks for it. Easy fix.- It will plug in directly
with
what you have now.
83PT40
Weatherford, tx
12-27-2006, 05:48
Seat switch
In a message dated 12/27/2006 3:42:51 P.M. Mountain Standard Time,
tjhannink@... writes:
1970-1981 Cadillac power seat switch 21 peg
TJ- those switches must be pretty much universal.
83PT40
Weatherford, tx
12-27-2006, 09:59
Seat switch
I am on a small roll i have fixed three things in three days thanks to
you guys with all the answers.
One of the buttons on my co-pilot seat control is broken off, I went
to the junk yard today but they didn't know what year or model chysler
product it was off of. I read on this forum where someone bought a
switch at a junk yard for $10.00, if you can tell me here i can get
one or how to indentify it i would appeicate it.
Thanks again for all your help
re brake 1983 FC-35 SB
12-27-2006, 10:37
Seat switch
I purchased a set of these new off eBay last year and they are similar, but not
identical - they use a surface mounted chrome housing and mount on top of the
existing panel instead of behind it. The switches and electrical parts are
identical and you could remove them and install them in your old housing. I
liked the way this housing protected the switches from sideways motion - both of
my originals were broken because the switches were pushed sideways too far.
Search for item number 220064003052, make sure you ask him for a left and a
right side one - they are stamped with a red marking on them.
Good luck,
TJ Hannink
Goldibox - 1987 Vanagon Camper, Wolfsburg Edition
1981 Bluebird Wanderlodge, FC-33SB
Full-timing in Paradis, Louisiana
http://groups.yahoo.com/group/wolfsburg_campers
http://groups.yahoo.com/group/FC_wanderlodge
Do You Yahoo!?
http://mail.yahoo.com
12-27-2006, 12:19
Seat switch
On my then 83 FC 35, I took the old switch with me, then pulled
switches out of multiple Chryslers to find the match. The 76 to 78
year range worked for me.
Dan
94 BB BMC 37'
--- In WanderlodgeForum@yahoogroups.com, "putneyflash"
to
chysler
12-27-2006, 12:34
Seat switch
Got mine out a 1970 Chrysler New Yorker.
Troy Tikalsky
Sent: Wednesday, December 27, 2006 3:59 PM
Subject: [WanderlodgeForum] Seat switch
12-27-2006, 12:34
Seat switch
If you send me a email pic of the back of the switch (where the
electrical connections are), I will see if it matches one of two spares
I have. Not all switches have the same connector scheme. If yours
matches my spare, you can have it for mailing costs. I have a short
harness if you want to just cut off your connector and wire to the
harness I have. The switch will likely not match the outward
appearance of the original. No chrome, just black plastic switches.
Dan
dweaver907 @ Comcast .net
to
chysler
12-27-2006, 12:37
Seat switch
Also found a Dodge dealer in New Jersey that has all the remaining new switches
in inventory. Only wants $250 each! Claims to be selling them to RV
manufacturers.
Troy Tikalsky
Sent: Wednesday, December 27, 2006 4:48 PM
Subject: Re: [WanderlodgeForum] Seat switch
83PT40
Weatherford, tx
12-28-2006, 09:59
Seat switch
If finding a replacement switch fails...and your speaking of the
bigger joystick toggle in the center of the three...I had luck in
purchasing a generic "big toggle switch" from Radio Shack and then
taking the switch carefully apart and filing the R/S toggle to fit. I
posted the job on the Wanderlodge FC site (files) since it was more
specific to the FC coaches.
Also I "switched" the switch units (org. pass side for the drivers
side) as the drivers switch gets by far the most use....if all else
fails, put your pass seat full back and use that good switch for the
drivers side.
Good luck!
Frank
85FC33
Woodbridge, Va.
to
chysler
12-28-2006, 15:24
Seat switch
I will try to get a picture friday. I know it has 21 pins. 3 rows of 7 each
thanks
re brake FC-35 sb
> From: "ac7880"
> Date: 2006/12/27 Wed PM 07:34:37 EST
> Subject: [WanderlodgeForum] Re: Seat switch
> Dan
> to
> chysler
