					Rediline relay noise
					11-17-2006, 09:11
				 Post: #1 | |||
					Greetings All: Anyone have a suggested modification to cure the noisy Rediline relay? Perhaps a replacement latching relay that won't hum? I would like to keep the option of using the Rediline, but the noise is too obnoxious when in an otherwise quiet environment. Thanks-- M.R.Kane '85 PT40 | |||
					11-17-2006, 13:54
				 Post: #2 | |||
					M, I do not have a Rediline to compare but I do know this. Many times a coil will hum because the laminations of the metal becomes loose. I have seen this come up before on a forum posting but that is the extent of my recall. You might try insulating the base of the coil from the enclosure with some stand-off insulators to reduce the resonance. Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Greetings All: > > Anyone have a suggested modification to cure the noisy Rediline relay? > Perhaps a replacement latching relay that won't hum? I would like to > keep the option of using the Rediline, but the noise is too obnoxious > when in an otherwise quiet environment. > > Thanks-- > M.R.Kane > '85 PT40 > | |||
					11-17-2006, 14:36
				 Post: #3 | |||
					M.R., Replace the relay and the noise will be gone. If ya want, I'll see if I still have one around here. I put it in and then shortly after, installed a Xantrex 2,500 watt inverter/charger. So, the rlay comes out permanently with the inverter update. Where r u from? Does your dash a/c work? Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Greetings All: > > Anyone have a suggested modification to cure the noisy Rediline relay? > Perhaps a replacement latching relay that won't hum? I would like to > keep the option of using the Rediline, but the noise is too obnoxious > when in an otherwise quiet environment. > > Thanks-- > M.R.Kane > '85 PT40 > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
