Front running light mod
11-15-2006, 05:20
Hello everyone:
Some time back there was a thread on someone making or having made a stainless cover for the front running lights that is located between the headlights on the 90's Coaches. I searched but did locate the thread. Where was it made? are they available? Any help is appreciated. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma |
11-15-2006, 06:41
Hi Ralph,
These guys can definitely make it. They may even have something is stock: http://www.summit-products.com/contact.htm David Brady '02 LXi, Smokey Va no more Ralph L. Fullenwider wrote: > Hello everyone: > > Some time back there was a thread on someone making or having made a > stainless cover for the front running lights that is located between the > headlights on the 90's Coaches. > > I searched but did locate the thread. Where was it made? are they > available? Any help is appreciated. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > |
11-15-2006, 07:44
Ralph,
Greg O'Connor made a SS cover that goes between the head lights on his '94. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Ralph L. Fullenwider wrote: >Hello everyone: > >Some time back there was a thread on someone making or having made a >stainless cover for the front running lights that is located between the >headlights on the 90's Coaches. > >I searched but did locate the thread. Where was it made? are they >available? Any help is appreciated. > >Safe travels, > >Ralph and Charolette Fullenwider >Ralph's RV Solutions, Duncan, Oklahoma > > > > |
11-15-2006, 08:05
Ralph:
I fabricated flat stainless for my coach including a plate that surrounds the headlight and turn signal. I used 20 guage #8 polished stainless. Got the metal from Phoenix Metals. Leroy Eckert 1990 WB-40 Smoke N Mirrors Niceville, FL ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, November 15, 2006 11:20 AM Subject: [WanderlodgeForum] Front running light mod Hello everyone: Some time back there was a thread on someone making or having made a stainless cover for the front running lights that is located between the headlights on the 90's Coaches. I searched but did locate the thread. Where was it made? are they available? Any help is appreciated. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma [Non-text portions of this message have been removed] |
11-15-2006, 09:10
Thanks to all for the info, very much appreciated. With your help, I have
found the solution. Ralph At 01:41 PM 11/15/2006 -0500, you wrote: >Hi Ralph, > >These guys can definitely make it. They may even have >something is stock: > >http://www.summit-products.com/contact.htm > >David Brady >'02 LXi, Smokey >Va no more > >Ralph L. Fullenwider wrote: > > Hello everyone: > > > > Some time back there was a thread on someone making or having made a > > stainless cover for the front running lights that is located between the > > headlights on the 90's Coaches. > > > > I searched but did locate the thread. Where was it made? are they > > available? Any help is appreciated. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > >Yahoo! Groups Links > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma |
11-15-2006, 17:18
Ralph, I made several out of rem stock I think 6 units cost less than
20.00 to make. Its easy if you have access to a brake. from headlight to headlight there is a slight radius that can be duplicated by leaving both fold tabs with material to trim ( aprox 2 inches)drag a plasma torch quick for the first 4-5 and last 4-5 inches but lift the torch during the center cut to heat the dross and distort the SS with a radius. If you want it closer to chrome use "everbright" SS I went with the DeLorean look using brushed SS. I made one of each for a guy we are meeting up with in Quartsite. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Thanks to all for the info, very much appreciated. With your help, I have > found the solution. > > Ralph > > > At 01:41 PM 11/15/2006 -0500, you wrote: > >Hi Ralph, > > > >These guys can definitely make it. They may even have > >something is stock: > > > >http://www.summit-products.com/contact.htm > > > >David Brady > >'02 LXi, Smokey > >Va no more > > > >Ralph L. Fullenwider wrote: > > > Hello everyone: > > > > > > Some time back there was a thread on someone making or having made a > > > stainless cover for the front running lights that is located between the > > > headlights on the 90's Coaches. > > > > > > I searched but did locate the thread. Where was it made? are they > > > available? Any help is appreciated. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > |
