Facet Pump
11-13-2006, 07:14
Facet Pump
Got a question on the facet pump??? Where is it located on a 89 SP 36' ???
I've owned this coach for three years been all over it underneath & haven't
been able to find it. First off should it have one or did they build them with
out a facet pump? Maybe I am looking for something that is not there. Also I
have never been able to locate the front & back places to bleed the air when
refilling the coolant after draining the system. The book tells where they
are but I can't find them.
Don
89 SP 36'
Butler, PA
11-13-2006, 21:54
Facet Pump
the pumps are available from Mark Dexter 5742934328. he sold them to BB.
I just got a pump from him. Also Vehicle Systems (who sells webasto
replacements) has pumps for Primus. SE Hallum, a long time engineer with BB
told
me to stick with PRIMUS. He said " if it is working there is no better heat
for an RV" If its not working its a PITA, as are all heat systems that do not
work.
Also Steve Birtles with this forum is a great source for PRIMUS parts and
other electrical repairs. His post name is capeinnovations
john redden
91 PT40
11-14-2006, 01:15
Facet Pump
I assume you are talking about the pumps in the Primus System. They
are located below the boilers. Very difficult to get to, but they are
there. The engine pre-heat pump is located on the curb side attached
to a diagonal brace down to the transmission.
36' ???
haven't
build them with
there. Also I
air when
where they
> Don
> 89 SP 36'
> Butler, PA
11-14-2006, 07:38
Facet Pump
Thanks Ron I was talking about the Facet pump that pumps the fuel to the
engine from the fuel tank up front.
Don
89 SP 36'
Butler, PA
--- In _WanderlodgeForum@WanderlodgeFWan_
(mailto:WanderlodgeForum@yahoogroups.com) , dspithaler@., dsp
36' ???
haven't
build them with
there. Also I
