					Identifying If Swing Radiator is already Installed
					08-30-2006, 20:46
					Henry, the hinges are a start in your search if you have a swing radiator.
			Take off the front panels, swing the bumper down and look on the side of your radiator. If you see any modification that looks like a hinge you will be in luck. The radiator is still bolted in place, though. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed]  |
					08-31-2006, 00:36
					(1)  If I have two hinges on the bottom of my front bumper, is this an
			indication that my bus may have the swing radiator installed? (2) What would be the next item to search for to confirm whether my bus has the swing radiator? I tried looking up, from below, for hinges attached to the radiator but I could see none. (3) Must I remove the front panels of the bus to see if I have a swing radiator? Thanks. Henry F. Claeys, 1979 FC 35, Austin, Tx. henry@...  |
					08-31-2006, 02:22
					Look through the grill louvers for a hinge on the left
			side (facing rear)of the radiator. Open the doghouse, see if top hose makes a large "U" instead of a tight one. Souuds to me like your swinging, at least part-way with the drop-down bumper. Also, see if the frame horn spreader allows the radiator to clear without removing. Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Henry, the hinges are a start in your search if you have a swing radiator. > Take off the front panels, swing the bumper down and look on the side of your > radiator. If you see any modification that looks like a hinge you will be in > luck. The radiator is still bolted in place, though. > > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] >  |
					08-31-2006, 08:01
					Thanks for your help Bob.   I guess my question should have been whether
			it's possible, with a quick visual inspection, to determine if the swing radiator is installed ? From what I'm gathering, the answer is "no." I'll follow the procedures that you and others have outlined. henry@... Austin, Tx, 1979 FC 35. one_dusty_hoot wrote: > Look through the grill louvers for a hinge on the left > side (facing rear)of the radiator. Open the doghouse, > see if top hose makes a large "U" instead of a tight one. > Souuds to me like your swinging, at least part-way with > the drop-down bumper. Also, see if the frame horn spreader > allows the radiator to clear without removing. > Bob Janes, Greenville, SC > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > >> Henry, the hinges are a start in your search if you have a swing >> > radiator. > >> Take off the front panels, swing the bumper down and look on the >> > side of your > >> radiator. If you see any modification that looks like a hinge you >> > will be in > >> luck. The radiator is still bolted in place, though. >> >> Ernie Ekberg >> 83 PT40 >> Livingston, Montana >> >> >> >> [Non-text portions of this message have been removed] >> >> > > > > > > > > > Yahoo! Groups Links > > > > > > > >  |
					08-31-2006, 11:58
					Hi Henry,
			When Holland Motor Homes installed aftermarket swing radiators, I believe they would often place a small wooden shoe window sticker on the copilot (perhaps drivers) side window that said "dutch door" on it. This would be the fastest way to identify it. Otherwise, get on your back and look for longer transmission cooling lines being held up by a bracket located directly under the copilot seat, or a longer coolant hose attached to the bottom of the radiator, or the longer topside coolant hose, all of which allow for swinging the radiator. If you're still unsure, remove the front panels and look for the large piano hinge on the curb side of the radiator. Gary Miller 83 FC 33 Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "Henry F. Claeys" wrote: > > Thanks for your help Bob. I guess my question should have been whether > it's possible, with a quick visual inspection, to determine if the swing > radiator is installed ? From what I'm gathering, the answer is "no." > I'll follow the procedures that you and others have outlined. > henry@... Austin, Tx, 1979 FC 35. > > one_dusty_hoot wrote: > > Look through the grill louvers for a hinge on the left > > side (facing rear)of the radiator. Open the doghouse, > > see if top hose makes a large "U" instead of a tight one. > > Souuds to me like your swinging, at least part-way with > > the drop-down bumper. Also, see if the frame horn spreader > > allows the radiator to clear without removing. > > Bob Janes, Greenville, SC > > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > >> Henry, the hinges are a start in your search if you have a swing > >> > > radiator. > > > >> Take off the front panels, swing the bumper down and look on the > >> > > side of your > > > >> radiator. If you see any modification that looks like a hinge you > >> > > will be in > > > >> luck. The radiator is still bolted in place, though. > >> > >> Ernie Ekberg > >> 83 PT40 > >> Livingston, Montana > >> > >> > >> > >> [Non-text portions of this message have been removed] > >> > >> > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > >  |
					08-31-2006, 20:01
					Thanks Gary.  There's no wooden shoe emblem on my bus, but I'll look for
			the items that you mentioned. henry@..., Austin, Tx 1979 FC 35. Gary Miller wrote: > Hi Henry, > > When Holland Motor Homes installed aftermarket swing radiators, I > believe they would often place a small wooden shoe window sticker on > the copilot (perhaps drivers) side window that said "dutch door" on > it. This would be the fastest way to identify it. > > Otherwise, get on your back and look for longer transmission cooling > lines being held up by a bracket located directly under the copilot > seat, or a longer coolant hose attached to the bottom of the > radiator, or the longer topside coolant hose, all of which allow for > swinging the radiator. > > If you're still unsure, remove the front panels and look for the > large piano hinge on the curb side of the radiator. > > Gary Miller > 83 FC 33 > Milwaukee area > > --- In WanderlodgeForum@yahoogroups.com, "Henry F. Claeys" > wrote: > >> Thanks for your help Bob. I guess my question should have been >> > whether > >> it's possible, with a quick visual inspection, to determine if the >> > swing > >> radiator is installed ? From what I'm gathering, the answer >> > is "no." > >> I'll follow the procedures that you and others have outlined. >> henry@... Austin, Tx, 1979 FC 35. >> >> one_dusty_hoot wrote: >> >>> Look through the grill louvers for a hinge on the left >>> side (facing rear)of the radiator. Open the doghouse, >>> see if top hose makes a large "U" instead of a tight one. >>> Souuds to me like your swinging, at least part-way with >>> the drop-down bumper. Also, see if the frame horn spreader >>> allows the radiator to clear without removing. >>> Bob Janes, Greenville, SC >>> >>> --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: >>> >>> >>>> Henry, the hinges are a start in your search if you have a >>>> > swing > >>>> >>>> >>> radiator. >>> >>> >>>> Take off the front panels, swing the bumper down and look on >>>> > the > >>>> >>>> >>> side of your >>> >>> >>>> radiator. If you see any modification that looks like a hinge >>>> > you > >>>> >>>> >>> will be in >>> >>> >>>> luck. The radiator is still bolted in place, though. >>>> >>>> Ernie Ekberg >>>> 83 PT40 >>>> Livingston, Montana >>>> >>>> >>>> >>>> [Non-text portions of this message have been removed] >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> Yahoo! Groups Links >>> >>> >>> >>> >>> >>> >>> >>> >>> > > > > > > > > > Yahoo! Groups Links > > > > > > >  |
