Radio Antennas
08-08-2006, 05:17
Radio Antennas
Hi Again,
I need to replace the two AM-FM radio antennas and the two CB antennas
on the coach. They are all NMO style mounts. I have searched the web
and they are hard to find. Anyone know where they can be found? I have
searched CB shops, truck shops, NAPA, Radio Shack, etc. Has anyone
used another type of mount instead of the NMO style? If so, how did you
retrofit?
Thanks,
Randy Merrill
93 WLWB
Ocala, FL
08-08-2006, 09:25
Radio Antennas
I used a trunk mount attached to an alum. angle which I attached to the front of
the "goat rail". That was on a cel antenna but the principle would be the same
on others. I think that the trunk mount might be a NMO style only with the
addition of the trunk mounting piece underneath and held in place with 2 screws
from under the underside. Maybe not. But, you could drill the alum. angle and
put the NMO mount through that.
Sent: Tuesday, August 08, 2006 10:17 AM
Subject: [WanderlodgeForum] Radio Antennas
Hi Again,
retrofit?
Thanks,
Randy Merrill
93 WLWB
Ocala, FL
08-08-2006, 12:30
Radio Antennas
Randy:
Give these people a call. Their antennas all have the loading coil
at the base of the antenna and the stainless steel rod is very
flexible and take kindly to being laid back with a tree limb.
I have used their amateur radio antennas for years and have never had
one fail.
I am sure they can help you with both the AM/FM and CB antennas.
Marv
2004 M380
Ocean Shores, WA
--- In WanderlodgeForum@yahoogroups.com, "Randy Merrill"
> Hi Again,
antennas
web
have
you
> retrofit?
> Thanks,
> Randy Merrill
> 93 WLWB
> Ocala, FL
08-08-2006, 12:37
Radio Antennas
Marv was there a link that I missed??
On 08/08/06, Marv & Jean wrote:
> Randy:
> one fail.
> Marv
> 2004 M380
> Ocean Shores, WA
> "Randy Merrill"
> > Hi Again,
> antennas
> web
> have
> you
> > retrofit?
> > Thanks,
> > Randy Merrill
> > 93 WLWB
> > Ocala, FL
Rob, Sue & Merlin Robinson
94 WLWB
08-08-2006, 15:18
Radio Antennas
My local CB shop set me up when I needed some, he told me that the
mount is common with "business-band" radios.
The CB Shop, in Holland, MI, located in the Tulip City Truck Stop lot
FYI.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "Marv & Jean"
> Randy:
had
> one fail.
> Marv
> 2004 M380
> Ocean Shores, WA
> > Hi Again,
> antennas
> web
> have
anyone
did
> you
> > retrofit?
> > Thanks,
> > Randy Merrill
> > 93 WLWB
> > Ocala, FL
08-08-2006, 15:53
Radio Antennas
Jeff after next summers OSKOSH gathering is there a chance I stop by your
shop?
> FYI.
> - Jeff Miller
> in Holland, MI
> "Marv & Jean"
> > Randy:
> had
> > one fail.
> > Marv
> > 2004 M380
> > Ocean Shores, WA
> "Randy Merrill"
> > wrote:
> > > Hi Again,
> > antennas
> > web
> > have
> anyone
> did
> > you
> > > retrofit?
> > > Thanks,
> > > Randy Merrill
> > > 93 WLWB
> > > Ocala, FL
94 WLWB
08-09-2006, 02:26
Radio Antennas
Randy:
There should have been a link but I omitted it.
http://www.radialllarsen.com
That should do the trick. Sorry but I must have had a "senior moment"
Marv
2004 M380
Ocean Shores, WA
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
> > Randy:
had
> > one fail.
> > Marv
> > 2004 M380
> > Ocean Shores, WA
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Randy Merrill"
> > wrote:
> > > Hi Again,
> > antennas
> > web
I
> > have
anyone
did
> > you
> > > retrofit?
> > > Thanks,
> > > Randy Merrill
> > > 93 WLWB
> > > Ocala, FL
> 94 WLWB
