"Low air pressure" dash light - where's the sender? 78 FC33
06-20-2006, 15:44
Hi all,
My "low air pressure" light does not work. Bulb is okay. Does anyone know the location of the pressure switch/sender that drives this light? Thanks, Danny FC33, 1978 San Jose, CA |
06-21-2006, 08:53
Hey,'
Mine is right in front of the door under the bus inside frame woody at ft bragg nc with 81-35' fc RB just back from the beach- -- In WanderlodgeForum@yahoogroups.com, "Dan" > > Hi all, > > My "low air pressure" light does not work. Bulb is okay. Does anyone > know the location of the pressure switch/sender that drives this light? > > Thanks, > > Danny > FC33, 1978 > San Jose, CA > |
06-21-2006, 09:15
Mine is on the same 4-way junction fitting that the Schrader valve is
on - the one that the tow truck driver hooks into when he needs to release the brakes. Its located behind the front wet tank, just inboard of the propane tank. Good luck, Tim Hannink Winter Park, FL 1981 FC-33SB --- In WanderlodgeForum@yahoogroups.com, "Dan" > > Hi all, > > My "low air pressure" light does not work. Bulb is okay. Does anyone > know the location of the pressure switch/sender that drives this light? > > Thanks, > > Danny > FC33, 1978 > San Jose, CA > |
