Koni Adjustable Shock Won't Adjust...'84 FC
06-19-2006, 08:57
David- you got a good coach. The Konis have a warranty with them.
Ernie Ekberg 83PT40 Livingston, Montana [Non-text portions of this message have been removed] |
06-19-2006, 08:58
David I went through the same thing on my shocks last summer The one
would adjust & the other one acted the same as you described it . I couldn't get it to adjust. Three did & one didn't. I ended up buying two new ones. Don 89 SP 36' Butler,PA In a message dated 6/19/2006 8:33:06 P.M. Eastern Daylight Time, dthollis@... writes: Went to adjust the 3 year old Konis on the FC today. The right one was set in the loosest position, and I adjusted it to about 3/4 firm. Took the left one off to adjust, and when pushing the shock down to engage the adjuster, it just spins. I can feel a slight detent, but pushing as hard as I can and even tapping with a mallet, it won't engage. Any other secrets to these shocks? Thanks. David Hollis 84 FC33(owned by Jeff and Ernie previously) Springfield,Sp [Non-text portions of this message have been removed] |
06-19-2006, 12:31
was set in the loosest position, and I adjusted it to about 3/4 firm. Took the left one off to adjust, and when pushing the shock down to engage the adjuster, it just spins. I can feel a slight detent, but pushing as hard as I can and even tapping with a mallet, it won't engage. Any other secrets to these shocks? Thanks. David Hollis 84 FC33(owned by Jeff and Ernie previously) Springfield,IL |
06-19-2006, 14:29
David,
You might want to check the compressed height of the shock and compare that to the length between the chassis shock mounts when the chassis air is dumped. The Koni adjusting nut may have been damaged due to the shock bottoming before the suspension bottoms. If so, you may be able to pick up a few tenths of additional shock travel by lining up the Koni adjustment nut with the foot valve assembly after they are installed on the chassis. Note, this only works when at least one end of the shock is a stud mount. David Brady '02 LXi, Smokey Va dthollis1961 wrote: > > Went to adjust the 3 year old Konis on the FC today. The right one > was set in the loosest position, and I adjusted it to about 3/4 firm. > Took the left one off to adjust, and when pushing the shock down to > engage the adjuster, it just spins. I can feel a slight detent, but > pushing as hard as I can and even tapping with a mallet, it won't > engage. Any other secrets to these shocks? Thanks. > > David Hollis 84 FC33(owned by Jeff and Ernie previously) > Springfield,I > |
06-19-2006, 14:40
David,
Can't do that as both ends have holes to mount on studs on the chassis. I might add that these shocks are stamped "Koni-Holland" and have the Blue Bird logo on them, so I'm supposing that they are the correct shock for the application. David Hollis 84 FC35 (Not 33 as in original post) Springfield,IL --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > David, > > You might want to check the compressed height of the > shock and compare that to the length between the chassis > shock mounts when the chassis air is dumped. The Koni > adjusting nut may have been damaged due to the shock > bottoming before the suspension bottoms. If so, you may > be able to pick up a few tenths of additional shock > travel by lining up the Koni adjustment nut with the foot > valve assembly after they are installed on the chassis. > Note, this only works when at least one end of the > shock is a stud mount. > > David Brady > '02 LXi, Smokey > Va > > > > |
06-20-2006, 02:31
When both ends are mounted on studs, you can still align
the adjustment mechanism, it's just that your choices of adjustment become more limited. You would need to adjust them in half turn increments, and when they are finally set, the adjustment cogs may need to be rotated slightly to line up with your mounting studs. IOWs, start by rotating the adjustment nut so that the two mounting holes are parallel. From this point you can adjust in 180 deg, half turn, increments and you will then be able to mount to the chassis and the adjustment nut will align with the foot valve assembly. Also, the stiffer you make the shock, the shorter the compressed length becomes. So to really give yourself extra clearance, make them full stiff and have the adjustment nut align with the foot valve assembly. I don't know why the shocks are too long, but it could be that over the years the tolerances in part specs were pushed to the limits. Monroe's became Koni's, firestone airbags became goodyear, etc, etc. Each change, while within spec, ate up a little tolerance and subsequently clearance. Of course, this all assumes that indeed your shock is bottoming before your suspension. I would measure that. Best regards, David Brady dthollis1961 wrote: > > David, > > Can't do that as both ends have holes to mount on studs on the > chassis. I might add that these shocks are stamped "Koni-Holland" > and have the Blue Bird logo on them, so I'm supposing that they are > the correct shock for the application. > > David Hollis 84 FC35 (Not 33 as in original post) Springfield,IL > |
