					New Questions: jack springs,upholstery,microwave,fridge
					04-27-2006, 12:24
					Our new to us  Fc does not have the original Sharp conevction/micro.
			It has been replaced with a conventional micro. Is there a currently mfd. easily obtainable micro/convection that will fit in that space? The left rear jack has one spring that is disconnected at the bottom. We tried quickly to reconnect but this seems like an impossible task and did not have a lot of time. Does the jack have to be removed to replace the spring? Is there a "trick" method? I notice that one of the jacks had heavy s hooks at the bottom to connect the springs. At one time the original owner removed the booth dinette and installed a bed. This has been removed and the booth reinstalled. They did a nice job but on the outer wall under the table the white pleated upholstery(same as headliner) has been removed and the outer steel wall is visible. Can this material still be obtained? The fridge is still the original. The unit has very low miles (64,000) and hasnt been used much. Although the 3801 Dometic still works my own experience is that it probably will not last long. Am I right in that belief or would you just use it till it goes (usually when you are in the hills 2000 miles from nowhere)? Thanks Bruce 1988 FC 300 HP Turbo Cat!!  |
					04-27-2006, 13:56
					We decided that the original frig would probably quit, when we were
			using it. ( when else would it quit ? ) Things always cost more and are more inconvenient on the road. Replaced it last Fall with a Dometic, RM 2820. It is a really snug fit, we did not want to loose the cabinet at the top or the drawer at the bottom, So we installed it ourselves. Some installers have changed these two storage areas to make things fit. IF you decide to replace the frig. we can give a few suggestion. If you are on your way from Ohio to park the Bird in Mexico, while living in Canada, I strongly suggest that you stop and have Jeff Miller check out the coach and determine, the priority list for fixing things up. http://millercoachworks.com/ He is in Western Michigan on your way to Chicago. Just west of Ohio. We really like our 88 FC, Bill --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Our new to us Fc does not have the original Sharp conevction/micro. > It has been replaced with a conventional micro. Is there a currently > mfd. easily obtainable micro/convection that will fit in that space? > > The left rear jack has one spring that is disconnected at the > bottom. We tried quickly to reconnect but this seems like an > impossible task and did not have a lot of time. Does the jack have > to be removed to replace the spring? Is there a "trick" method? I > notice that one of the jacks had heavy s hooks at the bottom to > connect the springs. > > At one time the original owner removed the booth dinette and > installed a bed. This has been removed and the booth reinstalled. > They did a nice job but on the outer wall under the table the white > pleated upholstery(same as headliner) has been removed and the outer > steel wall is visible. Can this material still be obtained? > > The fridge is still the original. The unit has very low miles > (64,000) and hasnt been used much. Although the 3801 Dometic still > works my own experience is that it probably will not last long. Am I > right in that belief or would you just use it till it goes (usually > when you are in the hills 2000 miles from nowhere)? > > Thanks Bruce 1988 FC 300 HP Turbo Cat!! >  |
					04-27-2006, 13:59
					Congratulations Bruce,
			We decided that the original frig would probably quit, when we were using it. ( when else would it quit ? ) Things always cost more and are more inconvenient on the road. Replaced it last Fall with a Dometic, RM 2820. It is a really snug fit, we did not want to loose the cabinet at the top or the drawer at the bottom, So we installed it ourselves. Some installers have changed these two storage areas to make things fit. IF you decide to replace the frig. we can give a few suggestion. If you are on your way from Ohio to park the Bird in Mexico, while living in Canada, I strongly suggest that you stop and have Jeff Miller check out the coach and determine, the priority list for fixing things up. http://millercoachworks.com/ He is in Western Michigan on your way to Chicago. He may be on your route West of Ohio. We really like our 88 FC, Bill --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Our new to us Fc does not have the original Sharp conevction/micro. > It has been replaced with a conventional micro. Is there a currently > mfd. easily obtainable micro/convection that will fit in that space? > > The left rear jack has one spring that is disconnected at the > bottom. We tried quickly to reconnect but this seems like an > impossible task and did not have a lot of time. Does the jack have > to be removed to replace the spring? Is there a "trick" method? I > notice that one of the jacks had heavy s hooks at the bottom to > connect the springs. > > At one time the original owner removed the booth dinette and > installed a bed. This has been removed and the booth reinstalled. > They did a nice job but on the outer wall under the table the white > pleated upholstery(same as headliner) has been removed and the outer > steel wall is visible. Can this material still be obtained? > > The fridge is still the original. The unit has very low miles > (64,000) and hasnt been used much. Although the 3801 Dometic still > works my own experience is that it probably will not last long. Am I > right in that belief or would you just use it till it goes (usually > when you are in the hills 2000 miles from nowhere)? > > Thanks Bruce 1988 FC 300 HP Turbo Cat!! >  |
					04-27-2006, 14:23
					Microwave: I'm told that there is still a Sharp manufactured, one
			sold by Sears, Elmer should have the model number on that one. The jack springs: On our '88, I found it easiest to put the bottom of the spring on first, then the top with a prybar. there shouldn't be any s-hooks. That is the wide-rib wall/ceiling materal, it was available a couple of years ago from BB, not sure if it still is. Good luck. 3801 Refrig: I have at least one set of all of the electtronics, burner, etc. for that unit (donated by Bill and I don't remember who else). If you need any of it, I'd love to see it find a good home. I threw away the last pile of used Dometic electronics, ... I'm told the 3801 is an expensive board so I've resisted tossing it so far. I will be surprised if the original refrigerator will stay more than 25degrees above outside temp. It will probably freeze well, but the refrigerator section will be weak, so on an 85degree day, ... the math is ugly for your lunch meat. You won't find out until it is warm out, the refrigerator is loaded with your favorite foods, and you're on a trip. Replace the refrigerator, or at least the cooling unit if you have a particular love for that unit. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Our new to us Fc does not have the original Sharp conevction/micro. > It has been replaced with a conventional micro. Is there a currently > mfd. easily obtainable micro/convection that will fit in that space? > > The left rear jack has one spring that is disconnected at the > bottom. We tried quickly to reconnect but this seems like an > impossible task and did not have a lot of time. Does the jack have > to be removed to replace the spring? Is there a "trick" method? I > notice that one of the jacks had heavy s hooks at the bottom to > connect the springs. > > At one time the original owner removed the booth dinette and > installed a bed. This has been removed and the booth reinstalled. > They did a nice job but on the outer wall under the table the white > pleated upholstery(same as headliner) has been removed and the outer > steel wall is visible. Can this material still be obtained? > > The fridge is still the original. The unit has very low miles > (64,000) and hasnt been used much. Although the 3801 Dometic still > works my own experience is that it probably will not last long. Am I > right in that belief or would you just use it till it goes (usually > when you are in the hills 2000 miles from nowhere)? > > Thanks Bruce 1988 FC 300 HP Turbo Cat!! >  |
					04-27-2006, 15:27
					The wall roof panelling is still availbale from Bluebird but you be
			shocked at the price is around 250.00 a sheet nuless there has been a recent pricwe dorp but i dont think so Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Our new to us Fc does not have the original Sharp conevction/micro. > It has been replaced with a conventional micro. Is there a currently > mfd. easily obtainable micro/convection that will fit in that space? > > The left rear jack has one spring that is disconnected at the > bottom. We tried quickly to reconnect but this seems like an > impossible task and did not have a lot of time. Does the jack have > to be removed to replace the spring? Is there a "trick" method? I > notice that one of the jacks had heavy s hooks at the bottom to > connect the springs. > > At one time the original owner removed the booth dinette and > installed a bed. This has been removed and the booth reinstalled. > They did a nice job but on the outer wall under the table the white > pleated upholstery(same as headliner) has been removed and the outer > steel wall is visible. Can this material still be obtained? > > The fridge is still the original. The unit has very low miles > (64,000) and hasnt been used much. Although the 3801 Dometic still > works my own experience is that it probably will not last long. Am I > right in that belief or would you just use it till it goes (usually > when you are in the hills 2000 miles from nowhere)? > > Thanks Bruce 1988 FC 300 HP Turbo Cat!! >  |
					04-27-2006, 15:40
					Bruce if you were keeping your bird in Canada or US I would say keep the
			refrigerator until goes. You can keep things pretty cool with a block or two of ice in the old box. However I wouldn't want to be somewhere remote where I wouldn't be able to get a new unit within a week or so. Congratulations on your Bird Rob, Sue & Merlin 94 WLWB Quoting birdshill123 > > > > Our new to us Fc does not have the original Sharp conevction/micro. > > It has been replaced with a conventional micro. Is there a currently > > mfd. easily obtainable micro/convection that will fit in that space? > > > > The left rear jack has one spring that is disconnected at the > > bottom. We tried quickly to reconnect but this seems like an > > impossible task and did not have a lot of time. Does the jack have > > to be removed to replace the spring? Is there a "trick" method? I > > notice that one of the jacks had heavy s hooks at the bottom to > > connect the springs. > > > > At one time the original owner removed the booth dinette and > > installed a bed. This has been removed and the booth reinstalled. > > They did a nice job but on the outer wall under the table the white > > pleated upholstery(same as headliner) has been removed and the outer > > steel wall is visible. Can this material still be obtained? > > > > The fridge is still the original. The unit has very low miles > > (64,000) and hasnt been used much. Although the 3801 Dometic still > > works my own experience is that it probably will not last long. Am I > > right in that belief or would you just use it till it goes (usually > > when you are in the hills 2000 miles from nowhere)? > > > > Thanks Bruce 1988 FC 300 HP Turbo Cat!! > > > > > > > > > > > > > > > > > SPONSORED LINKS > > > > > Recreational vehicles > > > Wanderlodge > > > Automotive maintenance > > > > > Recreational vehicle dealer > > > Used recreational vehicles > > > Automotive radiators > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > >  |
					04-27-2006, 22:42
					Bruce
			You may be able to stretch or pry the spring and add flat wooden spacers in between the spring coils, After a few spacers the spring may be longer. I have never attemped this task. Where in Ohio? We are just North of Toledo Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Our new to us Fc does not have the original Sharp conevction/micro. > It has been replaced with a conventional micro. Is there a currently > mfd. easily obtainable micro/convection that will fit in that space? > > The left rear jack has one spring that is disconnected at the > bottom. We tried quickly to reconnect but this seems like an > impossible task and did not have a lot of time. Does the jack have > to be removed to replace the spring? Is there a "trick" method? I > notice that one of the jacks had heavy s hooks at the bottom to > connect the springs. > > At one time the original owner removed the booth dinette and > installed a bed. This has been removed and the booth reinstalled. > They did a nice job but on the outer wall under the table the white > pleated upholstery(same as headliner) has been removed and the outer > steel wall is visible. Can this material still be obtained? > > The fridge is still the original. The unit has very low miles > (64,000) and hasnt been used much. Although the 3801 Dometic still > works my own experience is that it probably will not last long. Am I > right in that belief or would you just use it till it goes (usually > when you are in the hills 2000 miles from nowhere)? > > Thanks Bruce 1988 FC 300 HP Turbo Cat!! >  |
					04-27-2006, 23:04
					Hello Bruce,
			This worked for me: Place the spring on a sturdy work bench and extend it with a come-a-long. Cut a number of small wooden blocks and place these in the open spaces of the extended spring and then let the pressure off the spring. It will collapse to an extended length. Reinstall the spring on the jack. When you then extend the jack all the way down the blocks are easily removed. This procedure takes some practice but did work. Be sure the spring is installed as to counter the sideways force of it's partner spring or the jack will be twisted. Good luck, Jack '89 "FC 35 "Traveller" Franklin, NC [Non-text portions of this message have been removed]  |
					04-27-2006, 23:38
					Bill: Bird is in Columbus area.
			Bruce  |
					04-28-2006, 03:22
					Bruce,
			I suggest that you contact HWH and follow their advice on the proper method. They are great with the help. George Lowry '06 Alpine Apex = Formerly '95 WBDA 4203 Spearfish, SD - now in Stockton, CA -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Jack Bentley Sent: Friday, April 28, 2006 4:04 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: New Questions: jack springs,upholstery,microwave,fridge Hello Bruce, This worked for me: Place the spring on a sturdy work bench and extend it with a come-a-long. Cut a number of small wooden blocks and place these in the open spaces of the extended spring and then let the pressure off the spring. It will collapse to an extended length. Reinstall the spring on the jack. When you then extend the jack all the way down the blocks are easily removed. This procedure takes some practice but did work. Be sure the spring is installed as to counter the sideways force of it's partner spring or the jack will be twisted. Good luck, Jack '89 "FC 35 "Traveller" Franklin, NC [Non-text portions of this message have been removed] Yahoo! Groups Links -- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.385 / Virus Database: 268.5.1/326 - Release Date: 4/27/2006  |
