					35 FC Transmissions
					04-18-2006, 07:54
Post: #21
				35 FC Transmissions
					Tom, for the most part I think you will find that the modern engines SFC
			numbers are better. When I say modern, I am not including the latest Government compliant generation. Jerry MS Gulf Coast Still Looking _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner Sent: Monday, April 17, 2006 11:28 PM To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Re: 35 FC Transmissions Jerry the electronic controls on todays diesel engine were installed to ensure that the engines meet the very stringent emission standards of today. They have not become more efficient they have become compliant with the laws at the expense of lowering their efficiency. They achieve that by creating more heat and thus run at higher temperatures, and they therefore need better lubricants and increased maintenance, at the same time of operating at reduced power. Remember there is always a tradeoff to everything. A gallon of diesel fuel contains approximately 140,000 BTUs. One horsepower equals 2545 BTUs per hour. Its easy to see that increased horsepower is only achieved thru packing more fuel/air mixture into the cylinders and efficiently exhausting it. Tom Warner Vernon Center,NY 1982 FC35 for sale ( http://tinyurl.com/zv2on ) 1985 PT40 . At 12:11 AM 4/18/2006, you wrote: >Tom, a diesel or gasoline engine is an air breathing device. A turbo >charger increases the amount of air it can breath. If the boost pressure >provided is 14.7 PSI, the engine sees instead of the normal one atmosphere >of pressure, two atmospheres. It is, at 14.7PSI of boost, without losses >considerations, now twice the size engine. It does of course as you noted, >take more fuel. The intercooler takes some of the heat out of the intake >air, providing a denser, heavier fuel air mixture. The magic as I see it is >the electronic controls and devices used today to not only lower emissions >but also create more power with less fuel. > > > >Jerry > >MS Gulf Coast > >Looking for a BB > > > > > > _____ > >From: WanderlodgeForum@yahoogroups.com >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner >Sent: Monday, April 17, 2006 10:27 PM >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > >Hank thats about what I am getting with my 1982 FC35 with the Cat >3208NA. People forget that turbo chargers and intercoolers do not >make an engine more efficient they allow a denser fuel/air charge to >be pumped into the cylinder. More fuel pumped into the cylinder means >more fuel used. A horsepower increase from 210HP to 300HP in the same >engine can only be realized thru the use of more fuel. There is no >magic involved. > >Tom Warner >Vernon Center,NY >1982 FC35 (for sale <http://tinyurl.com/lotbdcan>http://tinyurl.com/lotbdcan ) >1985 PT40 > >At 09:55 PM 4/17/2006, you wrote: > >---Mike: > >That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > >consistently while my 90SP36 gets only 6-7mpg!!! That's a true > >staement and NOT nuts! > >Regards, > >Hank Hannigan > >1990SP36 > > > > > > > > > > > >In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > ><MHOHNSTEIN@...> wrote: > > > > > > That's nuts. Turbo charging and charge air coolers are methods to > >improve the efficiency of diesel engines. The 5 speed OD trans > >keeps engine speed down and increased horse power improves the power > >to weight ratio over the older NA/643 speed bumps. Most 87up FCs > >have two airs and the smaller lighter gen set, handling and > >acceleration are greatly enhanced. There is no way a NA gets better > >mileage than a turbo, level playing field. > > > I drove Millers 88 FC a while back and it was a night and day > >diffference compared to my well tuned 250 hp 83 rear bath. > > > Engine speed is the major issue when considering improving > >milage. > > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at > >full throttle and don't need to go over 2500 rpm for max power. NAs > >need to spin faster due to the lack of forced induction and need > >more fuel to facilitate that. > > > Now I could be over looking something, so if you have some REAL > >experience that might lend some credibility to your aurgument I'm > >listening Warner. I'm interested in miles you have driven your NA, > >average speed, speed on grades, that sort of thing. I assume you > >have taken some trips, so lets hear what you have really seen for > >fuel use. Those considering your FC might want to know. > > > Mike Hohnstein > > > ----- Original Message ----- > > > From: Tom Warner > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Sunday, April 16, 2006 9:58 PM > > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > > > > I doubt very much if you will find an 87-89 FC that will even > >get > > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > >believe > > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > > > Tom Warner > > > Vernon Center,NY > > > 1982 FC35 ( for sale at > ><<http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.p > hotobucket.com/albums/i57/warbucks13477/>http://s69.photobucke >t.com/albums/i57/warbucks13477/ > >) > > > 1985 PT 40 > > > > > > > > > At 09:55 PM 4/16/2006, you wrote: > > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > > >tranny,now,thats not bad milage as i see it! > > > >randy dupree > > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > > transmission in the 35 FC? If so, what year did they > >start? I've > > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > > >however, I > > > > > really hesitate buying one that gets such poor fuel mileage > >as the 4 > > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > >n_ObWmSYTw>Recreational > > > >vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > >y34cC1O9CxA>Automotive > > > >maintenance > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > >aeYHfELr6o72IW1A>Recreational > > > >vehicle dealer > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > >4L-kXbDI4ZSadEw>Used > > > >recreational vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > >nMq_4GlXA>Automotive > > > >radiators > > > > > > > > > > > >---------- > > > >YAHOO! GROUPS LINKS > > > > > > > > * Visit your group > > > > > > > > >"<<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/ group/WanderlodgeForum>http://groups.yahoo.com/gr >oup/WanderlodgeForum>WanderlodgeForum" > > > >on the web. > > > > * > > > > * To unsubscribe from this group, send an email to: > > > > * > > > > > > > > > > > > * > > > > * Your use of Yahoo! Groups is subject to the > > > > > > ><<<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>http ://docs.yahoo.com/info/terms/>Yahoo! > > > Terms of Service. > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > >of Service. > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum>WanderlodgeForum" > on the >web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > n >derlodgeForum-unsubscribe@yahoogroups.com > > > > * > > * Your use of Yahoo! Groups is subject to the > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > >---------- > > > > > > > > >SPONSORED LINKS > > >Recreational ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v > &k=Recreational+vehicles&w1=Recreational+v>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v > &k=Recreational+vehicles&w1=Recreational+v >ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de a >ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DA U >kCKkU7Dzhn_ObWmSYTw> vehicles > >Wanderlodge ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 > &k=Wanderlodge&w1=Recreational+vehicles&w2>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 > &k=Wanderlodge&w1=Recreational+vehicles&w2 >=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us e >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QL P >j9U0JvqYQ> > >Automotive ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ > &k=Automotive+maintenance&w1=Recreational+>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ > &k=Automotive+maintenance&w1=Recreational+ >vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+d e >aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=I F >4u_5wI8Pmy34cC1O9CxA> maintenance > > >Recreational ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati > &k=Recreational+vehicle+dealer&w1=Recreati>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati > &k=Recreational+vehicle+dealer&w1=Recreati >onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehi c >le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&. s >ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer > >Used ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio > &k=Used+recreational+vehicles&w1=Recreatio>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio > &k=Used+recreational+vehicles&w1=Recreatio >nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic l >e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s i >g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles > >Automotive ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve > &k=Automotive+radiators&w1=Recreational+ve>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve > &k=Automotive+radiators&w1=Recreational+ve >hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea l >er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePN V >MmISsCWgTnMq_4GlXA> radiators > > > > _____ > >YAHOO! GROUPS LINKS > > > >* Visit your group "WanderlodgeForum ><<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum> >" on the web. > > >* To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > > >* Your use of Yahoo! Groups is subject to the Yahoo! ><<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/> >Terms of Service. > > > > _____ > > > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > derlodgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed]  |
					04-18-2006, 13:05
Post: #22
				35 FC Transmissions
					Mike, A real good example is the 2007 PowerStroke Diesel from Ford.  Check
			out the details on the following link. 6.4L Power Stroke Diesel . 350HP and 650 lbs.ft. http://wnypa.org/64_files/frame.htm Jerry MS Gulf Coast Looking _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Mike Hohnstein Sent: Tuesday, April 18, 2006 8:39 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions Spoken like a true technical illiterate. Sophisticated contempary fuel controls are responsible for the greatly extended service life of engines, gasoline and diesel. Extrordinary horse power per cubic inch production is common place these days, dwarfing power levels of 20 years ago. There is a reason a 3208 10.3 litre engine is limited to 300 hp in highway use and an 8.3 litre Cummins routinely make in excess of 330, more if you can cool it. We work on many hot rod trucks in the shop and it's unbelievable how much punch these new fangled 5.9s can produce. Electronics are really magic. Expensive but very very cool. I wish I could retrofit my throwaways (3208) with new fuel controls. MH ----- Original Message ----- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 17, 2006 11:28 PM Subject: RE: [WanderlodgeForum] Re: 35 FC Transmissions Jerry the electronic controls on todays diesel engine were installed to ensure that the engines meet the very stringent emission standards of today. They have not become more efficient they have become compliant with the laws at the expense of lowering their efficiency. They achieve that by creating more heat and thus run at higher temperatures, and they therefore need better lubricants and increased maintenance, at the same time of operating at reduced power. Remember there is always a tradeoff to everything. A gallon of diesel fuel contains approximately 140,000 BTUs. One horsepower equals 2545 BTUs per hour. Its easy to see that increased horsepower is only achieved thru packing more fuel/air mixture into the cylinders and efficiently exhausting it. Tom Warner Vernon Center,NY 1982 FC35 for sale ( http://tinyurl.com/zv2on ) 1985 PT40 . At 12:11 AM 4/18/2006, you wrote: >Tom, a diesel or gasoline engine is an air breathing device. A turbo >charger increases the amount of air it can breath. If the boost pressure >provided is 14.7 PSI, the engine sees instead of the normal one atmosphere >of pressure, two atmospheres. It is, at 14.7PSI of boost, without losses >considerations, now twice the size engine. It does of course as you noted, >take more fuel. The intercooler takes some of the heat out of the intake >air, providing a denser, heavier fuel air mixture. The magic as I see it is >the electronic controls and devices used today to not only lower emissions >but also create more power with less fuel. > > > >Jerry > >MS Gulf Coast > >Looking for a BB > > > > > > _____ > >From: WanderlodgeForum@yahoogroups.com >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner >Sent: Monday, April 17, 2006 10:27 PM >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > >Hank thats about what I am getting with my 1982 FC35 with the Cat >3208NA. People forget that turbo chargers and intercoolers do not >make an engine more efficient they allow a denser fuel/air charge to >be pumped into the cylinder. More fuel pumped into the cylinder means >more fuel used. A horsepower increase from 210HP to 300HP in the same >engine can only be realized thru the use of more fuel. There is no >magic involved. > >Tom Warner >Vernon Center,NY >1982 FC35 (for sale <http://tinyurl.com/lotbdcan>http://tinyurl.com/lotbdcan ) >1985 PT40 > >At 09:55 PM 4/17/2006, you wrote: > >---Mike: > >That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > >consistently while my 90SP36 gets only 6-7mpg!!! That's a true > >staement and NOT nuts! > >Regards, > >Hank Hannigan > >1990SP36 > > > > > > > > > > > >In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > ><MHOHNSTEIN@...> wrote: > > > > > > That's nuts. Turbo charging and charge air coolers are methods to > >improve the efficiency of diesel engines. The 5 speed OD trans > >keeps engine speed down and increased horse power improves the power > >to weight ratio over the older NA/643 speed bumps. Most 87up FCs > >have two airs and the smaller lighter gen set, handling and > >acceleration are greatly enhanced. There is no way a NA gets better > >mileage than a turbo, level playing field. > > > I drove Millers 88 FC a while back and it was a night and day > >diffference compared to my well tuned 250 hp 83 rear bath. > > > Engine speed is the major issue when considering improving > >milage. > > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at > >full throttle and don't need to go over 2500 rpm for max power. NAs > >need to spin faster due to the lack of forced induction and need > >more fuel to facilitate that. > > > Now I could be over looking something, so if you have some REAL > >experience that might lend some credibility to your aurgument I'm > >listening Warner. I'm interested in miles you have driven your NA, > >average speed, speed on grades, that sort of thing. I assume you > >have taken some trips, so lets hear what you have really seen for > >fuel use. Those considering your FC might want to know. > > > Mike Hohnstein > > > ----- Original Message ----- > > > From: Tom Warner > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Sunday, April 16, 2006 9:58 PM > > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > > > > I doubt very much if you will find an 87-89 FC that will even > >get > > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > >believe > > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > > > Tom Warner > > > Vernon Center,NY > > > 1982 FC35 ( for sale at > ><<http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.p > hotobucket.com/albums/i57/warbucks13477/>http://s69.photobucke >t.com/albums/i57/warbucks13477/ > >) > > > 1985 PT 40 > > > > > > > > > At 09:55 PM 4/16/2006, you wrote: > > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > > >tranny,now,thats not bad milage as i see it! > > > >randy dupree > > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > > transmission in the 35 FC? If so, what year did they > >start? I've > > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > > >however, I > > > > > really hesitate buying one that gets such poor fuel mileage > >as the 4 > > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > >n_ObWmSYTw>Recreational > > > >vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > >y34cC1O9CxA>Automotive > > > >maintenance > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > >aeYHfELr6o72IW1A>Recreational > > > >vehicle dealer > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > >4L-kXbDI4ZSadEw>Used > > > >recreational vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > >nMq_4GlXA>Automotive > > > >radiators > > > > > > > > > > > >---------- > > > >YAHOO! GROUPS LINKS > > > > > > > > * Visit your group > > > > > > > > >"<<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/ group/WanderlodgeForum>http://groups.yahoo.com/gr >oup/WanderlodgeForum>WanderlodgeForum" > > > >on the web. > > > > * > > > > * To unsubscribe from this group, send an email to: > > > > * > > > > > > > > > > > > * > > > > * Your use of Yahoo! Groups is subject to the > > > > > > ><<<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>http ://docs.yahoo.com/info/terms/>Yahoo! > > > Terms of Service. > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > >of Service. > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum>WanderlodgeForum" > on the >web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > n >derlodgeForum-unsubscribe@yahoogroups.com > > > > * > > * Your use of Yahoo! Groups is subject to the > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > >---------- > > > > > > > > >SPONSORED LINKS > > >Recreational ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v > &k=Recreational+vehicles&w1=Recreational+v>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v > &k=Recreational+vehicles&w1=Recreational+v >ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de a >ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DA U >kCKkU7Dzhn_ObWmSYTw> vehicles > >Wanderlodge ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 > &k=Wanderlodge&w1=Recreational+vehicles&w2>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 > &k=Wanderlodge&w1=Recreational+vehicles&w2 >=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us e >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QL P >j9U0JvqYQ> > >Automotive ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ > &k=Automotive+maintenance&w1=Recreational+>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ > &k=Automotive+maintenance&w1=Recreational+ >vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+d e >aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=I F >4u_5wI8Pmy34cC1O9CxA> maintenance > > >Recreational ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati > &k=Recreational+vehicle+dealer&w1=Recreati>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati > &k=Recreational+vehicle+dealer&w1=Recreati >onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehi c >le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&. s >ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer > >Used ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio > &k=Used+recreational+vehicles&w1=Recreatio>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio > &k=Used+recreational+vehicles&w1=Recreatio >nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic l >e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s i >g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles > >Automotive ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve > &k=Automotive+radiators&w1=Recreational+ve>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve > &k=Automotive+radiators&w1=Recreational+ve >hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea l >er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePN V >MmISsCWgTnMq_4GlXA> radiators > > > > _____ > >YAHOO! GROUPS LINKS > > > >* Visit your group "WanderlodgeForum ><<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum> >" on the web. > > >* To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > > >* Your use of Yahoo! Groups is subject to the Yahoo! ><<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/> >Terms of Service. > > > > _____ > > > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > derlodgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- ---------------------------------------------------------------------------- -- YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ---------------------------------------------------------------------------- -- [Non-text portions of this message have been removed] _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed]  |
					04-18-2006, 13:12
Post: #23
				35 FC Transmissions
					Too bad about the 6.0.  Hope this one works better, the wheels fell off the V6
			engine a while back. Harvester needs a break today, hope this one works. Sure looks good. MH ----- Original Message ----- From: Jerry To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, April 18, 2006 8:05 PM Subject: RE: [WanderlodgeForum] Re: 35 FC Transmissions Mike, A real good example is the 2007 PowerStroke Diesel from Ford. Check out the details on the following link. 6.4L Power Stroke Diesel . 350HP and 650 lbs.ft. http://wnypa.org/64_files/frame.htm Jerry MS Gulf Coast Looking _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Mike Hohnstein Sent: Tuesday, April 18, 2006 8:39 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions Spoken like a true technical illiterate. Sophisticated contempary fuel controls are responsible for the greatly extended service life of engines, gasoline and diesel. Extrordinary horse power per cubic inch production is common place these days, dwarfing power levels of 20 years ago. There is a reason a 3208 10.3 litre engine is limited to 300 hp in highway use and an 8.3 litre Cummins routinely make in excess of 330, more if you can cool it. We work on many hot rod trucks in the shop and it's unbelievable how much punch these new fangled 5.9s can produce. Electronics are really magic. Expensive but very very cool. I wish I could retrofit my throwaways (3208) with new fuel controls. MH ----- Original Message ----- From: Tom Warner To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 17, 2006 11:28 PM Subject: RE: [WanderlodgeForum] Re: 35 FC Transmissions Jerry the electronic controls on todays diesel engine were installed to ensure that the engines meet the very stringent emission standards of today. They have not become more efficient they have become compliant with the laws at the expense of lowering their efficiency. They achieve that by creating more heat and thus run at higher temperatures, and they therefore need better lubricants and increased maintenance, at the same time of operating at reduced power. Remember there is always a tradeoff to everything. A gallon of diesel fuel contains approximately 140,000 BTUs. One horsepower equals 2545 BTUs per hour. Its easy to see that increased horsepower is only achieved thru packing more fuel/air mixture into the cylinders and efficiently exhausting it. Tom Warner Vernon Center,NY 1982 FC35 for sale ( http://tinyurl.com/zv2on ) 1985 PT40 . At 12:11 AM 4/18/2006, you wrote: >Tom, a diesel or gasoline engine is an air breathing device. A turbo >charger increases the amount of air it can breath. If the boost pressure >provided is 14.7 PSI, the engine sees instead of the normal one atmosphere >of pressure, two atmospheres. It is, at 14.7PSI of boost, without losses >considerations, now twice the size engine. It does of course as you noted, >take more fuel. The intercooler takes some of the heat out of the intake >air, providing a denser, heavier fuel air mixture. The magic as I see it is >the electronic controls and devices used today to not only lower emissions >but also create more power with less fuel. > > > >Jerry > >MS Gulf Coast > >Looking for a BB > > > > > > _____ > >From: WanderlodgeForum@yahoogroups.com >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner >Sent: Monday, April 17, 2006 10:27 PM >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > >Hank thats about what I am getting with my 1982 FC35 with the Cat >3208NA. People forget that turbo chargers and intercoolers do not >make an engine more efficient they allow a denser fuel/air charge to >be pumped into the cylinder. More fuel pumped into the cylinder means >more fuel used. A horsepower increase from 210HP to 300HP in the same >engine can only be realized thru the use of more fuel. There is no >magic involved. > >Tom Warner >Vernon Center,NY >1982 FC35 (for sale <http://tinyurl.com/lotbdcan>http://tinyurl.com/lotbdcan ) >1985 PT40 > >At 09:55 PM 4/17/2006, you wrote: > >---Mike: > >That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > >consistently while my 90SP36 gets only 6-7mpg!!! That's a true > >staement and NOT nuts! > >Regards, > >Hank Hannigan > >1990SP36 > > > > > > > > > > > >In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > ><MHOHNSTEIN@...> wrote: > > > > > > That's nuts. Turbo charging and charge air coolers are methods to > >improve the efficiency of diesel engines. The 5 speed OD trans > >keeps engine speed down and increased horse power improves the power > >to weight ratio over the older NA/643 speed bumps. Most 87up FCs > >have two airs and the smaller lighter gen set, handling and > >acceleration are greatly enhanced. There is no way a NA gets better > >mileage than a turbo, level playing field. > > > I drove Millers 88 FC a while back and it was a night and day > >diffference compared to my well tuned 250 hp 83 rear bath. > > > Engine speed is the major issue when considering improving > >milage. > > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at > >full throttle and don't need to go over 2500 rpm for max power. NAs > >need to spin faster due to the lack of forced induction and need > >more fuel to facilitate that. > > > Now I could be over looking something, so if you have some REAL > >experience that might lend some credibility to your aurgument I'm > >listening Warner. I'm interested in miles you have driven your NA, > >average speed, speed on grades, that sort of thing. I assume you > >have taken some trips, so lets hear what you have really seen for > >fuel use. Those considering your FC might want to know. > > > Mike Hohnstein > > > ----- Original Message ----- > > > From: Tom Warner > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Sunday, April 16, 2006 9:58 PM > > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > > > > I doubt very much if you will find an 87-89 FC that will even > >get > > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > >believe > > > the 4th gear is the same as the 5th or 6th gear in the 87-89. > > > > > > Tom Warner > > > Vernon Center,NY > > > 1982 FC35 ( for sale at > ><<http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.p > hotobucket.com/albums/i57/warbucks13477/>http://s69.photobucke >t.com/albums/i57/warbucks13477/ > >) > > > 1985 PT 40 > > > > > > > > > At 09:55 PM 4/16/2006, you wrote: > > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > > >tranny,now,thats not bad milage as i see it! > > > >randy dupree > > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > > transmission in the 35 FC? If so, what year did they > >start? I've > > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > > >however, I > > > > > really hesitate buying one that gets such poor fuel mileage > >as the 4 > > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > >n_ObWmSYTw>Recreational > > > >vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > >y34cC1O9CxA>Automotive > > > >maintenance > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > >aeYHfELr6o72IW1A>Recreational > > > >vehicle dealer > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > >4L-kXbDI4ZSadEw>Used > > > >recreational vehicles > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads?>http://group s.yahoo.com/gads? > >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > >nMq_4GlXA>Automotive > > > >radiators > > > > > > > > > > > >---------- > > > >YAHOO! GROUPS LINKS > > > > > > > > * Visit your group > > > > > > > > >"<<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/ group/WanderlodgeForum>http://groups.yahoo.com/gr >oup/WanderlodgeForum>WanderlodgeForum" > > > >on the web. > > > > * > > > > * To unsubscribe from this group, send an email to: > > > > * > > > > > > > > > > > > * > > > > * Your use of Yahoo! Groups is subject to the > > > > > > ><<<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>http ://docs.yahoo.com/info/terms/>Yahoo! > > > Terms of Service. > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > >of Service. > > > > > > > > > ------------------------------------------------------------------- > >----------- > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum>WanderlodgeForum" > on the >web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > n >derlodgeForum-unsubscribe@yahoogroups.com > > > > * > > * Your use of Yahoo! Groups is subject to the > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/>Yahoo! > Terms of Service. > > > > > >---------- > > > > > > > > >SPONSORED LINKS > > >Recreational ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v > &k=Recreational+vehicles&w1=Recreational+v>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v > &k=Recreational+vehicles&w1=Recreational+v >ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de a >ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DA U >kCKkU7Dzhn_ObWmSYTw> vehicles > >Wanderlodge ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 > &k=Wanderlodge&w1=Recreational+vehicles&w2>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 > &k=Wanderlodge&w1=Recreational+vehicles&w2 >=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us e >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QL P >j9U0JvqYQ> > >Automotive ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ > &k=Automotive+maintenance&w1=Recreational+>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ > &k=Automotive+maintenance&w1=Recreational+ >vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+d e >aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=I F >4u_5wI8Pmy34cC1O9CxA> maintenance > > >Recreational ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati > &k=Recreational+vehicle+dealer&w1=Recreati>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati > &k=Recreational+vehicle+dealer&w1=Recreati >onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehi c >le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&. s >ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer > >Used ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio > &k=Used+recreational+vehicles&w1=Recreatio>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio > &k=Used+recreational+vehicles&w1=Recreatio >nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic l >e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s i >g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles > >Automotive ><<http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve > &k=Automotive+radiators&w1=Recreational+ve>http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve > &k=Automotive+radiators&w1=Recreational+ve >hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea l >er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePN V >MmISsCWgTnMq_4GlXA> radiators > > > > _____ > >YAHOO! GROUPS LINKS > > > >* Visit your group "WanderlodgeForum ><<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr oup/WanderlodgeForum> >" on the web. > > >* To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > > >* Your use of Yahoo! Groups is subject to the Yahoo! ><<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/> >Terms of Service. > > > > _____ > > > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > derlodgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- ---------------------------------------------------------------------------- -- YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ---------------------------------------------------------------------------- -- [Non-text portions of this message have been removed] _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed]  |
					04-18-2006, 13:47
Post: #24
				35 FC Transmissions
			wrote: >the way i remember the old days of trucking was most trucks had maybe 300 hp and got maybe 3mpg,now we can have 650 hp and get 6-8 mpg with the new electronic engines,and get 500,000 miles before the first inframe overhaul. just think if they didnt have turbos or charge air coolers..i don't miss the smoke filled air at a truck stop.. randy dupree 93wb,84fc for sale,95 43' for sale. > Jerry the electronic controls on todays diesel engine were installed > to ensure that the engines meet the very stringent emission standards > of today. They have not become more efficient they have become > compliant with the laws at the expense of lowering their > efficiency. They achieve that by creating more heat and thus run at > higher temperatures, and they therefore need better lubricants and > increased maintenance, at the same time of operating at reduced > power. Remember there is always a tradeoff to everything. A gallon > of diesel fuel contains approximately 140,000 BTUs. One horsepower > equals 2545 BTUs per hour. Its easy to see that increased horsepower > is only achieved thru packing more fuel/air mixture into the > cylinders and efficiently exhausting it. > > Tom Warner > Vernon Center,NY > 1982 FC35 for sale ( http://tinyurl.com/zv2on ) > 1985 PT40 > > > > > . At 12:11 AM 4/18/2006, you wrote: > >Tom, a diesel or gasoline engine is an air breathing device. A turbo > >charger increases the amount of air it can breath. If the boost pressure > >provided is 14.7 PSI, the engine sees instead of the normal one atmosphere > >of pressure, two atmospheres. It is, at 14.7PSI of boost, without losses > >considerations, now twice the size engine. It does of course as you noted, > >take more fuel. The intercooler takes some of the heat out of the intake > >air, providing a denser, heavier fuel air mixture. The magic as I see it is > >the electronic controls and devices used today to not only lower emissions > >but also create more power with less fuel. > > > > > > > >Jerry > > > >MS Gulf Coast > > > >Looking for a BB > > > > > > > > > > > > _____ > > > >From: WanderlodgeForum@yahoogroups.com > >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner > >Sent: Monday, April 17, 2006 10:27 PM > >To: WanderlodgeForum@yahoogroups.com > >Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > > >Hank thats about what I am getting with my 1982 FC35 with the Cat > >3208NA. People forget that turbo chargers and intercoolers do not > >make an engine more efficient they allow a denser fuel/air charge to > >be pumped into the cylinder. More fuel pumped into the cylinder means > >more fuel used. A horsepower increase from 210HP to 300HP in the same > >engine can only be realized thru the use of more fuel. There is no > >magic involved. > > > >Tom Warner > >Vernon Center,NY > >1982 FC35 (for sale <http://tinyurl.com/lotbdcan>http://tinyurl.com/lotbdcan ) > >1985 PT40 > > > >At 09:55 PM 4/17/2006, you wrote: > > >---Mike: > > >That's nuts!!! My 77FC33 with the CAT 210NA got 8-9mpg > > >consistently while my 90SP36 gets only 6-7mpg!!! That's a true > > >staement and NOT nuts! > > >Regards, > > >Hank Hannigan > > >1990SP36 > > > > > > > > > > > > > > > > > >In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > > ><MHOHNSTEIN@> wrote: > > > > > > > > That's nuts. Turbo charging and charge air coolers are methods to > > >improve the efficiency of diesel engines. The 5 speed OD trans > > >keeps engine speed down and increased horse power improves the power > > >to weight ratio over the older NA/643 speed bumps. Most 87up FCs > > >have two airs and the smaller lighter gen set, handling and > > >acceleration are greatly enhanced. There is no way a NA gets better > > >mileage than a turbo, level playing field. > > > > I drove Millers 88 FC a while back and it was a night and day > > >diffference compared to my well tuned 250 hp 83 rear bath. > > > > Engine speed is the major issue when considering improving > > >milage. > > > > Turbo/charge air cooled engines can tolerate 400 rpm lower rpm at > > >full throttle and don't need to go over 2500 rpm for max power. NAs > > >need to spin faster due to the lack of forced induction and need > > >more fuel to facilitate that. > > > > Now I could be over looking something, so if you have some REAL > > >experience that might lend some credibility to your aurgument I'm > > >listening Warner. I'm interested in miles you have driven your NA, > > >average speed, speed on grades, that sort of thing. I assume you > > >have taken some trips, so lets hear what you have really seen for > > >fuel use. Those considering your FC might want to know. > > > > Mike Hohnstein > > > > ----- Original Message ----- > > > > From: Tom Warner > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Sunday, April 16, 2006 9:58 PM > > > > Subject: Re: [WanderlodgeForum] Re: 35 FC Transmissions > > > > > > > > > > > > I doubt very much if you will find an 87-89 FC that will even > > >get > > > > close to the fuel mileage of the 1982 FC/31/33/35 coaches. I > > >believe > > > > the 4th gear is the same as the 5th or 6th gear in the 87- 89. > > > > > > > > Tom Warner > > > > Vernon Center,NY > > > > 1982 FC35 ( for sale at > > ><<http://s69.photobucket.com/albums/i57/warbucks13477/>http://s69.p > > hotobucket.com/albums/i57/warbucks13477/>http://s69.photobucke > >t.com/albums/i57/warbucks13477/ > > >) > > > > 1985 PT 40 > > > > > > > > > > > > At 09:55 PM 4/16/2006, you wrote: > > > > >--- In WanderlodgeForum@yahoogroups.com, "sailingmyway" > > > > > > > > > > >i hear storys from 7-10 mpg on the fcs with the 4 speed > > > > >tranny,now,thats not bad milage as i see it! > > > > >randy dupree > > > > > > Does anyone know if they ever put the 5 or 6 speed overdrive > > > > > > transmission in the 35 FC? If so, what year did they > > >start? I've > > > > > > zeroed in on the 35FC as the correct Bird for my wife and I, > > > > >however, I > > > > > > really hesitate buying one that gets such poor fuel mileage > > >as the 4 > > > > > > speed Allison. John & Pat - Wantabee's, Stuart > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >http://groups.yahoo.com/gads? > > >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge & > > >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec r > > >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dz h > > >n_ObWmSYTw>Recreational > > > > >vehicles > > > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >http://groups.yahoo.com/gads? > > >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automo t > > >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+ v > > >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > > >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >http://groups.yahoo.com/gads? > > >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodg e > > >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+re c > > >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8P m > > >y34cC1O9CxA>Automotive > > > > >maintenance > > > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >http://groups.yahoo.com/gads? > > >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wande r > > >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us e > > >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xa h > > >aeYHfELr6o72IW1A>Recreational > > > > >vehicle dealer > > > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >http://groups.yahoo.com/gads? > > >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wander l > > >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d > > >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5k m > > >4L-kXbDI4ZSadEw>Used > > > > >recreational vehicles > > > > > > ><<<http://groups.yahoo.com/gads?>http://groups.yahoo.com/gads? >http://groups.yahoo.com/gads? > > >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge& w > > >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr e > > >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWg T > > >nMq_4GlXA>Automotive > > > > >radiators > > > > > > > > > > > > > > >---------- > > > > >YAHOO! GROUPS LINKS > > > > > > > > > > * Visit your group > > > > > > > > > > > > >"<<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yah oo.com/group/WanderlodgeForum>http://groups.yahoo.com/gr > >oup/WanderlodgeForum>WanderlodgeForum" > > > > > >on the web. > > > > > * > > > > > * To unsubscribe from this group, send an email to: > > > > > * > > > > > > > > > > > > > > > * > > > > > * Your use of Yahoo! Groups is subject to the > > > > > > > > > ><<<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/term s/>http://docs.yahoo.com/info/terms/>Yahoo! > > > > > Terms of Service. > > > > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ------------------------------------------------------------- ------ > > >----------- > > > > YAHOO! GROUPS LINKS > > > > > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > > > > > b.. To unsubscribe from this group, send an email to: > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > > >of Service. > > > > > > > > > > > > ------------------------------------------------------------- ------ > > >----------- > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yah oo.com/group/WanderlodgeForum>WanderlodgeForum" > > on the > >web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > >derlodgeForum-unsubscribe@yahoogroups.com > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/ >Yahoo! > > Terms of Service. > > > > > > > > >---------- > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > > > > >Recreational > ><<http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicles&w1=Recreational+v>http://groups.yahoo.co m/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v > >ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+veh icle+dea > >ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163& .sig=DAU > >kCKkU7Dzhn_ObWmSYTw> vehicles > > > >Wanderlodge > ><<http://groups.yahoo.com/gads? t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2>http://groups.yahoo.co m/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 > >=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale r&w5=Use > >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- 8HJdysB3QLP > >j9U0JvqYQ> > > > >Automotive > ><<http://groups.yahoo.com/gads? t=ms&k=Automotive+maintenance&w1=Recreational+>http://groups.yahoo.co m/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ > >vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+ve hicle+de > >aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163 &.sig=IF > >4u_5wI8Pmy34cC1O9CxA> maintenance > > > > > >Recreational > ><<http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+dealer&w1=Recreati>http://groups.yahoo.co m/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati > >onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreation al+vehic > >le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6& s=163&.s > >ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer > > > >Used > ><<http://groups.yahoo.com/gads? t=ms&k=Used+recreational+vehicles&w1=Recreatio>http://groups.yahoo.co m/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio > >nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreationa l+vehicl > >e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s =163&.si > >g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles > > > >Automotive > ><<http://groups.yahoo.com/gads? t=ms&k=Automotive+radiators&w1=Recreational+ve>http://groups.yahoo.co m/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve > >hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehi cle+deal > >er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&. sig=ePNV > >MmISsCWgTnMq_4GlXA> radiators > > > > > > > > _____ > > > >YAHOO! GROUPS LINKS > > > > > > > >* Visit your group "WanderlodgeForum > ><<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yahoo .com/group/WanderlodgeForum> > >" on the web. > > > > > >* To unsubscribe from this group, send an email to: > >WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > >* Your use of Yahoo! Groups is subject to the Yahoo! > ><<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms /> > >Terms of Service. > > > > > > > > _____ > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- >  |
