10-10-2013, 22:06
Post: #31
Love those colors Ernie , sure looks perty
10-11-2013, 08:24
Post: #32
I don't know how many coats of clear coat is on there, but the finish is very nice
10-22-2013, 06:48
Post: #33
Ernie, We've both been in flooring for a long time. My next anniversary will be 55 years. Oh how I know you earn your fees.
I've been two days removing the old carpet from our 450. My most patient installer will be out Friday to install new. Question: There are a few places we will need to use an adhesive. What do you use and or recommend? Most areas are plywood with a large steel plate under the co-pilot seat. Jack and Ila VanDenBerg Glenn, Mi. 49416 M 450 Ruffled Feathers |
10-22-2013, 08:23
Post: #34
Jack- what material are going to have installed?
10-22-2013, 20:50
Post: #35
Erine, A carpet from Fabrica . standard backing.
10-23-2013, 08:19
Post: #36
If you are going to use pad, I have switched to a 3/8 8- 10 pound pad.
10-24-2013, 05:44
Post: #37
(10-23-2013 08:19)ernie ekberg Wrote: If you are going to use pad, I have switched to a 3/8 8- 10 pound pad. There are a few places we will need to use an adhesive. (No pad) What do you use and or recommend? Most areas are plywood with a large steel plate under the co-pilot seat. Jack and Ila VanDenBerg Glenn, Mi. 49416 M 450 Ruffled Feathers |
10-24-2013, 08:20
Post: #38
contact cement
10-29-2013, 08:38
Post: #39
Seems that the outside trim had become loose on the refer compartment. Water damaged the deck and reconstruction is in order. Plus re-routing the refer drain
10-29-2013, 10:08
Post: #40
Whatya working on there Ernie?
(10-29-2013 08:38)ernie ekberg Wrote: Seems that the outside trim had become loose on the refer compartment. Water damaged the deck and reconstruction is in order. Plus re-routing the refer drain david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
