Maiden Voyage Complete!!!
06-15-2008, 10:16
Corey- welcome to the wonderful world of Bluebird.
83PT40
Livingston, Montana
Vote for your city's best dining and nightlife. City's Best 2008.
06-15-2008, 14:00
Well, our new to us 96' WLWB is safe at home. We flew to Houston yesterday
morning
and drove to Wimberley, then came on home today.
What a pleasant experience this has been for us. The coach was in every bit as
good of
shape as described, better than I expected. We drove a little over 500miles,
and truely
made the trip without a glitch.
Now for my first questions, I have the same door problems as addressed in the
door seal
thread, so I'm going to try the remedies previously posted before asking
additional
questions.
i am having two problems,
1. I cant get the leveling system to power up, so I have no ability to level
the coach. I'm
not familiar with using jacks, as our last coach used the air to level, but I
cant get a light
to flicker on the control pad, so I don't know where to go from there.
2. There is a kool o matic fan in the galley, the fan runs all the time, and i
absolutely
cant find a switch or rheostat to control the fan. So currently it runs all the
time and like
a dummy, I don't know where to turn it off.
I have several smaller issues, but I will address these 1 by 1 to make sure I
get
everything completed before taking on the next task.
Corey,
No longer a Wannabe!!!
06-15-2008, 14:28
Corey,
The fan should be controlled by the wall thermostat in that general
area. If it is like mine, it is like a normal home unit with a "Heat-
Off-Cool" switch and a fan "Auto-On" switch. If the "Auto-On" switch
is set to 'On', the fan runs constantly. When set to 'Auto'
and 'Cool', the fan will function off the thermostat setting.
Of course, your coach is much newer, so your set-up could be totally
different.
Scott Forman
86 PT38
Memphis
yesterday morning
every bit as good of
500miles, and truely
addressed in the door seal
asking additional
> questions.
ability to level the coach. I'm
level, but I cant get a light
there.
time, and i absolutely
runs all the time and like
make sure I get
> Corey,
06-15-2008, 14:45
Welcome to Bluebird. The coolmatic fanon my coach is controlled by the small bronze colored thermostat on the starboard galley wall. I seem to remember it is the aft-most of the two switches on the control.
Unless someone moved the jack control it should be to the left of the drivers butt and you press the top switch once and when the light comes on, press it again and the jacks should start to deploy. Thereafter, do nothing until it stops of its own accord. To retract the jacks, press the topmost button and then the "store" button. Some one at BB did not know the difference between "store" and "stow", oh well, something only a sailor type would notice.
Hope this helps.
Wallace Craig
95 WLWB 42
Azle, Texas
--- On Sun, 6/15/08, coreyg67 wrote:
Subject: [WanderlodgeForum] Maiden Voyage Complete!!!
Date: Sunday, June 15, 2008, 9:00 PM
morning and drove to Wimberley, then came on home today. What a pleasant experience this has been for us. The coach was in every bit as
good of shape as described, better than I expected. We drove a little over 500miles,
and truely made the trip without a glitch.
door seal thread, so I'm going to try the remedies previously posted before asking
additional questions. i am having two problems,
the coach. I'm not familiar with using jacks, as our last coach used the air to level, but I
cant get a light to flicker on the control pad, so I don't know where to go from there.
absolutely cant find a switch or rheostat to control the fan. So currently it runs all
the time and like a dummy, I don't know where to turn it off. I have several smaller issues, but I will address these 1 by 1 to make sure I
get everything completed before taking on the next task.
Corey,
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
mailto:WanderlodgeForum-digest@yahoogroups.com mailto:WanderlodgeForum-fullfeatured@yahoogroups.com
06-15-2008, 22:45
I have a 1991 WBWL with the automatic leveling system. On the face of the control panel there is a 5 amp fuse. Your system may not look like mine but I am sure there is a fuse that provides power to the panel. Your problem sure sounds like a fuse has blown. Jim Barone, Ocean City Maryland
In a message dated 6/16/2008 9:08:15 A.M. Central Daylight Time, corey@... writes:
Well 1 problem crossed off the list. I found the thermostat and turned off the fan. I
knew it was going to be something simple, I just couldnt figure out where they had
hidden the control.
As far as the jacks, I'm still stuck. i cant get power to the control panel to even operate
the system. I'm familiar with how the system functions, but I kill the motor, turn the key
to the on position, press the button on the pad, and nothing. No lights, no indicators,
no noises, its like I'm pressing on a blank wall. I'm sure there is a fuse or breaker
somewhere that is tripped or blown, but I have no idea where it might be located.
I'm sorry for the questions, but I've never had anyone instruct me on the Bluebird, or
where any of its systems and controls are locate, so it feels as if I'm on a treasure hunt
most of the time.
Thanks again
Corey
--- In "WanderlodgeForum%40yahoogroups.com", "coreyg67" wrote:
> Well, our new to us 96' WLWB is safe at home. We flew to Houston yesterday morning
> What a pleasant experience this has been for us. The coach was in every bit as good
of
> shape as described, better than I expected. We drove a little over 500miles, and truely
> Now for my first questions, I have the same door problems as addressed in the door
seal
> thread, so I'm going to try the remedies previously posted before asking additional
> questions.
> 1. I cant get the leveling system to power up, so I have no ability to level the coach.
I'm
> not familiar with using jacks, as our last coach used the air to level, but I cant get a
light
> 2. There is a kool o matic fan in the galley, the fan runs all the time, and i absolutely
> cant find a switch or rheostat to control the fan. So currently it runs all the time and
like
> I have several smaller issues, but I will address these 1 by 1 to make sure I get
> Corey,
06-16-2008, 00:34
Regarding jacks....
Also the ignition switch must be turned either to "accessory position" or
"on position" to activate the jack panel.
Mike, from Thomaston Maine
'97 BMC 40'
Michael Brody
P.O. Box 281
Dresher, PA 19025
(V) 215-572-0663
(F) 215-572-6992
06-16-2008, 01:55
Mike,
How are you doing??? Did you get the bus back??? How is it and what was the final result???
Sea Ya
Larry
NYC
84 35FCSB
'Pura Vida'
----- Original Message ----
Sent: Monday, June 16, 2008 8:34:34 AM
Subject: [WanderlodgeForum] Re: Maiden Voyage Complete!!!
Regarding jacks....
'97 BMC 40'
Michael Brody
P.O. Box 281
Dresher, PA 19025
(V) 215-572-0663
(F) 215-572-6992
06-16-2008, 02:07
fan. I
had
hidden the control.
even operate
turn the key
indicators,
breaker
located.
Bluebird, or
treasure hunt
most of the time.
Thanks again
Corey
morning
as good
of
and truely
door
seal
additional
> questions.
the coach.
I'm
cant get a
light
i absolutely
the time and
like
get
> Corey,
06-16-2008, 03:53
Corey,
Might check a couple other key positions, including accessory. Also, I leave my generator on to keep things charged while hydraulics are operating. I've actually been able to use my jacks with the coach engine running.
Blue Bird hides breakers and fuses all over the front..including behind hidden panels in the overhead compartments.
Hope it's something that simple.
Now you can invite friends from Facebook and other groups to join you on Windows Live™ Messenger. Add them now!
06-16-2008, 03:55
Corey,
On the LXi, the HWH system won't come alive unless all
basement doors are shut. The system detects that they are
shut via mercury switches mounted on the door arms/hinges.
Check to see that the 2 wires to each switch are connected.
Many times these wires break due to metal fatigue from the
constant bending/flexing. Just a thought... your HWH system
may not be wired for this safety check.
David Brady
'02 LXi, NC
where they had
hidden the control.
motor, turn the key
fuse or breaker
be located.
the Bluebird, or
on a treasure hunt
most of the time.
Thanks again
Corey
yesterday morning
every bit as good
of
seal
asking additional
> questions.
I'm
light
there.
like
make sure I get
> Corey,
Checked by AVG. Version: 7.5.524 / Virus Database: 270.3.0/1504 - Release Date: 6/15/2008 5:52 PM
