LXi Lug Centric Wheel Studs
09-28-2013, 10:36
(This post was last modified: 09-28-2013 19:02 by davidbrady.)
For the drive axle with the Dana Spicer W230 and 8.62" drums I have:
Starts with Chassis Serial Number 10001400 (4/6/98) ends with 6/13/99 Studs: Webb 101178 right hand, and Webb 101179 left hand Inner Cap Nut: 5978 or 5988 R or L Outer Cap Nut: 5996 R or L Starts with 6/14/99 ends with Chassis Serial Number 10052364 Studs: Webb 101172 right hand, and Webb 101173 left hand Inner Cap Nut: 5978 or 5988 R or L Outer Cap Nut: 5996 R or L I uploaded a copy of Euclid's Wheel Attaching Parts to our Library under Document Library -> Chassis -> Tires and Wheels. Euclid Wheel Attaching Parts.pdf (Size: 2.41 MB / Downloads: 1293) david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
2 users Like davidbrady's post |
09-28-2013, 12:27
RE: LXi Lug Centric Wheel Studs
Good info David, all Wanderlodge owners should have a " Chassis Maintenance Manual and Parts Catalog", it has part number's and front and rear axle diagram's. Jay
09-28-2013, 19:40
I have looked and do not have the Chassis parts Manual . our 93 WB had one but not in our LXI . If a 200LXI owner has one maybe he could put it on line .
09-28-2013, 20:37
We have a Chassis Parts Catalog for the LX/LXi. It's in our Library under Document Library -> Owners Manuals. It has lots of part numbers; unfortunately, virtually all of them are internal BB numbers.
09-29-2013, 12:46
David , I see this is for what appears to be 2001-02 BB . I have always wondered what some of the differences were in our 2000 vs 01, o2 respectively . I think you said you do not have the inner outer wheel lugs , so that is one they also went to 16500 front axle from the 14500 on the 2000 . what other changes /upgrades to overall coach were there ?
09-29-2013, 22:28
(This post was last modified: 09-29-2013 22:52 by travelite.)
Al,
Here's a few items that I've come across, by no means exhaustive: Steer Axle: I146 became I160, Brakes: single channel and 4 channel ABS to 6 channel ABS, Drive axle brake drums: 7" became 8.62", Tag axle brake drums: 6" on steer tag became 7" on fixed, Wheel mounts: lug centric became hub centric, Ridewell suspension: reworked using FEA, Ridewell suspension hangers: two drive hangers for drive/tag axles became one combined hanger, Suspension: no anti sway bar, became 1 3/4" dia bar, became 2 1/8" dia bar, Shocks: Gabriel became Koni, Tag axle: Lift became Steer became Fixed, Bulk Oil: there and then gone, Batteries: Gel then AGM w/ supporting inverters, Transfer Switch: assorted house relays became implemented in Xantrex inverter, A myriad of Detroit Diesel Series 60 improvements. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
