Sporlan Water Valve- Changeout
03-16-2006, 12:28
-----Original Message-----
Sent: Fri, 17 Mar 2006 00:04:48 -0000
Subject: [WanderlodgeForum] Re: Sporlan Water Valve- Changeout
yes ernie, the valve is on the floor behind the built in dresser. I
had to dismantle the dresser cabinet and jack it up enough to get my
upper torso in to get the top off the valve. I can barely see it. Any
way it was coated with white mineral stuff which I cleaned off. since
its so hard to get to I thougt it best to put in new parts. By the way
I fixed my gen set(wouldnt fire). Changed fuel filter and tightned alt
belt.
edgardels 89sp
arlington texas
Ed, that must have been an undertaking. I remember we searched hi and low for
that thing. Glad it worked out for you. Ernie-83pt40 back home in Texas
> > SPONSORED LINKS
> > Recreational vehicles
sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\
bWmSYTw>
> > Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\
derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\
tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>
> > Automotive maintenance
Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\
cC1O9CxA>
> > Recreational vehicle dealer
r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\
HfELr6o72IW1A>
> > Used recreational vehicles
<http://groups.yahoo.com/gads?t=ms&k=Used...onal+\
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\
&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\
kXbDI4ZSadEw>
> > Automotive radiators
<http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\
es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\
ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\
_4GlXA>
> > YAHOO! GROUPS LINKS
> > * Visit your group "WanderlodgeForum
> > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web.
> > * To unsubscribe from this group, send an email to:
> > WanderlodgeForum-unsubscribe@yahoogroups.com
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service <http://docs.yahoo.com/info/terms/>.
> Yahoo! Groups Links
Yahoo! Groups Links
03-16-2006, 12:36
--- In WanderlodgeForum@yahoogroups.com, "Stephen" <share@...> wrote:
Steven- Im not very knowledgble about birds yet but thats what I
learned at my last rally. My diafram was also flexible and looked new.
The o ring is good too. Will install new ones when they get here. Its
been broke since December.
good luck
ed gardels 89sp
arlington
> My valve was not clogged, or full of anything. I took it apart
before I knew
> I had problems, because it was leaking(the big o-ring) I went to the
local
> hardware store, and got a new o-ring.. Well it does not leak, but it
does
> not stop water from flowing either. The rubber disc was clean, and
soft..
> but I guess it has sit up dry for a long time, and the top rubber
does not
> seal the hole anymore??.. I guess I need a rebuild kit. When I go
outside
> and move the "tank Fill" switch on/off, I hear a clicking sound
inside.. I
> assume the solenoid is trying to open/close. and it is getting
power. What
> cha think?
> Stephen
> 81 FC-33SB
> Plant City, Fl
> _____
> [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger
> Sent: Thursday, March 16, 2006 1:28 PM
> Subject: Re: [WanderlodgeForum] Re: Sporlan Water Valve- Changeout
> Ed,
> No too bad. Mine was between walls that support the bed and keep the
> water tank in place. A space about 12 inches by 24 inches, filled with
> plumbing. Lifted the mattress and supported it, removed the mattress
> platform, and stuck my head in under the mattress and cussed the whole
> time. About a half hour job. It would take all day if I had to R&R the
> valve body.
> Curt Sprenger 1987 PT38, Anaheim Hills, Calif.
> ED GARDELS wrote:
> > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger
> > wrote:
> > Yes curt, the diaphram was dirty but now looks clean and new. It was
> > soooo hard to get at(behind bedroom dresser which i had to
> > dismantal) that i thought I would put in new parts.Was yours hard to
> > get to?
> > edgardels 89sp
> > Arlington Texas
> > > Is the diaphragm in good condition? A while back I took mine
> > apart,
> > > removed the white stuff, lightly cleaned the diaphragm, and
> > reassembled
> > > it. Works great so far.
> > > .Curt Sprenger 1987 PT38, Anaheim Hills, Calif.
> > > ED GARDELS wrote:
> > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@>
> > > > wrote:
> > > > Steven, I have the same problem you described.(89sp). I have my
> > > > valve out right now, and ordered a rebuild kit from bb yesterday,
> > > > $30.00.. The valve(I could only get the top off with 4 bolts)and
> > it
> > > > was filled with a white scum from water contamanites.I understand
> > > > from other owners that it sticks in this condition and causes
> > what
> > > > you described.
> > > > good luck
> > > > Ed Gardels 89sp
> > > > Arlington, Texas
> _____
03-24-2006, 11:03
Ed
Where is the sporlan located in your 89SP?
I have an 89SP also, with a center queen bed. I think I have located
mine on the curb side at the bottom of the bedroom cabinets at the
foot of the bed. Is that the location?
--- In WanderlodgeForum@yahoogroups.com, "ED GARDELS"
> $30.00.. The valve(I could only get the top off with 4 bolts)and it
> from other owners that it sticks in this condition and causes what
> you described.
> good luck
> Ed Gardels 89sp
> Arlington, Texas
> > Has anyone ever replced one of these? Now that all my water lines
> are
> > repaired- and I have pressure, the valve that is used to fill the
> > fresh tank is obvously not working. EWhen I hook up city water, it
> > starts to fill the tank- without regard to the valve switch on or
> off.
> > I can hear the valve clicking and trying to work, but it does not.
> The
> > water pump also is affected by this- because it does not seal the
> > loop, and lets water bypass around in a circle.
> > I have even thought about seeing if there was a type of manual
> valve
> > with a push/pull type cable to open and close the connection.
> > Help??!
> > Stephen
> > 81 FC-33SB
> > Plant City, FL
03-24-2006, 15:09
--- In WanderlodgeForum@yahoogroups.com, "fred89sp"
>thats where the valve is on the 90sp i have here.
randy
> Ed
located
yesterday,
it
understand
what
> > you described.
> > good luck
> > Ed Gardels 89sp
> > Arlington, Texas
lines
> > are
water, it
or
> > off.
not.
> > The
> > valve
> > > Help??!
> > > Stephen
> > > 81 FC-33SB
> > > Plant City, FL
03-25-2006, 03:28
--- In WanderlodgeForum@yahoogroups.com, "fred89sp" wrote:
FRED-- Yes, thats where its at. I have pictures for you I will send in
near future. Just recieved rebuild kit from bb.
Ed gardels 89sp
Arlington,Tx
> Ed
> > you described.
> > good luck
> > Ed Gardels 89sp
> > Arlington, Texas
> > are
> > off.
> > The
> > valve
> > > Help??!
> > > Stephen
> > > 81 FC-33SB
> > > Plant City, FL
03-25-2006, 12:31
Fred
On my 90 the valve is under the bed. Raise the foot of the bed and you will
find it under the head on the curb side.
LT 90 SP
in Eclectic, AL
To:
Sent: Friday, March 24, 2006 5:03 PM
> Ed
>> you described.
>> good luck
>> Ed Gardels 89sp
>> Arlington, Texas
>> are
>> off.
>> The
>> valve
>> > Help??!
>> > Stephen
>> > 81 FC-33SB
>> > Plant City, FL
> Yahoo! Groups Links
