Insulating the engine bay
02-14-2013, 17:00
RE: Insulating the engine bay
I'll measure mine tonight, if nobody else pops in to give us the answer.
02-14-2013, 17:07
Give it some time, cause I know Peter Haggins redid his genny insulation.
david brady, '02 LXi, NC |
02-14-2013, 23:55
Mine is 40"D x 26"H x 30"W. There's a 30"W x 26"H panel across the back and a small amount around the front enclosure. So each wall is about 7.25 sqft, while the ceiling is about 6 sqft and the back wall is closer to 5.5 sqft. So total, there's about 26 sqft. There's 8 sqft per panel, so I'd need probably 4 panels to do with. Might as well add 1 for safety, so call it 5 panels total. Does that sound right?
02-15-2013, 11:16
(This post was last modified: 02-15-2013 11:22 by davidbrady.)
(02-12-2013 14:04)pgchin Wrote: David B used some "killer" stuff ( sheets) that was pricey but worth it IMHO in the engine bay, may be he can remember the vendor as I can't! :-) Also that exhaust stacks in 95-97's are insulated on the "closet side" not the stack where your pipes run, if you add any , add it there by removing the closet walls..... much safer as later birds (380/450) have the stuff on the muffler side and when the glue deteriorates, it falls and catches fire! Plenty of examples of burned 380's stacks. Also if the exhaust system needs replacing consider stainless.....lower temps and I believe David has a vendor with the LXI parts already done, ship them you 95 stuff and John, BHTubes does supply stainless exhaust pipe sections for your coach. I worked with them many moons ago on both S60 equipped WB stainless exhaust pieces and the LXi stainless pieces. For the LXi they also supply stainless Charge Air Cooler and Coolant System pipes. http://www.bhtubes.com/shop/category.aspx?catid=171 And, don't forget the Brady muffler supplied by Pittsburgh Power. It's a straight thru design that takes the edge off the jake brake. Great free flow performance without the hassle of the law! http://www.pittsburghpower.com/ And, as usual I have NFI in any of these goodies. david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
02-15-2013, 11:32
(This post was last modified: 02-15-2013 11:34 by Arcticdude.)
I looked at Pittsburgh Power a while back, thinking about one of their Powerboxes. They're supposed to really wake up a 60. Papa Nealy (of bbq fame) has one on his coach and really raves about it. Is the Brady muffler listed on their site?
test John Mace 06 450LXi bigger bird living in the wild hinterlands of the north free to roam without the man getting me down |
02-15-2013, 11:37
(02-15-2013 11:32)Arcticdude Wrote: Is the Brady muffler listed on their site? Three years ago it was a custom build for me. I think it's part of their standard line up now. Here it is: http://www.pittsburghpower.com/product_i...f7f9f7e16b david brady, '02 Wanderlodge LXi 'Smokey' (Sold), '04 Prevost H3 Vantare 'SpongeBob' "I don't like being wrong, but I really hate being right" |
02-15-2013, 11:40
Great!! Thanks!!
03-10-2013, 23:13
So how many cans of 8090 have you guys used for the engine bay?
03-10-2013, 23:49
John, I think I bought a case of 6. I paid $14.45 per can.
03-15-2013, 07:13
I am in the middle of redoing the insulation in my engine bay and I can tell you its a swine of a project. If you don't get the surface nice and clean first, free of the old gunk and glue/adhesive, it can make attaching the new stuff quite a bear. I'm now in the process of stripping all that gunk off and trying to get to a fairly cleaning base before I go further. I attached 3 pieces, two of which held well, one which did not. Hopefully the surface cleanliness is the problem, will know soon.
