auxilliary air compressor maintenance
02-04-2006, 03:02
Ours runs about twice a day when we are parked. At the same time, I
note that the air toilet compressor is also running, and I think that
the two compressors are connected. (I had the latter replaced about 2
yrs. ago.) The tank or compressor expels air for 50 to 60 cycles before
it finally stabilizes, fills, and shuts off. I think I have to drain
the water out but don't know where the drain is. Anyone??
Thanks
Ron & Ruth in 2000 lxi
02-04-2006, 06:13
Ron & Ruth - I have been told by truckers that the Detroit 60Series is very
fuel efficient. Have you found that so?
Jerry
Looking
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of luckyron1
Sent: Saturday, February 04, 2006 9:02 AM
Subject: [WanderlodgeForum] auxilliary air compressor maintenance
Thanks
SPONSORED LINKS
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v
ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU
kCKkU7Dzhn_ObWmSYTw> vehicles
Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2
=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use
d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP
j9U0JvqYQ>
Automotive
<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de
aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF
4u_5wI8Pmy34cC1O9CxA> maintenance
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati
onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic
le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s
ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer
Used
<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio
nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl
e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si
g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles
Automotive
<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve
hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV
MmISsCWgTnMq_4GlXA> radiators
_____
YAHOO! GROUPS LINKS
* Visit your group "WanderlodgeForum
<http://groups.yahoo.com/group/WanderlodgeForum> " on the web.
* To unsubscribe from this group, send an email to:
_____
02-04-2006, 10:56
Jerry,
I'm not Ron & Ruth - but I had the series 60 in our Wanderlodge. The
best I ever saw was 6 mpg and that was after modifications. It usually
ran between 5 & 6 mpg. According to the Detroit guru's I have talked
to, the World transmission just doesn't have enough gears to get best
fuel economy. The best rpm for the series is 1400. To get that, you are
limited to 55 mph. At 65 mph, you are turning 1600 rpm. If we had a
fifteen speed like the truckers do, we could keep the engine at the 1400
rpm and get the best efficiency.
George Lowry
'06 Alpine Apex - Former owner of '95 WBDA 4203
Spearfish, SD enjoying the warmth in Palm Springs...
>Jerry
>Looking
> _____
>From: WanderlodgeForum@yahoogroups.com
>Thanks
>SPONSORED LINKS
>Recreational
>Wanderlodge
>j9U0JvqYQ>
>Automotive
>Recreational
>Used
>Automotive
> _____
>YAHOO! GROUPS LINKS
> _____
>Yahoo! Groups Links
02-04-2006, 11:17
Hi Ron,
> the same time, I
> and I think that
The 110V compressor and the 12V compressor were not
originally connected to one another by BB. However,
many owners, including me, have had them replumbed so
they both feed all air requirements and had the
pressure regulators set so the 110v kicks in at a
slightly lower air pressure than the 12V so the 110V
effectively becomes the "master compressor," after the
engine compressor. Plumbed in this manner, in the
event 110V is not present (and the 110V is not usually
connected to the inverter), the 12V will then come on
and drive the toilet and the slide air seals.
> (I had the
> to 60 cycles before
Reach into the area where the 110V compressor is
buried behind wooden panels covered with felt, or
unscrew the panels, and feel for a 3/8" relatively
"loose" plastic air tubing line. At its far end is a
connector with the ability to open and drain the tank
of accumulated water. Gently pull the tubing out from
the opening and you will note the tube length is just
long enough to reach outside the bin area. Stand back
when you open the pet-cock as, if it hasn't been
regularly drained, it may spew lots of gunk.
Good luck,
John Suter
2000LXi
> Anyone??
> Thanks
Do You Yahoo!?
http://mail.yahoo.com
02-06-2006, 06:14
Hi John,
I could find only one drain line with a petcock on it.
It comes from the bottom of the air tank, which is
mounted above and between the 12 volt and 110 volt
compressors, and runs down and through the floor. It
won't pull out of the floor so I assume it drains
beneath the coach. I opened it, the 12 volt
compressor came on and I heard the sound of air
expelling from the tank. I looked beneath the coach
and I couldn't see any water spray or hear any air
noise. I left the valve petcock open for about a
minute and then closed it. The 12 volt compressor ran
for another few minutes and then shut down. Last nite
the 110 volt compressor came on and made that air
sputtering sound that compressors make over a hundred
times before 'closing', and then ran another minute or
so before shutting down. I must be missing something
here. Any ideas? Thanks.
Ron & Ruth in 2000 Lxi
--- John Suter wrote:
> Hi Ron,
> At
> > the same time, I
> running,
> > and I think that
> not
> so
> the
> usually
> on
> > (I had the
> 50
> > to 60 cycles before
> a
> tank
> from
> just
> back
> Good luck,
> John Suter
> 2000LXi
> > Anyone??
> > Thanks
> Do You Yahoo!?
> protection around
02-06-2006, 08:17
Hi again Ron,
--- R J wrote:
> Hi John,
> it.
I've not seen one mounted in that fashion, and I'd
prefer to be able to "see" the output; however, the
point is you found it. Add a reminder to drain, to
your monthly maintenance checklist, especially if you
live in an area of humidity. The 12Volt compressor
does not have a tank to drain, and the engine air
compressor has a built-in air dryer which dryer
cartridge should be changed every few years.
> It
> ran
For the 12V to come on when the 110V tank is drained
must mean they are plumbed together. However, for the
12v to come on before the 110V must also mean their
pressure regulators must be set in the reverse of what
I would desire.
> Last nite
> hundred
> or
> something
For what it's worth, my 110V will operate about 1
minute, "sputter" a couple of times, then shut down
and will cycle in that manner about every 3-4 hours.
The 12V compressors are notorious for wearing out
their teflon-like, piston seal, and perhaps that is
what is causing the prolonged operation you describe.
Unfortunately, you cannot repair the 5 cent seal and
must purchase a new $150 complete pump, if it fails.
I became "pi##ed" (upset) at the seal problem and
found a manufacturer who would produce the seals to
order - however the minimum order was about 1 million
seals for about $1,000 - not much help. A solution is
to perform the replumb I mentioned previously, and to
add a 12V switch to the 12V compressor pump to
conserve/preserve their life. I note that some BB's
have the switch factory installed and some do not.
Regards,
John Suter
> > Hi Ron,
> > At
> > > the same time, I
> > running,
> > > and I think that
> > not
> However,
> > so
> 110V
> > the
> > usually
> > on
> > > (I had the
> > 50
> > > to 60 cycles before
> is
> > a
> > tank
> > from
> > just
> > back
> > Good luck,
> > John Suter
> > 2000LXi
> > > Anyone??
> > > Thanks
> > Do You Yahoo!?
> > protection around
Do You Yahoo!?
02-06-2006, 09:03
Thanks again John, I'm just not a mechanical guy and
I'm still confused.
> > It
Actually, when I tried it again, the 110 volt
compressor came on 1st and then a minute or so later
the 12 volt one kicked in. I don't have a clue how
they might be plumbed but the 12 volt one seems to
work independent of the 110 volt one. Like you, I
just had the 12 volt compressor replaced a couple of
years ago and to me, it seems to be performing
perfectly since then.... although now that you
mention it, I notice that it occassionaly comes on
spontaneously for 20 seconds our so. To give you an
idea, when new, it ran about 40 seconds after a flush
and then shut down and that hasn't changed since I had
it put in. To further confuse, I'm suprized to hear
that your 110 volt cycles every 3 to 4 hours because
ours doesn't seem to cycle more than 2 to 3 times per
day.
> drained
> the
> what
> I would desire.
> describe.
> million
> is
> to
> Regards,
> John Suter
I don't understand why the 12 volt compressor is even
necessary what with the engines compressor, the 110
volt auxilliary compressor, the inverters and
generator. Maybe a shut off switch on the 12 volt is
the way to go. Just save it for when all else fails?
Your further thoughts and advice appreciated.
ron & ruth
02-06-2006, 10:20
Ron,
Sorry you are still confused and hope I haven't
added to it.
> I'm still confused.
Great! That is the manner in which I believe it
should work.
> flush
> had
> per
> day.
My guess is I should look for some leaks and fix
'em. That will be the next project.
> even
> generator.
Typically, the 110V compressor is not on the
inverter so you need the 12V compressor whenever you
are not connected to shore power or the generator is
not running.
> is
> fails?
When our 2000 was new, BB replaced the 12V 4 or 5
times under warranty. I thought there has to be a
better way, especially when it became my nickel. The
switch was simple, cheap, and I haven't replaced a 12V
pump since.
Glad to try and help. I think you have it.
John
Do You Yahoo!?
02-07-2006, 07:26
Hey John,
As it turned out, the aux comp stopped running yesterday. We are
hooked up to shorepower, the slide is out, and the 12 volt
compressor is functioning normally when the toilet flushes; and a
little extra from time to time during the day for the other non-
engine related air-acuated devices. I have a new Gast Compressor
(same model) on the way to us and will probably have it by the
middle of next week; will have it installed by a local RV Tech. In
the interim I want to make sure we don't burn out the 12 volt
compressor. I'm thinking that to be on the safe side that we should
probably put the slide in?; turn off the aux comp breaker; open both
the gray and black water valves; cease using the stair-well
cover....
In the mean time I have overcome some of my early alzheimers and
recalled that my air toilet wouldn't work when my 12 volt died about
2 yrs. ago, so it would follow that the 2 compressors weren't
plumbed together as some birders have had done. I'm wondering how
to do it or have it done. Do you have a diagram or something?
Your thoughts appreciated
. --- In WanderlodgeForum@yahoogroups.com, John Suter
> Ron,
> added to it.
> > I'm still confused.
> should work.
> > flush
> > had
> > per
> > day.
> > even
> > generator.
> not running.
> > is
> > fails?
> pump since.
> John
> Do You Yahoo!?
02-07-2006, 12:10
Oh, I'm sorry, Ron, to hear your 110V compressor bit
the dust.
> Hey John,
> yesterday. We are
> 12 volt
> flushes; and a
> the other non-
> Gast Compressor
> it by the
> local RV Tech. In
> the 12 volt
> compressor.
I take it you do not have a switch currently
installed for the 12V compressor. You can purchase
any brand of single pole, on/off switch, rated at 12
volts or more, and 15 amps or more, from NAPA or Radio
Shack. Personally, I would choose one with "screw
type" terminals, to make the electrical connections
easy on yourself.
Although the switch doesn't need a "through metal"
mounting location or bracket, if one is readily
available I'd use it and purchase the type switch that
will protrude thru it. If not, the switch can simply
become an "in line" type, lying loose. Simply cut one
of the two wires running to the 12V compressor at
least 2 or more inches from the motor, strip
approximately 1/2 inch of insulation from each of the
newly cut ends, and attach each end to one of the
switch screw terminals. If you create the "lying
loose" model, tape everything securely with electrical
tape, leaving the throw free to move.
> side that we should
The slide is hydraulically driven and the seals can
be inflated by starting the engine, so no need to
worry either way.
> breaker;
I would turn off the dash switch and the breaker as
you do not know what caused the electrical failure of
the 110V motor. A high resistance problem could
continue to feed 110V to the motor and, although a
small probability of heat/fire, why take any chance.
> open both
> stair-well
> cover....
No need again, as the engine air compressor can be
used to provide any air necessary by simply starting
the engine and letting the air build.
> alzheimers and
> volt died about
> compressors weren't
> wondering how
> something?
I wouldn't want to give detailed advice via the net
without seeing exactly what you have now. (BB seldom
seems to create more than one the same LOL).
Shouldn't be that costly to have knowledgeable shop
re-plumb the system for you. I'd estimate 1/2 hour or
so to determine what you now have, and another 1/2 to
1 hour to join all together plus whatever
adjustments/modifications to pressure regulators are
necessary to get all to work peacefully with one
another. Remember to advise, you are trying to
connect engine air, 110V air and 12V air so all work
every air device.
Hope this helps more than confuses.
John Suter
Do You Yahoo!?
