					estimated cost for repairs
					12-12-2005, 13:01
					Ernie-83pt40 in Texas- all prepped for coach surgery
			Hey Ernie, Does the new Medicare or drug program cover the sugery?? Bill --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > > Ralph can do an inspection. the rear bath is larger then on the side bath > coaches. The only drawback- you have twin beds- which isn't all that bad. > Ernie-83pt40 in Texas- all prepped for coach surgery Tuesday > > > [Non-text portions of this message have been removed] >  |
					12-12-2005, 13:03
					A rear bath doesn't seem like a good family coach set-up; having the
			kids walk through the bedroom to go to the bathroom would get old pretty quickly especially in the middle of the night. Of course, with the twin beds, they probably wouldn't be interrupting anything. :>) Good luck, Tim Hannink Winter Park, FL 1981 FC-33SB w/rear twins :>( --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > > Ralph can do an inspection. the rear bath is larger then on the side bath > coaches. The only drawback- you have twin beds- which isn't all that bad. > Ernie-83pt40 in Texas- all prepped for coach surgery Tuesday > > > [Non-text portions of this message have been removed] >  |
					12-12-2005, 13:09
			> > Hi Mike: > > The '85 FC is a good coach. > > Need to check the power to the master switch for the HWH jacks. That switch > enables the solenoid that is located to the front of the entry step under > the coach. > > There are fuses (or at least there was in my '85FC) for the drive line > retarder located in the main control box located just above the retarder > proper. Also need to check the power from the retarder switch. Seems like > both power enables to those switches go through "C" plug under the dash > then on to the cb's and conversely to the enable solenoids. Those cb's are > located behind the drivers front head light. > > Power steering pump I had rebuilt, not sure but in the neighborhood of > 95.00. Ah, also check the bolts to the steering box and tighten them, bet a > nickle they are lose as well. > > The ac covers, depends on what brand,, probably Brisk airs. Some are still > available. > > I had some of those ok to drive local tires, then promptly had 2 blow outs. > Tires are expensive but in the long run, cheap insurance, because these > tires can take out wheel wells. > > Good luck with her. If I can help let me know. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 10:25 PM 12/12/2005 +0000, you wrote: > >Hi all- > >I am looking at a 85 FC '35 that looks to be in good shape but needs > >the following repairs/maintenance. I would like to know what it would > >cost for the following so I can figure it into the price. > > > >It has a recent oil change/lube and oil analysis > >which showed normal. The tires are 5-6 years old and should be > >replaced before a trip but are ok to drive local. The oil needs to be > >changed in the front wheel bearings. The refrigerator and head have > >already been replaced with newer models. The retarder is not working > >and the leveling system is not working but both can be fixed. Two > >roof ac's need covers. Power steering pump has a leak. > > > > > >Thanks > >Mike > > > > > > > > > > > > > Ralph- Can you call me this week when you get 10 minutes that we can talk? I will send you an email with my number thanks  |
					12-12-2005, 14:57
					--- In WanderlodgeForum@yahoogroups.com, "cobraheat1"
			<mike.meister@i...> wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hi Mike: > > > > The '85 FC is a good coach. > > > > Need to check the power to the master switch for the HWH jacks. > That switch > > enables the solenoid that is located to the front of the entry > step under > > the coach. > > > > There are fuses (or at least there was in my '85FC) for the drive > line > > retarder located in the main control box located just above the > retarder > > proper. Also need to check the power from the retarder switch. > Seems like > > both power enables to those switches go through "C" plug under the > dash > > then on to the cb's and conversely to the enable solenoids. Those > cb's are > > located behind the drivers front head light. > > > > Power steering pump I had rebuilt, not sure but in the > neighborhood of > > 95.00. Ah, also check the bolts to the steering box and tighten > them, bet a > > nickle they are lose as well. > > > > The ac covers, depends on what brand,, probably Brisk airs. Some > are still > > available. > > > > I had some of those ok to drive local tires, then promptly had 2 > blow outs. > > Tires are expensive but in the long run, cheap insurance, because > these > > tires can take out wheel wells. > > > > Good luck with her. If I can help let me know. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 10:25 PM 12/12/2005 +0000, you wrote: > > >Hi all- > > >I am looking at a 85 FC '35 that looks to be in good shape but > needs > > >the following repairs/maintenance. I would like to know what it > would > > >cost for the following so I can figure it into the price. > > > > > >It has a recent oil change/lube and oil analysis > > >which showed normal. The tires are 5-6 years old and should be > > >replaced before a trip but are ok to drive local. The oil needs > to be > > >changed in the front wheel bearings. The refrigerator and head > have > > >already been replaced with newer models. The retarder is not > working > > >and the leveling system is not working but both can be fixed. Two > > >roof ac's need covers. Power steering pump has a leak. > > > > > > > > >Thanks > > >Mike > > > > > > > > > > > > > > > > > > > > > Ralph- > Can you call me this week when you get 10 minutes that we can talk? > I will send you an email with my number > thanks Mick is this the unit your looking at?:http://www.cacars.com/used- rvs/113437.htm- This really looks like a nice old bird- Jon Jon Lechich 1978 Wanderlodge Bremerton Washington >  |
					12-12-2005, 19:20
					In a message dated 12/12/2005 7:08:58 PM Central Standard Time,
			billpatty@... writes: > Does the new Medicare or drug program cover the sugery?? Bill- I didn't sign up for that, yet. Might have to postpone surgery since you brought that up. Thanks- Ernie [Non-text portions of this message have been removed]  |
					12-13-2005, 02:26
					Welcome to the ownership group, Mike (hopefully!)
			I can't say all air conditioning shrouds/covers are created equal; however, the unpainted ones from Bluebird for my 2000LXi were $106.98 each, delivered Florida, in late 2004 and I know there has been a substantial factory price increase on all parts since then. Perhaps a Forum member can assist you in finding another source, but let this pricing serve as your benchmark. John Suter --- cobraheat1 <mike.meister@...> wrote: > Hi all- > I am looking at a 85 FC '35 that looks to be in good > shape but needs > the following repairs/maintenance. I would like to > know what it would > cost for the following so I can figure it into the > price. > > It has a recent oil change/lube and oil analysis > which showed normal. The tires are 5-6 years old > and should be > replaced before a trip but are ok to drive local. > The oil needs to be > changed in the front wheel bearings. The > refrigerator and head have > already been replaced with newer models. The > retarder is not working > and the leveling system is not working but both can > be fixed. Two > roof ac's need covers. Power steering pump has a > leak. > > > Thanks > Mike > > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com  |
					12-13-2005, 09:30
			<mike.meister@i...> wrote: > I have a rear bath and LOVE IT. It is the largest RV bathroom I have ever seen, and by not having the side bath up in the living area, the lounge/kitchen area feels much more open and spacious. When I was looking for my coach, I was actually biased against RB models and would not pay attention to them when I came across them. Now, after having one, I would be reluctant to get another coach without it. It is one of the major reasons I do not upgrade to a PT. Scott Forman 82 FC35RB Memphis > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hi Mike: > > > > The '85 FC is a good coach. > > > > Need to check the power to the master switch for the HWH jacks. > That switch > > enables the solenoid that is located to the front of the entry > step under > > the coach. > > > > There are fuses (or at least there was in my '85FC) for the drive > line > > retarder located in the main control box located just above the > retarder > > proper. Also need to check the power from the retarder switch. > Seems like > > both power enables to those switches go through "C" plug under the > dash > > then on to the cb's and conversely to the enable solenoids. Those > cb's are > > located behind the drivers front head light. > > > > Power steering pump I had rebuilt, not sure but in the > neighborhood of > > 95.00. Ah, also check the bolts to the steering box and tighten > them, bet a > > nickle they are lose as well. > > > > The ac covers, depends on what brand,, probably Brisk airs. Some > are still > > available. > > > > I had some of those ok to drive local tires, then promptly had 2 > blow outs. > > Tires are expensive but in the long run, cheap insurance, because > these > > tires can take out wheel wells. > > > > Good luck with her. If I can help let me know. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 10:25 PM 12/12/2005 +0000, you wrote: > > >Hi all- > > >I am looking at a 85 FC '35 that looks to be in good shape but > needs > > >the following repairs/maintenance. I would like to know what it > would > > >cost for the following so I can figure it into the price. > > > > > >It has a recent oil change/lube and oil analysis > > >which showed normal. The tires are 5-6 years old and should be > > >replaced before a trip but are ok to drive local. The oil needs > to be > > >changed in the front wheel bearings. The refrigerator and head > have > > >already been replaced with newer models. The retarder is not > working > > >and the leveling system is not working but both can be fixed. Two > > >roof ac's need covers. Power steering pump has a leak. > > > > > > > > >Thanks > > >Mike > > > > > > > > > > > > > > > > > > > > > Thanks everyone. (I don't know anything about these things) > > Looks like it is safe to assume 5k in after purchase > tires/maintenance. > > 1. Who does inspections in the midwest? > > 2. It also it has rear bath. Is that a positive/negative or moot > point? >  |
					12-13-2005, 10:34
					Like you Scott, I have a Rear Bath and absolutely love the spaciousness it
			affords. Plus the open feeling when in the Salon area. The 35 foot is a nice size to maneuver too. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - Wanderlodge Owners Online http://www.wanderlodge.us 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 13, 2005 4:30 PM Subject: [WanderlodgeForum] Re: estimated cost for repairs --- In WanderlodgeForum@yahoogroups.com, "cobraheat1" <mike.meister@i...> wrote: > I have a rear bath and LOVE IT. It is the largest RV bathroom I have ever seen, and by not having the side bath up in the living area, the lounge/kitchen area feels much more open and spacious. When I was looking for my coach, I was actually biased against RB models and would not pay attention to them when I came across them. Now, after having one, I would be reluctant to get another coach without it. It is one of the major reasons I do not upgrade to a PT. Scott Forman 82 FC35RB Memphis > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hi Mike: > > > > The '85 FC is a good coach. > > > > Need to check the power to the master switch for the HWH jacks. > That switch > > enables the solenoid that is located to the front of the entry > step under > > the coach. > > > > There are fuses (or at least there was in my '85FC) for the drive > line > > retarder located in the main control box located just above the > retarder > > proper. Also need to check the power from the retarder switch. > Seems like > > both power enables to those switches go through "C" plug under the > dash > > then on to the cb's and conversely to the enable solenoids. Those > cb's are > > located behind the drivers front head light. > > > > Power steering pump I had rebuilt, not sure but in the > neighborhood of > > 95.00. Ah, also check the bolts to the steering box and tighten > them, bet a > > nickle they are lose as well. > > > > The ac covers, depends on what brand,, probably Brisk airs. Some > are still > > available. > > > > I had some of those ok to drive local tires, then promptly had 2 > blow outs. > > Tires are expensive but in the long run, cheap insurance, because > these > > tires can take out wheel wells. > > > > Good luck with her. If I can help let me know. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 10:25 PM 12/12/2005 +0000, you wrote: > > >Hi all- > > >I am looking at a 85 FC '35 that looks to be in good shape but > needs > > >the following repairs/maintenance. I would like to know what it > would > > >cost for the following so I can figure it into the price. > > > > > >It has a recent oil change/lube and oil analysis > > >which showed normal. The tires are 5-6 years old and should be > > >replaced before a trip but are ok to drive local. The oil needs > to be > > >changed in the front wheel bearings. The refrigerator and head > have > > >already been replaced with newer models. The retarder is not > working > > >and the leveling system is not working but both can be fixed. Two > > >roof ac's need covers. Power steering pump has a leak. > > > > > > > > >Thanks > > >Mike > > > > > > > > > > > > > > > > > > > > > Thanks everyone. (I don't know anything about these things) > > Looks like it is safe to assume 5k in after purchase > tires/maintenance. > > 1. Who does inspections in the midwest? > > 2. It also it has rear bath. Is that a positive/negative or moot > point? > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed]  |
					12-13-2005, 13:37
					well i love the rear bath in my bus but
			i need to sleep by my boss and am looking for a way to put a bigger bed in 1 side.. has anybody done a folding type bed in a twin fc or have any ideas? thanks Woody 81 fc rb in cold NC  |
					12-13-2005, 13:58
					I can see it now a murphy bed screwed to the wall, that way you don't
			need to make the bed, you just fold it up and your done, but then you couldn't hide stuff under the bed anymore ![]() the other "Bruce Campbell" --- In WanderlodgeForum@yahoogroups.com, "rwoodysurplus" > > well i love the rear bath in my bus but > > i need to sleep by my boss and am looking for a way to put a bigger > bed in 1 side.. > > has anybody done a folding type bed in a twin fc or have any ideas? > > thanks > > Woody 81 fc rb in cold NC >  |
