Would This Work
09-15-2005, 16:14
Would This Work
I have a set of 18 volt battery powered tools. Can I use this, or a
smaller 12 volt battery to test different circuits? What I am thinking of, is connecting jumper wires to the wires at the circuit breaker (TV antenna for example) and connecting/touching the other ends to the 18 volt battery terminals. This way I could determine if the problem was before or after the breaker. Is my thinking flawed? Would using 18 volts damage anything? Steve Harrie Trying to Save a Few Steps |
09-16-2005, 01:52
Would This Work
smaller 12 volt battery to test different circuits? OK, thanks to those who contacted me off line. I wont use an 18 volt battery to test anything. The reason it ran across my mind, is on my old Dutch Star I had automatic awnings. At one time I couldn't get them to roll up. Care Free told me to use my 18 volt battery to give it more oomph, and I was able to close it. Thanks again for preventing a meltdown. Steve Harrie |
09-16-2005, 12:34
Would This Work
Steve,
Send me an email & I'll give you my phone no. If you still need help you can call & I'll help you trouble shoot nthe electrical on your antenna. Scott Williams SOB ======== --- In WanderlodgeForum@yahoogroups.com, "trvlngnrs" wrote: > I have a set of 18 volt battery powered tools. Can I use this, or a > smaller 12 volt battery to test different circuits? What I am thinking > of, is connecting jumper wires to the wires at the circuit breaker (TV > antenna for example) and connecting/touching the other ends to the 18 > volt battery terminals. This way I could determine if the problem was > before or after the breaker. > > Is my thinking flawed? > Would using 18 volts damage anything? > > Steve Harrie > Trying to Save a Few Steps |
