Towing insurance
06-09-2005, 02:06
Towing insurance
I was wondering what the members believe is the best insurance for
towing and tire changes. Thanks Jim Hutchings 1983 FCRB Yorba Linda, CA |
06-09-2005, 02:38
Towing insurance
The best is the one that is recommended by FMCA, Coach Net. It is
also the one that most of the major manufacturers use. Not only do they provide service, they have technicians that can many times diagnose your problem and get you back on the road faster. They also make certain that the facility they are towing you to can and will be able to repair your coach. Others will just tow you to the closest repair facility and you don't know if they can fix your problem until after you are there. (877-801-0333) or http://www.coach-net.com George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD bluebird3208 wrote: > I was wondering what the members believe is the best insurance for > towing and tire changes. > > Thanks > > Jim Hutchings > 1983 FCRB > Yorba Linda, CA > > > > > > > Yahoo! Groups Links > > > > > > > > > > |
06-09-2005, 02:55
Towing insurance
Jim,
Coach Net was the best in my research. 877-801-0333 http://www.coach-net.com Curt Sprenger â87PT38, Anaheim, Calif. |
12-05-2018, 17:59
RE: Towing insurance
Hi
We currently have AAA RV road protection insurance. My wife wanted me to look into Good Sam Roadside Assistance. Does anyone have any suggestions - Good or Bad Thanks Urnie In the past we had a 1983 FC35 for many years. We now have a 2001 LXi Not sure how to add this to my questions. Urnie & Medie Krueger Yorkville, IL 2001 LXi One Slide 1983 FC35 sold |
12-07-2018, 10:49
Strong promotion of Coach Net over Good Sam. Having been towed by both.
Communication with Good Sam was difficult, requiring many calls going through repetition of numbers and events. Sent a small truck and then required that we spend the night AT a Flying J fuel pump. Coach net, one call..they called back and then again to confirm that service had arrived. Ross Ross MacKillop Wiarton Ontario 2006 450 Lxi |
12-07-2018, 11:37
Have had similar situations as Ross. Years ago(last century), they were great, but have changed owners and went downhill. Coachnet is sooo much better, at least it was the last time I used them. I have been towed at least 4 times in the last 20 years and have found out, that you have to your do diligence, give them full specifics on your coach. Tell them weight, length, and type(bus). The person on the other end of the line knows nothing of RV's. Then make repeat back to you, what you just told them. Plus, you want a landall if at all possible.
