Refrigerator help needed.
08-09-2005, 15:27
The refrigerator is not cooling when operating on gas. It works fine
when hooked up to electricity. I pulled the burner out and cleaned it, reinstalled. I also removed the vent cover on the roof to verify there was no blockage. I also brushed the fins while the roof cover was off. I have the wind shield off and the flame is all blue and looks to be burning the full length of the flame tube. The refrigerator is a Dometic RM1300. How long should it take to begin cooling? Are there other things to check? There is also a fan behind the refrigerator and when I turn the fan on at the galley panel should the fan be spinning or is thermostatically controlled? Troy, Waconia MN 1983 FC33 |
08-09-2005, 16:47
Hi Troy:
It is time to clean the flue tube of rust and soot and also clean the baffle that hangs in the flue tube. Open the anti flame blow out cap on top of the flue tube. You will see a bent wire hanging on the inside of the tube, pull the baffle out taking care not to disturb the bend in the wire and wire brush the baffle. Then you need a flue tube brush to clean the tube with. Sort of like running a brush down the barrel of a rifle to clean it. The baffle makes the rising heat swirl to evenly distribute the heat in the proper proportions and the built up scale inside the tube prevents the heat from causing the ammonia/water to boil at the proper temp causing the super heated gas to rise to the evaporator and the water to separate and flow back to the chamber. It heats on electric because the heat transfer is to the out side of the flue tube causing the above reaction. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 03:27 AM 8/10/2005 +0000, you wrote: >The refrigerator is not cooling when operating on gas. It works fine >when hooked up to electricity. I pulled the burner out and cleaned >it, reinstalled. I also removed the vent cover on the roof to verify >there was no blockage. I also brushed the fins while the roof cover >was off. I have the wind shield off and the flame is all blue and >looks to be burning the full length of the flame tube. The >refrigerator is a Dometic RM1300. How long should it take to begin >cooling? Are there other things to check? There is also a fan behind >the refrigerator and when I turn the fan on at the galley panel should >the fan be spinning or is thermostatically controlled? > >Troy, Waconia MN >1983 FC33 |
08-11-2005, 02:13
That worked! Thanks Ralph.
How about the refrigerator cooling fan, mounted behind the fridge. Is the fan thermostatically controlled? Troy, Waconia MN 1983 FC33 --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > Hi Troy: > > It is time to clean the flue tube of rust and soot and also clean the > baffle that hangs in the flue tube. > Open the anti flame blow out cap on top of the flue tube. You will see a > bent wire hanging on the inside of the tube, pull the baffle out taking > care not to disturb the bend in the wire and wire brush the baffle. Then > you need a flue tube brush to clean the tube with. Sort of like running a > brush down the barrel of a rifle to clean it. > The baffle makes the rising heat swirl to evenly distribute the heat in the > proper proportions and the built up scale inside the tube prevents the heat > from causing the ammonia/water to boil at the proper temp causing the super > heated gas to rise to the evaporator and the water to separate and flow > back to the chamber. > > It heats on electric because the heat transfer is to the out side of the > flue tube causing the above reaction. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > > > At 03:27 AM 8/10/2005 +0000, you wrote: > >The refrigerator is not cooling when operating on gas. It works fine > >when hooked up to electricity. I pulled the burner out and cleaned > >it, reinstalled. I also removed the vent cover on the roof to verify > >there was no blockage. I also brushed the fins while the roof cover > >was off. I have the wind shield off and the flame is all blue and > >looks to be burning the full length of the flame tube. The > >refrigerator is a Dometic RM1300. How long should it take to begin > >cooling? Are there other things to check? There is also a fan behind > >the refrigerator and when I turn the fan on at the galley panel should > >the fan be spinning or is thermostatically controlled? > > > >Troy, Waconia MN > >1983 FC33 |
08-11-2005, 03:14
With the frig. full of food, the setting all the way cold, and operating
for more than a day, what should the temperature be inside the frig? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. ttikalsky wrote: > That worked! Thanks Ralph. > > How about the refrigerator cooling fan, mounted behind the fridge. Is > the fan thermostatically controlled? > > > Troy, Waconia MN > 1983 FC33 > > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > Hi Troy: > > > > It is time to clean the flue tube of rust and soot and also clean > the > > baffle that hangs in the flue tube. > > Open the anti flame blow out cap on top of the flue tube. You will > see a > > bent wire hanging on the inside of the tube, pull the baffle out > taking > > care not to disturb the bend in the wire and wire brush the baffle. > Then > > you need a flue tube brush to clean the tube with. Sort of like > running a > > brush down the barrel of a rifle to clean it. > > The baffle makes the rising heat swirl to evenly distribute the heat > in the > > proper proportions and the built up scale inside the tube prevents > the heat > > from causing the ammonia/water to boil at the proper temp causing > the super > > heated gas to rise to the evaporator and the water to separate and > flow > > back to the chamber. > > > > It heats on electric because the heat transfer is to the out side of > the > > flue tube causing the above reaction. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > > > > > At 03:27 AM 8/10/2005 +0000, you wrote: > > >The refrigerator is not cooling when operating on gas. It works > fine > > >when hooked up to electricity. I pulled the burner out and cleaned > > >it, reinstalled. I also removed the vent cover on the roof to > verify > > >there was no blockage. I also brushed the fins while the roof > cover > > >was off. I have the wind shield off and the flame is all blue and > > >looks to be burning the full length of the flame tube. The > > >refrigerator is a Dometic RM1300. How long should it take to begin > > >cooling? Are there other things to check? There is also a fan > behind > > >the refrigerator and when I turn the fan on at the galley panel > should > > >the fan be spinning or is thermostatically controlled? > > > > > >Troy, Waconia MN > > >1983 FC33 > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
08-11-2005, 03:43
Curt,
This is just a guess, But I think it should be about 40 degrees, Until the outside ambient temp reaches over 80/85. The amonia frig can only reduce the temp about 40 to 50 degrees. It may not be as efficient at 90/95 outside degrees. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > With the frig. full of food, the setting all the way cold, and operating > for more than a day, what should the temperature be inside the frig? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > ttikalsky wrote: > > > That worked! Thanks Ralph. > > > > How about the refrigerator cooling fan, mounted behind the fridge. Is > > the fan thermostatically controlled? > > > > > > Troy, Waconia MN > > 1983 FC33 > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Hi Troy: > > > > > > It is time to clean the flue tube of rust and soot and also clean > > the > > > baffle that hangs in the flue tube. > > > Open the anti flame blow out cap on top of the flue tube. You will > > see a > > > bent wire hanging on the inside of the tube, pull the baffle out > > taking > > > care not to disturb the bend in the wire and wire brush the baffle. > > Then > > > you need a flue tube brush to clean the tube with. Sort of like > > running a > > > brush down the barrel of a rifle to clean it. > > > The baffle makes the rising heat swirl to evenly distribute the heat > > in the > > > proper proportions and the built up scale inside the tube prevents > > the heat > > > from causing the ammonia/water to boil at the proper temp causing > > the super > > > heated gas to rise to the evaporator and the water to separate and > > flow > > > back to the chamber. > > > > > > It heats on electric because the heat transfer is to the out side of > > the > > > flue tube causing the above reaction. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > Ralph's RV Solutions, Duncan, Oklahoma > > > http://home.swbell.net/rlf47/index.htm > > > > > > > > > > > > At 03:27 AM 8/10/2005 +0000, you wrote: > > > >The refrigerator is not cooling when operating on gas. It works > > fine > > > >when hooked up to electricity. I pulled the burner out and cleaned > > > >it, reinstalled. I also removed the vent cover on the roof to > > verify > > > >there was no blockage. I also brushed the fins while the roof > > cover > > > >was off. I have the wind shield off and the flame is all blue and > > > >looks to be burning the full length of the flame tube. The > > > >refrigerator is a Dometic RM1300. How long should it take to begin > > > >cooling? Are there other things to check? There is also a fan > > behind > > > >the refrigerator and when I turn the fan on at the galley panel > > should > > > >the fan be spinning or is thermostatically controlled? > > > > > > > >Troy, Waconia MN > > > >1983 FC33 > > > > > > > > > > ----------------------------------------------------------------- ------- > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ----------------------------------------------------------------- ------- > > |
08-11-2005, 03:57
Thanks Bill. Our frig. operates at 40 degrees in 80/85 degree weather.
Curt Sprenger 1987 PT38, Anaheim Hills, Calif. pattypape wrote: > Curt, > This is just a guess, But I think it should be about 40 degrees, > Until the outside ambient temp reaches over 80/85. The amonia frig > can only reduce the temp about 40 to 50 degrees. > It may not be as efficient at 90/95 outside degrees. > > Bill 88 FC > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > With the frig. full of food, the setting all the way cold, and > operating > > for more than a day, what should the temperature be inside the > frig? > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > |
08-11-2005, 07:21
Curt, when I was a Hospital Corpsman we used to have to check the refrigerator
temps and they had to be 41 degrees F or lower to meet food safety standards. So as long as they are below 41 degrees you should be OK. Bruce Morris (919)872-7635 Webmaster - Wanderlodge Owners Online 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv. > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > With the frig. full of food, the setting all the way cold, and > operating > > for more than a day, what should the temperature be inside the > frig? > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
08-11-2005, 09:30
Thanks Bruce. The thermometer in our frig. reads 40/41 degrees so I'm
going to be happy with that for now. It's s cheap thermometer so accuracy is questionable. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Bruce Morris wrote: > Curt, when I was a Hospital Corpsman we used to have to check the > refrigerator temps and they had to be 41 degrees F or lower to meet > food safety standards. > So as long as they are below 41 degrees you should be OK. > > Bruce Morris (919)872-7635 > Webmaster - Wanderlodge Owners Online > 1983 WL FC35RB > > FMCA: 7142s Ham Radio: KI4ME > Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv. > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > With the frig. full of food, the setting all the way cold, and > > operating > > > for more than a day, what should the temperature be inside the > > frig? > > > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive > maintenance > Recreational vehicle dealer Used recreational vehicles > Automotive radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wand...2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Auto...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used...onal+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Auto...ehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
08-11-2005, 12:28
Curt:
The freezer should be between 0F and 9F. The lower compartment should be between 34F and 39F. Remember to leave air gaps between food stuffs so air can circulate. Safe travels, Ralph Ralph's RV Solutions http://home.swbell.net/rlf47/index At 08:14 AM 8/11/2005 -0700, you wrote: >With the frig. full of food, the setting all the way cold, and operating >for more than a day, what should the temperature be inside the frig? > >Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > |
08-11-2005, 12:30
Good to hear, Troy. The fan should have a thermostat on it inline should
come on about 95F or so, that is give or take. Safe travels, Ralph At 02:13 PM 8/11/2005 +0000, you wrote: >That worked! Thanks Ralph. > >How about the refrigerator cooling fan, mounted behind the fridge. Is >the fan thermostatically controlled? > > >Troy, Waconia MN >1983 FC33 > > > |
User(s) browsing this thread: 17 Guest(s)
