					fc tachometer
					07-24-2011, 05:32
				fc tachometer
					i have an 87 fc33 which needs a little attention
			the tach does not work and i dont have a swingout radiator does anyone know of an electronic replacement kit or some easier option to pulling the radiator(cable good so drive bad?) also my roof leaks also, as per previous post is there an accepted(correct) fix? thanks for all the forums contributors and there vast knowledge and willingness to share!!!!!!!! dana fransen 87 fc33 valley springs ca  |
					07-24-2011, 12:42
				fc tachometer
					Are you sure there is not a swing-out rad on your 87?  I though the swing-out
			became standard in 85. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "df0226" > > i have an 87 fc33 which needs a little attention > the tach does not work and i dont have a swingout radiator > does anyone know of an electronic replacement kit or some easier option to pulling the radiator(cable good so drive bad?) > > also my roof leaks also, as per previous post is there an accepted(correct) fix? > > thanks for all the forums contributors and there vast knowledge and willingness to share!!!!!!!! > > dana fransen > 87 fc33 valley springs ca >  |
					07-24-2011, 22:29
				fc tachometer
			> > i have an 87 fc33 which needs a little attention > the tach does not work and i dont have a swingout radiator > does anyone know of an electronic replacement kit or some easier option to pulling the radiator(cable good so drive bad?) > > also my roof leaks also, as per previous post is there an accepted(correct) fix? > > thanks for all the forums contributors and there vast knowledge and willingness to share!!!!!!!! > > dana fransen > 87 fc33 valley springs ca The tach sensor may be on the bell housing near & forward of the tranny, The Rad does indeed open , Just a little more difficult because of the air to air cooler. Loosen the top rad hose from inside the doghouse, remove grill drop the bumper, and remove the air cooler hose clamps, remove the driver side park light. a couple bolts behind the light.  |
