					Gen help needed!
					05-27-2011, 06:30
				Gen help needed!
					About to leave for the weekend in an hour. 4 hour ride ahead in 90 or so temps. Ran generator for about 4 hours yesterday no problem. Started it today before noon, left to walk the dog at 1, still running. Got back at 2, not running. Gas tank is full, oil in the gen is at proper level, coolant tank half full. The solenoid pulls out or releases when it shuts off, if you hold it, it keeps running. But even when you hold it to keep it running, no power whatsoever inside.
			Ideas? Markus 86 PT40  |
					05-27-2011, 06:36
				Gen help needed!
					Voltage regulator has gone out is what it sounds like or check the brushes
			Safe travels, Ralph Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T From:  Markus Meyer  Date: Fri, 27 May 2011 14:30:09 -0400 To:  Subject: [WanderlodgeForum] Gen help needed! Ideas? Markus 86 PT40  |
					05-27-2011, 06:48
				Gen help needed!
					To go along with that, check the rear bearing in the housing, then the slip rings,(use a mirror and flashlight) and the diode and fuse for the quadrature windings (55 and 65) on your schematic. Then check the diodes in the control box (3 of them) check the wiring on the AC relay (large one in the control box) and the contacts for burning. Un plug the oil and water sensor for the safety shut down to check if one or both sensors have gone out. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 06:36 PM 5/27/2011 +0000, you wrote: >Voltage regulator has gone out is what it sounds like or check the brushes > >Safe travels, Ralph & Charolette Fullenwider'84 FC35 "Ruff Diamond"Duncan, >OklahomaSent via BlackBerry by AT&T >From: Markus Meyer >Sender: WanderlodgeForum@yahoogroups.com >Date: Fri, 27 May 2011 14:30:09 -0400 >To: >ReplyTo: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Gen help needed! >About to leave for the weekend in an hour. 4 hour ride ahead in 90 or so >temps. Ran generator for about 4 hours yesterday no problem. Started it >today before noon, left to walk the dog at 1, still running. Got back at >2, not running. Gas tank is full, oil in the gen is at proper level, >coolant tank half full. The solenoid pulls out or releases when it shuts >off, if you hold it, it keeps running. But even when you hold it to keep >it running, no power whatsoever inside. > >Ideas? > >Markus >86 PT40 > > > >14d7427.jpg  |
					07-05-2011, 13:06
				Gen help needed!
