					Jack stands...for Wanderlodge's
					05-14-2011, 05:07
					To anyone who can answer this,
			What size jack stand is recommended for the 1995 Wanderlodge Wide body 42'. I know that the weight unloaded is about 48,000 lbs. Would a 12 ton jack stand be adequate or should it be a 22 ton? Ron Thompson 1995 WLWB 42' cockyfox@...  |
					05-14-2011, 06:06
				 Ron
I feel 20 ton or better is safest.
as I recall the price difference isnââ¬â¢t much
Fred & Jeanne Hulse Morristown,Arizona 97 WLWB41  |
					05-14-2011, 06:12
					An old saying to err on the high side will work on the low side too. I agree
			with Fred, get the 20 ton stands and be safe. Most of us have purchased 20 ton bottle jacks when some one finds a sale, just as a point of reference. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "Ron Thompson" Sender: WanderlodgeForum@yahoogroups.com Date: Sat, 14 May 2011 17:07:27 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Jack stands...for Wanderlodge's To anyone who can answer this, What size jack stand is recommended for the 1995 Wanderlodge Wide body 42'. I know that the weight unloaded is about 48,000 lbs. Would a 12 ton jack stand be adequate or should it be a 22 ton? Ron Thompson 1995 WLWB 42' cockyfox@... ------------------------------------ Yahoo! Groups Links  |
					05-14-2011, 07:08
					05-14-2011, 07:10
					05-14-2011, 09:25
				 Ron, I have a set of these and like them a lot: http://www.thetoolwarehouse.net/p-4138-otc-1783.aspx David Brady, 02 LXi, NC On 5/14/2011 3:10 PM, Ron Thompson wrote: ÃÂ  |
					05-14-2011, 09:28
				 Ron
The pin lock seems more absolute,although the pawl lock type are using the coach weight to hold it in place.
Seems an uneven surface would put the pawl lock in jeopardy,but so is an uneven surface.
I donââ¬â¢t have a preference,but pin lock sounds like the best design.
					05-14-2011, 09:30
					05-14-2011, 09:31
					05-14-2011, 17:39
					Make sure the rating is what you think it is. Is this is pairs or individually?
			On 14 May 2011 12:08, Ron Thompson <"cockyfox@sbcglobal.net"> wrote:
