Air Brakes 91'Bird
05-05-2011, 07:10
Air Brakes 91'Bird
I have a constant leak out the exhaust port of the air brake on my drive axle
pass side whenever the parking brake is off and I'm ready to drive. Can I fix this myself ? |
05-05-2011, 08:11
Air Brakes 91'Bird
Well I don't know can you? LOL. It depends on what the problem is I suppose. It may be leaking brake chamber. If you replace the brake chamber replace the hoses at the same time and do both Chambers at once given their age. Never.... ever.... try to take a brake chamber apart on your own. There is a spring pressure in your parking brake chambers that is enormous and very dangerous. Also block the bus frame up so it does not come down on you. Maybe a repair shop is in order?
On 5 May 2011 12:10, oldbaja <"bjsc4363@hotmail.com"> wrote:
05-05-2011, 09:19
Air Brakes 91'Bird
05-05-2011, 13:25
Air Brakes 91'Bird
Wallace & Faye Craig
95 WLWB 42
Azle, Texas
From: Ernie Ekberg To: WanderlodgeForum@yahoogroups.com Sent: Thu, May 5, 2011 4:19:17 PM Subject: Re: [WanderlodgeForum] Air Brakes 91'Bird
05-05-2011, 13:50
Air Brakes 91'Bird
I also second the repair shop. Safer and Steve Quandt 1993 PT 40 Iron Mountain, MI From: Well I don't know can you? LOL. It depends on what the problem is I suppose. It may be leaking brake chamber. If you replace the brake chamber replace the hoses at the same time and do both Chambers at once given their age. Never.... ever.... try to take a brake chamber apart on your own. There is a spring pressure in your parking brake chambers that is enormous and very dangerous. Also block the bus frame up so it does not come down on you. Maybe a repair shop is in order? On 5 May 2011 12:10, oldbaja <"bjsc4363@hotmail.com"> I have a constant leak |
05-06-2011, 08:01
Air Brakes 91'Bird
Thanks for the input guys. It is leaking from the chamber. Can't drive it cause
the leak won't let the parking brake off. Gonna find an assembly and try to change it here. --- In WanderlodgeForum@yahoogroups.com, "oldbaja" <bjsc4363@...> wrote: > > I have a constant leak out the exhaust port of the air brake on my drive axle pass side whenever the parking brake is off and I'm ready to drive. Can I fix this myself ? > |
05-06-2011, 08:48
Air Brakes 91'Bird
Dear ???, (please sign your posts)
I note that you have never indicated your mechanical prowess or if you have ever changed one of those out before, but you got some good advice to let someone else do it. Call a mobile diesel truck service. Several items to consider. If you have a chamber spring 'tool', you can release the spring pressure on that chamber and you can move the bus around (slowly please) if you need to re-position it. The 91 used a MGM 3036 chamber. If you do a search on the forum you will find several posts on this chamber (as well as installation hints). I had one of mine go in 2007 and it was impossible to find locally in San Antonio, TX. Even the manufacturer had none in stock at that time. The MGM 3036 ran about $300 at that time. A potential replacement is a Bendix 3030 which is readily available at any truck shop in the US. They make about 4 million per year and are rated up to 80,000 lbs as I recall. They were under $100 each. Downside, you need to replace both sides. If you decide to crawl under there, make darn sure you brace the frame up and not just rely on the jacks. (I really hate making "In Memoriam" front pages for Bird of the Week! Check Bird of the Week archive for one that did not brace the frame on a big rig.) Good luck and let us know how it works out. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "oldbaja" <bjsc4363@...> wrote: > > Thanks for the input guys. It is leaking from the chamber. Can't drive it cause the leak won't let the parking brake off. Gonna find an assembly and try to change it here. > > --- In WanderlodgeForum@yahoogroups.com, "oldbaja" <bjsc4363@> wrote: > > > > I have a constant leak out the exhaust port of the air brake on my drive axle pass side whenever the parking brake is off and I'm ready to drive. Can I fix this myself ? > > > |
05-07-2011, 09:46
Air Brakes 91'Bird
> > Thanks for the input guys. It is leaking from the chamber. Can't drive it cause the leak won't let the parking brake off. Gonna find an assembly and try to change it here. > > --- In WanderlodgeForum@yahoogroups.com, "oldbaja" <bjsc4363@> wrote: > > > > I have a constant leak out the exhaust port of the air brake on my drive axle pass side whenever the parking brake is off and I'm ready to drive. Can I fix this myself ? > > > I would not go under your bus for anything. Call a mobile diesel mechanic and have it replaced for safety sake. Also you must know if your current brake chambers are long stroke or not. 97 is around the time the switch started to happen on some busses. Don't mix short stroke and long stroke as this can create timing problem with brake applications potentially causing dangerous conditions on the road. Have it done by a professional. |
