Wanderlodge WB40 Trans temp sender unit
10-03-2010, 05:11
Looking for suggestions on locating a sending unit for my 1991 WB40 Wanderlodge.
This Wanderlodge has the 8V92 detroit with the 745 allison w/retarder. In my
Wanderlodge manual it shows this as "Sender oil temp, Transmission with
retarder" Part# 1197920.
Is there a place that still has some Wanderlodge parts inventory?
If not....would you think this is a "detroit part", "allison part", "wanderlodge
part" or "Bluebird part".
Any suggestions appreciated. Thanks, Gerald
10-03-2010, 06:58
>Wanderlodge.
>my Wanderlodge manual it shows this as "Sender oil temp, Transmission with
>"wanderlodge part" or "Bluebird part".
I would say none of the above. Senders/gauges are normally a matched pair.
Meaning Teleflex.
10-03-2010, 08:14
Hi Gerald,
This will likely be a part you can obtain from Allison or even perhaps your local Napa dealer or truck part store.  It will be a sending unit that Allison should be able to provide you will once you give them your transmission information.
Cheers
Gary
10-04-2010, 06:49
Thanks for the replies....The part number appears to be "Bluebird" specific.
Doesn't mean anything to my local "Allison" or "Detroit" dealer. Didn't have
any luck at "Napa" either. Googleing "teleflex" doesn't show the sender I'm
looking for.
This sender controls the "red light" that is located on the trans oil temp
guage. The guage itself, has its own sender.
Contacted "Parliament Coach" and they are seeing if they can come up with
something.
Again thanks for the responses, Gerald
10-04-2010, 07:35
Mine doesn't have a separate "red light" with sender, so I didn't realize there
were two.
Looking around the internet it appears that the most common is a single sender
that handles both gauge and light.
See, for example, the third sender on this page:
http://www.egauges.com/vdo_send.asp?Send...F_150C_VDO
Don Bradner
90 PT40 "Blue Thunder"
>specific. Doesn't mean anything to my local "Allison" or "Detroit"
>dealer. Didn't have any luck at "Napa" either. Googleing "teleflex"
>doesn't show the sender I'm looking for.
>something.
>Yahoo! Groups Links
10-04-2010, 07:39
Try Holland Motor Homes in Holland, MI 616-396-1461
and ask for Tammy in parts. She should be able to help. They will not be the
cheapest place on the block but I have had very good luck there. She just got
me an Engine Oil Temp Sender.
Steve Quandt
1993 – PT-40
Iron Mountain, MI
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Pete
Sent: Sunday, October 03, 2010
12:11 PM
Subject: [WanderlodgeForum]
with the 745 allison w/retarder. In my Wanderlodge manual it shows this as
"Sender oil temp, Transmission with retarder" Part# 1197920.
part", "allison part", "wanderlodge part" or
"Bluebird part".
