Powder Balancing
06-20-2005, 13:44
Powder Balancing
What does this mean? Jon
Jon Lechich
jipjob@...
06-20-2005, 14:00
Powder Balancing
Hi Jon,
There are at least two different "powder" materials that are used for
balancing of tires. The one I am familiar with is "Equal". I have
used it on two coaches so far and I believe it is superior to the
Centromatics balancers that I used to have. What they do is put a
measured amount in your tire in a package. The package disintegrates
in a couple of hundred miles and then you have complete usage. As the
tire turns, the powder redistributes itself so as to keep the
tire/wheel in balance. I have bee told that is also tends to keep the
tread flatter against the road surface giving you better traction.
To my knowledge, Equal is only available for the larger truck/bus
tires. I have been told that they are working on a formula that will
work on the smaller (more turns per mile) tires for cars. The other
brand, which I cannot remember the name of right now, claims that
theirs will work in any size tire. It sure is nice not having to
rebalance every so often...
BTW, I have Equal in all eight tires.
George Lowry
Spearfish, SD
> Jon Lechich
> jipjob@...
> Yahoo! Groups Links
06-20-2005, 14:28
Powder Balancing
Does anyone have experience with the power clogging up the tire
stem/valves??
Bill 88 FC
--- In WanderlodgeForum@yahoogroups.com, George Lowry
> Hi Jon,
for
have
a
disintegrates
will
other
> George Lowry
> Spearfish, SD
> > Jon Lechich
> > jipjob@Y...
> > Yahoo! Groups Links
06-20-2005, 14:36
Powder Balancing
they put a power in the tire that spreads around the tire on the
inside, and balances it out !! seems to work,,, day jax fla pt-40
06-20-2005, 14:38
Powder Balancing
it takes a special valve core when you use equal.i have it in my new
toyos.randydupree93wb
Sent: Monday, June 20, 2005 10:28 PM
Subject: [WanderlodgeForum] Re: Powder Balancing
stem/valves??
Bill 88 FC
> Hi Jon,
for
have
a
disintegrates
will
other
> George Lowry
> Spearfish, SD
> > Jon Lechich
> > jipjob@Y...
> > Yahoo! Groups Links
Yahoo! Groups Links
06-20-2005, 14:38
Powder Balancing
yes,,, i had it happen on the two new front tires i just had
installed,, day,, jax fla 83 pt-40
06-20-2005, 15:05
Powder Balancing
I did not know that there was anything different about the valve
core . I thought they just put the colored bands on them to show to the
next tire mechanic that the tires infact had equal in them. What would
be the difference in the valve core ??? Bob 93pt illinois
06-20-2005, 15:20
Powder Balancing
The valve core has a filter in it so that the powder cannot get into the
valve stem and cause it to stick. Make sure if you do get equal that you
get these valve stems installed.
Actually I would not install equal in a RV tire unless you are going to put
a lot of miles on the tires. If it sits for any length of time and there is
even the slightest amount of water vapor in the tire the equal may clump.
Truckers use it and do not have these problems because the tires are
constantly moving.
On the other hand I have about 40# of Counteract balancing beads a compound
which I believe is better for RV use. I am not a dealer and do not intend
to sell it although I have the equipment and the product to both inject the
beads thru the vavle stem on a installed tire and the bags that are thrown
into the casing on new tires.
http://www.wheelweights.com/cbb-brochure.pdf#search='counteract%20balancing%20be\
ads'
Counteract balancing beads differ from equal in that the composition of the
beads and the fact that water moisture does not effect it. In addition
counteract balancing beads come in two different compositions one for cars
and one for trucks or RVs. The two different beads are engineered for the
different tire rebounding characteristics between cars and trucks.
I now have it in my steer tires and when I install the new tires will
install it in both the steers and the rear duals.
tom
1982 FC35
Vernon Center,NY
>Yahoo! Groups Links
06-20-2005, 16:34
Powder Balancing
Is this rebounding characteristic that noticeable when you do not have this
material in your tires? Does it make for a smoother ride? Jon
Jon Lechich
Bremerton Washington
constantly moving.
ads'
tom
1982 FC35
Vernon Center,NY
>Yahoo! Groups Links
Yahoo! Groups Links
One of my favorite sayings goes! "You never own anything, everything owns you!"
Yahoo! Sports
Rekindle the Rivalries. Sign up for Fantasy Football
06-20-2005, 21:51
Powder Balancing
Jon I can sure feel an out of balance tire and the heavier the tire is the
more you can feel it. It is this out of balance condition that forces the
tire down against the pavement and the resulting rebound that causes the
balancing beads to be forced to a point opposite to the heavy spot in the
tire. The company has found that in the case of an automobile the
suspension is designed for a much smooter ride and the beads designed for
trucks do not distribute themselves the same way when installed in an
automobile.
tom
1982 FC35
Vernon Center,NY
>this material in your tires? Does it make for a smoother ride? Jon
>Jon Lechich
>constantly moving.
>http://www.wheelweights.com/cbb-brochure.pdf#search='counteract%20balancing%20b\
eads'
>tom
>1982 FC35
>Vernon Center,NY
> >Yahoo! Groups Links
>Yahoo! Groups Links
>you!"
>Yahoo! Sports
>Yahoo! Groups Links
