FMCA /COACH NET ROAD SERVICE
05-28-2010, 12:01
For all of those who subscribe to Coach-Net policy issued throughtFMACA,please take the time to read the"member benefit guide" which is available by contacting www.coach-net.com . One of members recently experienced a surprise with his coverage which might have been a huge problem to one less mechinacally inclined (me). Be sure that you understand what is in your interest to say when you call for service and in order to do this you must read the benefit guide.
A word to the wise.
Wallace & Faye Craig
95 WLWB 42
Azle, Texas
05-28-2010, 12:09
Wallace,
Could you be a little more direct with this comment? What was the problem and
what am I looking for in the guide?
Thanks,
1991 WB40 "Texas Minivan"
San Antonio, TX - home again!
--- In WanderlodgeForum@yahoogroups.com, Wallace Craig
FMACA,please take the time to read the "member benefit guide" which is available
by contacting http://www.coach-net.com . One of members recently experienced a
benefit guide.
> A word to the wise.
> 95 WLWB 42
> Azle, Texas
05-28-2010, 15:05
Mike, you really have to look at the benefit guide which they will send you if you ask. Things that you might think are coveredare not; maintenance issues for example (what that mean?) I don't want to elaboratetoo much, but if you read the guide you will see what I mean.
95 WLWB 42
Azle, Texas
Sent: Fri, May 28, 2010 7:09:32 PM
Subject: [WanderlodgeForum] Re: FMCA /COACH NET ROAD SERVICE
Wallace,
Could you be a little more direct with this comment? What was the problem and what am I looking for in the guide?
Thanks,
> A word to the wise.
> 95 WLWB 42
> Azle, Texas
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
"WanderlodgeForum-digest@yahoogroups.com"
"WanderlodgeForum-fullfeatured@yahoogroups.com"
"WanderlodgeForum-unsubscribe@yahoogroups.com"
05-28-2010, 15:35
Wallace what is the big deal here, just say it! I have been towed by Coach net three times ( 2 times for the smae trouble) and had no probelm with Coach Net.
Scooter 2000XL
Date: Fri, 28 May 2010 20:05:49 -0700
Subject: Re: [WanderlodgeForum] Re: FMCA /COACH NET ROAD SERVICE
95 WLWB 42
Azle, Texas
Wallace,
Thanks,
> A word to the wise.
> 95 WLWB 42
> Azle, Texas
Yahoo! Groups Links
05-28-2010, 15:35
It sounds like you are expecting the service to be something like a Warranty?
Otherwise I don't see what the source of the problem would have to do with it.
They will either tow you, or pay for a roadside service guy's travel time, and
it doesn't really have to do with what the issue is so long as it has left you
stranded.
I've used them three tows and one service call over the past 8 years, and
whether something was maintenance-caused did not enter the equation. In none of
the cases did they cover actual repairs, and I didn't expect it.
The only issue I had was with the service call - I had to insist on it, since
they wanted to tow me, and had to sit through the reading of the rules which
basically said that I was burning my once per incident and if I needed towing
after the service I was on my own, and I was responsible for the hourly rate of
the guy when he got there, one hour minimum. Not a problem, just dispatch him!
>you if you ask. Things that you might think are covered are not;
>elaborate too much, but if you read the guide you will see what I mean.
>95 WLWB 42
>Azle, Texas
05-29-2010, 03:06
Don, I don't remember mentioning warranty; I simply caution members to know what they are buying. I have had no problem with C N , but have had to be insistant on occasion. I am not suggesting that the product is bad, just know what you are buying.
95 WLWB 42
Azle, Texas
Sent: Fri, May 28, 2010 10:35:49 PM
Otherwise I don't see what the source of the problem would have to do with it. They will either tow you, or pay for a roadside service guy's travel time, and it doesn't really have to do with what the issue is so long as it has left you stranded.
I've used them three tows and one service call over the past 8 years, and whether something was maintenance-caused did not enter the equation. In none of the cases did they cover actual repairs, and I didn't expect it.
The
only issue I had was with the service call - I had to insist on it, since they wanted to tow me, and had to sit through the reading of the rules which basically said that I was burning my once per incident and if I needed towing after the service I was on my own, and I was responsible for the hourly rate of the guy when he got there, one hour minimum. Not a problem, just dispatch him!
>95 WLWB 42
>Azle, Texas
Yahoo! Groups Links
on the web, go to:
05-29-2010, 03:18
Wow!! Good point Wallace. I see that after a tow or road side repair AND it is found to have been a normal maint item, then CN would not cover it. For instance the Coach quit, and after a tow into a shop and all that was found were fuel filters plugged then because it is a maint item not break down. Interesting.
Safe travels, Ralph Charolette Fullenwider
'84 FC35 "Ruff Diamond"
Duncan, Oklahoma
Sent via BlackBerry by AT&T
Date: Sat, 29 May 2010 08:06:26 -0700 (PDT)
To:
95 WLWB 42
Azle, Texas
The
>95 WLWB 42
>Azle, Texas
Yahoo! Groups Links
on the web, go to:
05-29-2010, 03:22
But I may have read it wrong too, being a layman, some of the fine print escapes me
Duncan, Oklahoma
Date: Sat, 29 May 2010 15:18:52 +0000
To: Wanderlodge Forum
Duncan, Oklahoma
To:
95 WLWB 42
Azle, Texas
The
>95 WLWB 42
>Azle, Texas
Yahoo! Groups Links
on the web, go to:
05-29-2010, 07:07
I emphasize that our experience has been good, they flew FC home twice, but I had to explain their options to them. İmage
95 WLWB 42
Azle, Texas
Sent: Sat, May 29, 2010 10:22:55 AM
Safe travels, Ralph & Charolette Fullenwider
Duncan, Oklahoma
Duncan, Oklahoma
To:
95 WLWB 42
Azle, Texas
The
>95 WLWB 42
>Azle, Texas
Yahoo! Groups Links
on the web, go to:
05-31-2010, 00:04
I was towed in Feb of last year in my bird by coach net. They pulled me to Freightliner in Knoxville. There was never any mention of the problem. The set the coach down in the parking lot and they were done.
Paul Downey
Versailles Ky.
In a message dated 5/28/2010 11:36:07 P.M. Eastern Daylight Time, bluethunder@... writes:
The only issue I had was with the service call - I had to insist on it, since they wanted to tow me, and had to sit through the reading of the rules which basically said that I was burning my once per incident and if I needed towing after the service I was on my own, and I was responsible for the hourly rate of the guy when he got there, one hour minimum. Not a problem, just dispatch him!
>95 WLWB 42
>Azle, Texas
