%0 amp connector part#
12-05-2009, 16:13
I want to make up a new 50 am cord for our
82FC. Does any one know the NEMA number for the female plug? The current one
is so worn that the numbers cannot be read.
- Chuck
Wheeler-
1982 FC 31SB Fort Worth TX
12-05-2009, 17:05
Chuck - Try 947B. That is the listing number on mine.
Bob Griesel '83 FC31 WLII WA
--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" wrote:
> I want to make up a new 50 am cord for our 82FC. Does any one know the NEMA
> number for the female plug? The current one is so worn that the numbers
> cannot be read.
> - Chuck Wheeler-
12-05-2009, 18:45
Thanks, I’ll give it a look.
- Chuck
Wheeler-
WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of freewill2008
Sent: Saturday, December 05, 2009
11:05 PM
Subject: [WanderlodgeForum] Re: %0
amp connector part#
--- In "WanderlodgeForum%40yahoogroups.com",
NEMA
> cannot be read.
> - Chuck Wheeler-
TX
12-05-2009, 18:45
- Chuck
Wheeler-
11:05 PM
amp connector part#
NEMA
> cannot be read.
> - Chuck Wheeler-
TX
12-06-2009, 08:39
Chuck,
I thought it was NEMA L6-50, but when I just looked it up, the L6
configuration now lacks neutral. Instead, of the three pins being
hot-hot-neutral, with the ground connection made via contacts in the case,
the L6 now contains one pin dedicated to ground.
Apparently 'code' now does not like the older version grounding via the
case. If we want 240 and 120 vac (2 hot legs, neutral and ground),
apparently we are supposed to use a NEMA L14 4-pole connector that has four
pins, hot, hot, neutral and ground.
I just replaced my original 1976 50 amp male connector on the bus to make it
compatible with the 50 amp 240/120 volt cables I already use around marinas
(3-poles plus case ground). When I spoke to a licensed electrician recently
about installing a 50 amp receptacle outside the garage, he told me that
code required this new four pin connector that I see associated with home
generator connectors.
Perhaps someone who knows more can elaborate.
Regards,
Donn
76 33FC
South Kingstown, RI
http://en.wikipedia.org/wiki/NEMA_connector#NEMA_L6
https://www.hubbellnet.com/max_htm/PDF_L.../h4636.pdf
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Chuck Wheeler
Sent: Saturday, December 05, 2009 11:13 PM
Subject: [WanderlodgeForum] %0 amp connector part#
cannot be read.
- Chuck Wheeler-
12-06-2009, 08:56
I agree with Don. If you are rebuilding the shore cable anyway, replace the
male connecter and go with the 4-pin system.
If they still make the old style connector, here is the complete information
(now that it is daylight and NOT snowing!) off my 50 connectors:
Arrow-Harting
Hart-Lock
Made in USA
U/L Listed 947B Connector
50A 250VAC
Bob Griesel '84 FC31 WLII WA
--- In WanderlodgeForum@yahoogroups.com, "Donald Watson" wrote:
> Chuck,
> Regards,
> Donn
> 76 33FC
> South Kingstown, RI
> cannot be read.
> - Chuck Wheeler-
12-06-2009, 10:08
Thanks Bob! Your information allow me to
find that Arrow-Hart was acquired by Cooper and what they list as a 947B is not
the same as our original connectors. I appreciate you taking the time to check
your connector.
- Chuck
Wheeler-
Sent: Sunday, December 06, 2009
2:57 PM
To:
amp connector part#
cable anyway, replace the male connecter and go with the 4-pin system.
Arrow-Harting
Hart-Lock
Made in USA
50A 250VAC
"Donald Watson" > wrote:
> Chuck,
four
it
marinas
recently
> Regards,
> Donn
> 76 33FC
> South Kingstown, RI
> https://www.hubbellnet.com/max_htm/PDF_Literature_Library/h4636.pdf
> From: "WanderlodgeForum%40yahoogroups.com"
> [mailto:"WanderlodgeForum%40yahoogroups.com"]
NEMA
> cannot be read.
> - Chuck Wheeler-
TX
