Location of air tank.
06-14-2005, 02:35
Can someone tell me where the air storage tank is located in a 1994
WB? I was told I should drain every year. Thanks Nelson SLinkman 1994wb |
06-14-2005, 14:26
--- In WanderlodgeForum@yahoogroups.com, "nslinkman"
wrote: > Can someone tell me where the air storage tank is located in a 1994 > WB? I was told I should drain every year. > Thanks > Nelson SLinkman 1994wb Nelson: Under your coach, get directly beneath the air dryer and look up. You will see two tanks that have manual valves on them and you can reach up and drain them. Then crawl forward towards the front of the coach about 4 feet and look up next to where the fuel tank starts, you will see another air tank that runs cross ways. You will be unable to reach this tank but there should be a copper line running from the drain on the tank to a valve that you can reach, just follow the line from the bottom of the tank. Bpb 93pt--Illinois |
06-15-2005, 01:19
Thanks Bob for the information. Could you also tell me
where the air dryer is located. I have never been underneath the coach. --- Bob & Carol Howald` > --- In WanderlodgeForum@yahoogroups.com, "nslinkman" > > wrote: > > Can someone tell me where the air storage tank is > located in a 1994 > > WB? I was told I should drain every year. > > Thanks > > Nelson SLinkman 1994wb > > Nelson: Under your coach, get directly beneath > the air dryer and > look up. You will see two tanks that have manual > valves on them and you > can reach up and drain them. Then crawl forward > towards the front of > the coach about 4 feet and look up next to where the > fuel tank starts, > you will see another air tank that runs cross ways. > You will be unable > to reach this tank but there should be a copper line > running from the > drain on the tank to a valve that you can reach, > just follow the line > from the bottom of the tank. Bpb 93pt--Illinois > > > > __________________________________ Discover Yahoo! Find restaurants, movies, travel and more fun for the weekend. Check it out! http://discover.yahoo.com/weekend.html |
06-15-2005, 03:17
Nelson: The air dryer is located directly infront of the drive axle
gear section . If you still can't find it, start the coach and set the brake's crawl under it and wait for the dryer to discharge, there will be do doubt where it's located when this happen's. (just kidding)..Bob 93pt illinois |
