					Spot/Flood Lights
					06-09-2005, 23:21
				Spot/Flood Lights
					I am trying to trouble shoot the spot/flood lights on our 86FCRB. They
			are Jabsco model 61026. The port light comes on and will switch from flood/spot the starboard light bulb is cracked(on order from grainger 40.00 ouch) But both have quit moving in either direction vert or horiz. I have pulled the overhead panel down and separated (I think) the switches from the wiring harness from the light. Hooked up 12v directly to the wires to make the dc motor drive and ... nothing. The folks at Jabsco have been very helpful and say the motors are very durable and they doubt the motors have gone bad. Just mention the "turkey" incident and he will immediately be your friend..lol Does anyone know how long the wiring harness from the light is from Jabsco to the BB wiring harness..want to eliminate any additional connectors. What about the routing of the harnesses?? Diagrams say small fuse is in the upper front load center found that its ok ..or appears to be. Checking this before dis-assembly of the light itself.. Anyone have some other ideas as to a solution. Scott 86FC35 "RUBY" Murrells Inlet SC (right next to heaven) PS..it's interesting the wiring behind the panel found several "cut" wires thats another post.  |
					06-10-2005, 00:06
				Spot/Flood Lights
					rob robinson (where are you rob?) took john finns light down and took it
			apart,greasing and cleaning everything in there,i think he made it all work again.it was just dirty..maybe john remembers..randydupree93wb ----- Original Message ----- From: Scott To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 10, 2005 7:21 AM Subject: [WanderlodgeForum] Spot/Flood Lights I am trying to trouble shoot the spot/flood lights on our 86FCRB. They are Jabsco model 61026. The port light comes on and will switch from flood/spot the starboard light bulb is cracked(on order from grainger 40.00 ouch) But both have quit moving in either direction vert or horiz. I have pulled the overhead panel down and separated (I think) the switches from the wiring harness from the light. Hooked up 12v directly to the wires to make the dc motor drive and ... nothing. The folks at Jabsco have been very helpful and say the motors are very durable and they doubt the motors have gone bad. Just mention the "turkey" incident and he will immediately be your friend..lol Does anyone know how long the wiring harness from the light is from Jabsco to the BB wiring harness..want to eliminate any additional connectors. What about the routing of the harnesses?? Diagrams say small fuse is in the upper front load center found that its ok ..or appears to be. Checking this before dis-assembly of the light itself.. Anyone have some other ideas as to a solution. Scott 86FC35 "RUBY" Murrells Inlet SC (right next to heaven) PS..it's interesting the wiring behind the panel found several "cut" wires thats another post. ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]  |
					06-10-2005, 01:19
				Spot/Flood Lights
					Hi Scott.
			You will need to open the overhead panel (remove panel) where the spotlight control switches are, see if you have power to the center wire on the left/right switch and to the joystick control If so, stop looking for fuses, there is power. Next see if the speed rheostat is passing power. If all have power then it COULD be the motors. I've had spotlights that were frozen from non-use, after manipulating by hand they would work on their own, another possibility. Any of the switches can go bad, selector/speed/joystick, ... and the wiring from there to the spotlights is all in the overhead and should be tracable directly to the spotlights as it goes through the roof right under the spotlight base. Run a few checks with a 12v light while moving the joystick around and that'll narrow it down. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > I am trying to trouble shoot the spot/flood lights on our 86FCRB. They > are Jabsco model 61026. The port light comes on and will switch from > flood/spot the starboard light bulb is cracked(on order from grainger > 40.00 ouch) But both have quit moving in either direction vert or > horiz. I have pulled the overhead panel down and separated (I think) > the switches from the wiring harness from the light. Hooked up 12v > directly to the wires to make the dc motor drive and ... nothing. The > folks at Jabsco have been very helpful and say the motors are very > durable and they doubt the motors have gone bad. Just mention > the "turkey" incident and he will immediately be your friend..lol > > Does anyone know how long the wiring harness from the light is from > Jabsco to the BB wiring harness..want to eliminate any additional > connectors. > What about the routing of the harnesses?? > Diagrams say small fuse is in the upper front load center found that > its ok ..or appears to be. Checking this before dis-assembly of the > light itself.. > Anyone have some other ideas as to a solution. > Scott > 86FC35 "RUBY" > Murrells Inlet SC (right next to heaven) > > PS..it's interesting the wiring behind the panel found several "cut" > wires thats another post.  |
					06-10-2005, 01:34
				Spot/Flood Lights
					Scott,
			I just watched Rob do his thing on the light, but it works now, the only thing that he couldn't fix was the deteriorated rubber boot that seals off the bottom. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA /////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > rob robinson (where are you rob?) took john finns light down and took it apart,greasing and cleaning everything in there,i think he made it all work again.it was just dirty..maybe john remembers..randydupree93wb > ----- Original Message ----- > From: Scott > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, June 10, 2005 7:21 AM > Subject: [WanderlodgeForum] Spot/Flood Lights > > > I am trying to trouble shoot the spot/flood lights on our 86FCRB. They > are Jabsco model 61026. The port light comes on and will switch from > flood/spot the starboard light bulb is cracked(on order from grainger > 40.00 ouch) But both have quit moving in either direction vert or > horiz. I have pulled the overhead panel down and separated (I think) > the switches from the wiring harness from the light. Hooked up 12v > directly to the wires to make the dc motor drive and ... nothing. The > folks at Jabsco have been very helpful and say the motors are very > durable and they doubt the motors have gone bad. Just mention > the "turkey" incident and he will immediately be your friend..lol > > Does anyone know how long the wiring harness from the light is from > Jabsco to the BB wiring harness..want to eliminate any additional > connectors. > What about the routing of the harnesses?? > Diagrams say small fuse is in the upper front load center found that > its ok ..or appears to be. Checking this before dis-assembly of the > light itself.. > Anyone have some other ideas as to a solution. > Scott > 86FC35 "RUBY" > Murrells Inlet SC (right next to heaven) > > PS..it's interesting the wiring behind the panel found several "cut" > wires thats another post. > > > > > > > -------------------------------------------------------------------- ---------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed]  |
					06-10-2005, 09:33
				Spot/Flood Lights
					Hi Scott,
			I rebuilt the ones on my '90. They, too, were frozen in place. In addition to cleaning and lubricating I replaced the rubber boots (don't know if they are still available) and also replaced the relay that switches power through the joystick to either set of motors. Worked great after above was done. Total parts were only a few dollars, relay was from Radio Shack, bulbs at local NAPA store. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > I am trying to trouble shoot the spot/flood lights on our 86FCRB. They > are Jabsco model 61026. The port light comes on and will switch from > flood/spot the starboard light bulb is cracked(on order from grainger > 40.00 ouch) But both have quit moving in either direction vert or > horiz. I have pulled the overhead panel down and separated (I think) > the switches from the wiring harness from the light. Hooked up 12v > directly to the wires to make the dc motor drive and ... nothing. The > folks at Jabsco have been very helpful and say the motors are very > durable and they doubt the motors have gone bad. Just mention > the "turkey" incident and he will immediately be your friend..lol > > Does anyone know how long the wiring harness from the light is from > Jabsco to the BB wiring harness..want to eliminate any additional > connectors. > What about the routing of the harnesses?? > Diagrams say small fuse is in the upper front load center found that > its ok ..or appears to be. Checking this before dis-assembly of the > light itself.. > Anyone have some other ideas as to a solution. > Scott > 86FC35 "RUBY" > Murrells Inlet SC (right next to heaven) > > PS..it's interesting the wiring behind the panel found several "cut" > wires thats another post.  |
					06-10-2005, 10:58
				Spot/Flood Lights
					Thanks Rich, George, Bill, etal.. I think my problem is a compound
			one. The joy stick when testing it..doesn't have power to one set of pins when pushed to that side..Additionally I believe the relay has gone south.. no power to that set of wires on the board for the relay. Jay do you remember the radio shack part #?? I know it is a shot in the dark but electronics co. wants $40.00 for the relay plus shipping. I have a wiring diagram (for dual lights) if anyone is interested in getting one. Just email me and I will be happy to scan what I have and send it to you ... this electric stuff is hard when you have TWO GREMLINS TO CHASE...WHEW Scott 86FC35 Murrells Inlet SC (still next to heaven) --- In WanderlodgeForum@yahoogroups.com, "g_man1146" wrote: > Hi Scott, > > I rebuilt the ones on my '90. They, too, were frozen in place. In > addition to cleaning and lubricating I replaced the rubber boots > (don't know if they are still available) and also replaced the relay > that switches power through the joystick to either set of motors. > Worked great after above was done. Total parts were only a few > dollars, relay was from Radio Shack, bulbs at local NAPA store. > > Rich D. '99LXi43' CT > > --- In WanderlodgeForum@yahoogroups.com, "Scott" > wrote: > > I am trying to trouble shoot the spot/flood lights on our 86FCRB. > They > > are Jabsco model 61026. The port light comes on and will switch > from > > flood/spot the starboard light bulb is cracked(on order from > grainger > > 40.00 ouch) But both have quit moving in either direction vert or > > horiz. I have pulled the overhead panel down and separated (I > think) > > the switches from the wiring harness from the light. Hooked up 12v > > directly to the wires to make the dc motor drive and ... nothing. > The > > folks at Jabsco have been very helpful and say the motors are very > > durable and they doubt the motors have gone bad. Just mention > > the "turkey" incident and he will immediately be your friend..lol > > > > Does anyone know how long the wiring harness from the light is > from > > Jabsco to the BB wiring harness..want to eliminate any additional > > connectors. > > What about the routing of the harnesses?? > > Diagrams say small fuse is in the upper front load center found > that > > its ok ..or appears to be. Checking this before dis-assembly of > the > > light itself.. > > Anyone have some other ideas as to a solution. > > Scott > > 86FC35 "RUBY" > > Murrells Inlet SC (right next to heaven) > > > > PS..it's interesting the wiring behind the panel found > several "cut" > > wires thats another post.  |
