					Tachometer fix
					06-06-2005, 17:07
				Tachometer fix
					Time to fix the tachometer.  I have only owned the wanderlodge for a
			few weeks, 2 short weekend trips so far, and have finally opened the front. Luckily it has a swing radiator, looks like it was modified after the original build, probably when the new engine was installed. Any way I need to get the fan off, it is an electric fan and I am not sure if this was stock I am guesing not because of the "custom" wiring block mounted on the front of the motor to power the fan. I have removed the large bolt in the center and I can see a shaft with a keyway, a bearing and the fan housing. The fan spins freely on the shaft or should I say on the bearing. Now how do I remove the fan? I am guessing a puller is needed but not sure. Any one famaliar with removing this type of fan? Troy, Waconia MN 83 FC 33  |
					06-06-2005, 23:03
				Tachometer fix
					stop! remove the 4 bolts that hold the fan and housing to the block.pay very
			close attention to the 4 bolts and the long flat bar the bolts go through.make sure you mark the bar and put it back as removed. randydupree93wb ----- Original Message ----- From: ttikalsky To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, June 07, 2005 1:07 AM Subject: [WanderlodgeForum] Tachometer fix Time to fix the tachometer. I have only owned the wanderlodge for a few weeks, 2 short weekend trips so far, and have finally opened the front. Luckily it has a swing radiator, looks like it was modified after the original build, probably when the new engine was installed. Any way I need to get the fan off, it is an electric fan and I am not sure if this was stock I am guesing not because of the "custom" wiring block mounted on the front of the motor to power the fan. I have removed the large bolt in the center and I can see a shaft with a keyway, a bearing and the fan housing. The fan spins freely on the shaft or should I say on the bearing. Now how do I remove the fan? I am guessing a puller is needed but not sure. Any one famaliar with removing this type of fan? Troy, Waconia MN 83 FC 33 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]  |
					06-09-2005, 15:44
				Tachometer fix
					Thanks for the tip, unfortunatly I already removed the bolts and the
			bars and I did not mark them. What does this effect? The bars are on the outside of the fan support so I don't see how they could effect anything. Also I removed the tach drive and the drive pins were good. Any ideas why the tachometer would work when idling but stop working above idle? Anyone know how to test voltage output levels and what they should be? Troy, Waconia MN 83FC33 --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > stop! remove the 4 bolts that hold the fan and housing to the block.pay very close attention to the 4 bolts and the long flat bar the bolts go through.make sure you mark the bar and put it back as removed. randydupree93wb > ----- Original Message ----- > From: ttikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, June 07, 2005 1:07 AM > Subject: [WanderlodgeForum] Tachometer fix > > > Time to fix the tachometer. I have only owned the wanderlodge for a > few weeks, 2 short weekend trips so far, and have finally opened the > front. Luckily it has a swing radiator, looks like it was modified > after the original build, probably when the new engine was installed. > Any way I need to get the fan off, it is an electric fan and I am not > sure if this was stock I am guesing not because of the "custom" wiring > block mounted on the front of the motor to power the fan. I have > removed the large bolt in the center and I can see a shaft with a > keyway, a bearing and the fan housing. The fan spins freely on the > shaft or should I say on the bearing. Now how do I remove the fan? I > am guessing a puller is needed but not sure. Any one famaliar with > removing this type of fan? > > Troy, Waconia MN 83 FC 33 > > > > > > -------------------------------------------------- ---------------------------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed]  |
					06-09-2005, 16:36
				Tachometer fix
					The flat bars have holes that are offset toward the inside, have to
			be installed again with the holes offset toward the inside/fan shaft. The tach drive on the '83 is an AC type, also used as cruise-control sender of that vintage, should increase frequency at increased RPM. You could use a DMM with a freq. counter on it, see if it is relative to RPM increase. The only other check I can think of is to put the output on a scope, and you can drive the sender with a drill if you're careful. Check the angle-drive, spin the input adapter with one hand while providing some resistance to the output cable and see if it slips internally, some do as the bevel-gears wear. Could also be the tachometer, although I've never had one fail. The angle-drive is apparently a special part, I've never been able to find one with a long enough input reach to clear the engine with a sender on it. BB should have the angle-drive, and I believe that HMH in Holland also has a cache of them on-hand, but haven't been there in a while. Previous years with the 90degree sweep tach. are driven by a DC generator sender made by AutoMeter. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > Thanks for the tip, unfortunatly I already removed the bolts and the > bars and I did not mark them. What does this effect? The bars are on > the outside of the fan support so I don't see how they could effect > anything. > > Also I removed the tach drive and the drive pins were good. Any ideas > why the tachometer would work when idling but stop working above idle? > Anyone know how to test voltage output levels and what they should be? > > Troy, Waconia MN 83FC33 > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > wrote: > > stop! remove the 4 bolts that hold the fan and housing to the > block.pay very close attention to the 4 bolts and the long flat bar > the bolts go through.make sure you mark the bar and put it back as > removed. randydupree93wb > > ----- Original Message ----- > > From: ttikalsky > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, June 07, 2005 1:07 AM > > Subject: [WanderlodgeForum] Tachometer fix > > > > > > Time to fix the tachometer. I have only owned the wanderlodge > for a > > few weeks, 2 short weekend trips so far, and have finally opened > the > > front. Luckily it has a swing radiator, looks like it was > modified > > after the original build, probably when the new engine was > installed. > > Any way I need to get the fan off, it is an electric fan and I am > not > > sure if this was stock I am guesing not because of the "custom" > wiring > > block mounted on the front of the motor to power the fan. I have > > removed the large bolt in the center and I can see a shaft with a > > keyway, a bearing and the fan housing. The fan spins freely on > the > > shaft or should I say on the bearing. Now how do I remove the > fan? I > > am guessing a puller is needed but not sure. Any one famaliar > with > > removing this type of fan? > > > > Troy, Waconia MN 83 FC 33 > > > > > > > > > > > > > -------------------------------------------------- > ---------------------------- > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > > [Non-text portions of this message have been removed]  |
					06-09-2005, 23:34
				Tachometer fix
					the bolt holes in the bars are offset to one side,if installed backwards the
			wide side towards the housing,the strap will not go flat against the housing when the bolts are tightened,then what happens is the housing slips down while your driving...check it out. randydupree93wb ----- Original Message ----- From: ttikalsky To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 11:44 PM Subject: [WanderlodgeForum] Re: Tachometer fix Thanks for the tip, unfortunatly I already removed the bolts and the bars and I did not mark them. What does this effect? The bars are on the outside of the fan support so I don't see how they could effect anything. Also I removed the tach drive and the drive pins were good. Any ideas why the tachometer would work when idling but stop working above idle? Anyone know how to test voltage output levels and what they should be? Troy, Waconia MN 83FC33 --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > stop! remove the 4 bolts that hold the fan and housing to the block.pay very close attention to the 4 bolts and the long flat bar the bolts go through.make sure you mark the bar and put it back as removed. randydupree93wb > ----- Original Message ----- > From: ttikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, June 07, 2005 1:07 AM > Subject: [WanderlodgeForum] Tachometer fix > > > Time to fix the tachometer. I have only owned the wanderlodge for a > few weeks, 2 short weekend trips so far, and have finally opened the > front. Luckily it has a swing radiator, looks like it was modified > after the original build, probably when the new engine was installed. > Any way I need to get the fan off, it is an electric fan and I am not > sure if this was stock I am guesing not because of the "custom" wiring > block mounted on the front of the motor to power the fan. I have > removed the large bolt in the center and I can see a shaft with a > keyway, a bearing and the fan housing. The fan spins freely on the > shaft or should I say on the bearing. Now how do I remove the fan? I > am guessing a puller is needed but not sure. Any one famaliar with > removing this type of fan? > > Troy, Waconia MN 83 FC 33 > > > > > > -------------------------------------------------- ---------------------------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]  |
					06-13-2005, 15:37
				Tachometer fix
					I cleaned and reasembled the tach drive, no broken parts found.  I
			started the motor and the gauge appears to be working, but when I rev the engine, quarter throttle max in neutral, the RPM goes over 3000. Is this correct? There is no red line on the guage. What RPM are most owners running? I have a 3208T, 225 HP with the 4.89 gear ratio. Troy, Waconia MN 1983 FC33 --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > Time to fix the tachometer. I have only owned the wanderlodge for a > few weeks, 2 short weekend trips so far, and have finally opened the > front. Luckily it has a swing radiator, looks like it was modified > after the original build, probably when the new engine was installed. > Any way I need to get the fan off, it is an electric fan and I am not > sure if this was stock I am guesing not because of the "custom" wiring > block mounted on the front of the motor to power the fan. I have > removed the large bolt in the center and I can see a shaft with a > keyway, a bearing and the fan housing. The fan spins freely on the > shaft or should I say on the bearing. Now how do I remove the fan? I > am guessing a puller is needed but not sure. Any one famaliar with > removing this type of fan? > > Troy, Waconia MN 83 FC 33  |
					06-14-2005, 01:22
				Tachometer fix
					2800 is normal for your engine.  That doesn't mean it's OK to run it there
			continuously. 2000/2300 is a safe cruise speed. Mike Hohnstein ----- Original Message ----- From: ttikalsky To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 13, 2005 10:37 PM Subject: [WanderlodgeForum] Re: Tachometer fix I cleaned and reasembled the tach drive, no broken parts found. I started the motor and the gauge appears to be working, but when I rev the engine, quarter throttle max in neutral, the RPM goes over 3000. Is this correct? There is no red line on the guage. What RPM are most owners running? I have a 3208T, 225 HP with the 4.89 gear ratio. Troy, Waconia MN 1983 FC33 --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > Time to fix the tachometer. I have only owned the wanderlodge for a > few weeks, 2 short weekend trips so far, and have finally opened the > front. Luckily it has a swing radiator, looks like it was modified > after the original build, probably when the new engine was installed. > Any way I need to get the fan off, it is an electric fan and I am not > sure if this was stock I am guesing not because of the "custom" wiring > block mounted on the front of the motor to power the fan. I have > removed the large bolt in the center and I can see a shaft with a > keyway, a bearing and the fan housing. The fan spins freely on the > shaft or should I say on the bearing. Now how do I remove the fan? I > am guessing a puller is needed but not sure. Any one famaliar with > removing this type of fan? > > Troy, Waconia MN 83 FC 33 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]  |
					06-14-2005, 02:49
				Tachometer fix
					Troy,
			Just had a similar problem. After three trips to the truck repair place problem was solved with a new sending unit. Before biting the bullet for a new sending unit ($100 +)be sure that right angle drive if in good shape and that all wiring is good. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of ttikalsky Sent: Monday, June 13, 2005 10:38 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Tachometer fix I cleaned and reasembled the tach drive, no broken parts found. I started the motor and the gauge appears to be working, but when I rev the engine, quarter throttle max in neutral, the RPM goes over 3000. Is this correct? There is no red line on the guage. What RPM are most owners running? I have a 3208T, 225 HP with the 4.89 gear ratio. Troy, Waconia MN 1983 FC33 --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > Time to fix the tachometer. I have only owned the wanderlodge for a > few weeks, 2 short weekend trips so far, and have finally opened the > front. Luckily it has a swing radiator, looks like it was modified > after the original build, probably when the new engine was installed. > Any way I need to get the fan off, it is an electric fan and I am not > sure if this was stock I am guesing not because of the "custom" wiring > block mounted on the front of the motor to power the fan. I have > removed the large bolt in the center and I can see a shaft with a > keyway, a bearing and the fan housing. The fan spins freely on the > shaft or should I say on the bearing. Now how do I remove the fan? I > am guessing a puller is needed but not sure. Any one famaliar with > removing this type of fan? > > Troy, Waconia MN 83 FC 33 ---------------------------------------------------------------------------- -- Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]  |
					06-14-2005, 02:57
				Tachometer fix
					If you have instrument problems, I suggest that you go to a
			speedometer shop or instrument shop. They are the experts and have the proper equipment and training to quickly diagnose the problem and repair them. I have found their prices to be less than a general repair shop who has to go to the instrument shop for the parts and sometimes the expertise, then add a markup. FWIW. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Chet Geist wrote: > > Troy, > > Just had a similar problem. After three trips to the truck repair place > problem was solved with a new sending unit. Before biting the bullet for a > new sending unit ($100 +)be sure that right angle drive if in good shape and > that all wiring is good. > > Chet Geist > 1981 FC33, Austin, Texas > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of ttikalsky > Sent: Monday, June 13, 2005 10:38 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Tachometer fix > > > I cleaned and reasembled the tach drive, no broken parts found. I > started the motor and the gauge appears to be working, but when I rev > the engine, quarter throttle max in neutral, the RPM goes over 3000. > Is this correct? There is no red line on the guage. What RPM are > most owners running? I have a 3208T, 225 HP with the 4.89 gear ratio. > > Troy, Waconia MN 1983 FC33 > > > --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" > wrote: > > Time to fix the tachometer. I have only owned the wanderlodge for a > > few weeks, 2 short weekend trips so far, and have finally opened the > > front. Luckily it has a swing radiator, looks like it was modified > > after the original build, probably when the new engine was installed. > > Any way I need to get the fan off, it is an electric fan and I am not > > sure if this was stock I am guesing not because of the "custom" wiring > > block mounted on the front of the motor to power the fan. I have > > removed the large bolt in the center and I can see a shaft with a > > keyway, a bearing and the fan housing. The fan spins freely on the > > shaft or should I say on the bearing. Now how do I remove the fan? I > > am guessing a puller is needed but not sure. Any one famaliar with > > removing this type of fan? > > > > Troy, Waconia MN 83 FC 33 > > > > > > ---------------------------------------------------------------------------- > -- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] > > > > > > Yahoo! Groups Links > > > > > > > > >  |
