					Low Water Pressure with Water Pump On
					08-31-2009, 06:01
					Was hooked to shore water for a week and now back at the home front. With the coach Water Pump ON, the faucets have low volume/pressure. Fill Tank SW is in the off position. Thoughts appreciated?
			Curt Sprenger  |
					08-31-2009, 06:20
					Curt
			Is the Sporlan valve closing all the way? I just put in a rebuild kit this last weekend because mine wouldn't close all the way, gave me lower pressure but also pushed water back out the fresh water feed. I had put in a rebuild kit about 2 years ago, the old diaphram was noticeably harder than the new one I put in now. Steve Quandt 1993 PT 40 Iron Mountain, MI --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Was hooked to shore water for a week and now back at the home front. With > the coach Water Pump ON, the faucets have low volume/pressure. Fill Tank SW > is in the off position. Thoughts appreciated? > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > *Read all about Southwest Bluebirds and Friends (SWBB) at > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > "Host of the Annual Bluebird Quartzsite Rally" * >  |
					08-31-2009, 06:23
				 Curt, I have had a similar experience, usually - Chuck 1982 FC 31SB  From:    Was hooked to shore water for a week and now back at the home front. With the coach Water Pump ON, the faucets have low volume/pressure. Fill Tank SW is in the off position. Thoughts appreciated?
					08-31-2009, 17:41
					If the pump shuts down it isnt the sporlan fill switch?
			read voltage to pump and amp draw when running to check if it is an elecrtical/ motor issue. ( Maybe some one knows what the proper amp limit is? I would disconnect the exhaust side of the pump and see how the pump spits without friction after If there is more pressure when you first turn the pressurized system on and it pisses lowvolumn then it is pump or supply Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Was hooked to shore water for a week and now back at the home front. With > the coach Water Pump ON, the faucets have low volume/pressure. Fill Tank SW > is in the off position. Thoughts appreciated? > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > *Read all about Southwest Bluebirds and Friends (SWBB) at > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > "Host of the Annual Bluebird Quartzsite Rally" * >  |
					09-01-2009, 03:56
					If you have a air purge switch in the water closet turn it on and you will have water.....this happens to me when I forget that I am filling the tank and I have a overflow.
			Scooter 2000LX Ocqueoc, MI To: WanderlodgeForum@yahoogroups.com From: curtsprenger@... Date: Mon, 31 Aug 2009 11:01:41 -0700 Subject: [WanderlodgeForum] Low Water Pressure with Water Pump On
Curt Sprenger  |
					09-05-2009, 23:54
