Converting JPEG to PDF
05-14-2009, 09:11
I have about 250 files to upload to the 'Attachments' section on the forum. Some of those files are JPEG. I can convert a JPEG to PDF. The problem I'm having is the single JPEG comes out 3 pages in the PDF. I can use help here. Thanks.
Curt Sprenger
Anaheim Hills, CA
Read all about Southwest Bluebirds and Friends (SWBB) at http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us.
"Host of the Annual Bluebird Quartzsite Rally"
05-14-2009, 10:10
It may depend on the software you're using. However, you should be able to set the size of the page to include the whole document. For example, some of the diagrams you recently posted show up as 11 x 17 size pages.
If you're working in Adobe Acrobat Pro, then you need to fiddle with the job options to set the page size. I did not find a specific page size limitation in my Acrobat documentation.
Pete Masterson, Author of
Book Design and Production: A Guide for Authors and Publishers
"Aeonix1@Mac.com"
Aeonix Publishing Group http://www.aeonix.com
Curt Sprenger
Anaheim Hills, CA
Read all about Southwest Bluebirds and Friends (SWBB) athttp://www.SOUTHWEST-BLUEBIRDS.ORG...Then Join us.
05-14-2009, 14:06
Have you reduced the jpeg file in size? Try that first and then convert. See
if that works better. What is the nature of the upload?
> Thanks.
> Curt Sprenger
> Anaheim Hills, CA
> *Read all about Southwest Bluebirds and Friends (SWBB) at
> "Host of the Annual Bluebird Quartzsite Rally" *
05-14-2009, 14:43
The upload..about half pertains to the 1984 FC. Remainder is Miscellaneous.'Bird stuff.
Curt Sprenger
Anaheim Hills, CA
On Thu, May 14, 2009 at 7:06 PM, ronmarabito2002 <"remarabito@att.net"> wrote:
Have you reduced the jpeg file in size? Try that first and then convert. See if that works better. What is the nature of the upload?
> Thanks.
> Curt Sprenger
> Anaheim Hills, CA
05-15-2009, 03:26
Are these written documents or photos & graphics?
> Curt Sprenger
> Anaheim Hills, CA
> > forum.
> > I'm
> > here.
> > > Thanks.
> > > Curt Sprenger
> > > Anaheim Hills, CA
05-15-2009, 03:32
I'd call them Photos & Graphics.
Curt Sprenger
Anaheim Hills, CA
On Fri, May 15, 2009 at 8:26 AM, ronmarabito2002 <"remarabito@att.net"> wrote:
> Curt Sprenger
> Anaheim Hills, CA
> > --- In "WanderlodgeForum%40yahoogroups.com"40yahoogroups.com>,
> > forum.
> > I'm
> > here.
> > > Thanks.
> > > Curt Sprenger
> > > Anaheim Hills, CA
05-15-2009, 08:03
All software I've ever seen to convert jpg to PDF uses the Adobe compressions
algorithm.
If you force a high resolution jpg to a small page PDF, it will lose resolution
and may become unreadable.
The best thing is to set the PDF page size to something slightly bigger than the
jpg. There are also some options with many of the conversion SW to maintain the
resolution at "high" which will force a bigger page.
It's great you are posting useful stuff but if you can't read it, its value is
diminished.
Regards,
GPSGary
84FC35SB
05-15-2009, 08:12
You must have done something right because I checked a few and they were just
fine. Thanks for all the great information.
> Curt Sprenger
> Anaheim Hills, CA
> > > Curt Sprenger
> > > Anaheim Hills, CA
> > convert.
> > > > --- In
> > > > forum.
> > problem
> > > > I'm
> > help
> > > > here.
> > > > > Thanks.
> > > > > Curt Sprenger
> > > > > Anaheim Hills, CA
05-15-2009, 17:46
Ron,
Did you check the JPEGs vx PDFs?
Curt Sprenger
Anaheim Hills, CA
On Fri, May 15, 2009 at 1:12 PM, ronmarabito2002 <"remarabito@att.net"> wrote:
You must have done something right because I checked a few and they were just fine. Thanks for all the great information.
> Curt Sprenger
> Anaheim Hills, CA
> > > Curt Sprenger
> > > Anaheim Hills, CA
> > convert.
> > 40yahoogroups.com>,
> > > > forum.
> > problem
> > > > I'm
> > help
> > > > here.
> > > > > Thanks.
> > > > > Curt Sprenger
> > > > > Anaheim Hills, CA
05-16-2009, 04:01
Curt: The only ones I opened were the PDF's. I will check on the JPEG's.
> Ron,
> Curt Sprenger
> Anaheim Hills, CA
> > > Curt Sprenger
> > > Anaheim Hills, CA
> > > > --- In
> > > > > Curt Sprenger
> > > > > Anaheim Hills, CA
> > > > convert.
> > > > > > --- In
> > the
> > > > > > forum.
> > > > problem
> > > > > > I'm
> > > > help
> > > > > > here.
> > > > > > > Thanks.
> > > > > > > Curt Sprenger
> > > > > > > Anaheim Hills, CA
