					changing belts and hoses
					03-31-2009, 17:13
					if it was an addon otherwise it does not have swingout rad  you can change the
			belts without opening the front be sure you have all the belts before you start and tightening them you do some from the top inside and some fromm the bottom out side Another added feature make sure you have a case of beer for the finish stephen 77fc35 dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, Dorn Hetzel > > I don't know if it has a swing out radiator or not. In the 18 months or so > that I have owned it, I have not yet had to access the radiator other than > to check coolant. Were swing out radiators an option in 77 FC 35 ? > > On Tue, Mar 31, 2009 at 6:00 PM, Curt Sprenger > > > Does your coach have the swing out radiator? Makes the job a lot easier. > > Might be a good time to fabricate your own swing radiator. Several > > procedures and pictures can be found on the forum. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > *Read all about Southwest Bluebirds and Friends (SWBB) at > > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > > "Host of the Annual Bluebird Quartzsite Rally" * > > > > > > > > > > On Tue, Mar 31, 2009 at 2:25 PM, Dorn Hetzel > > > >> It looks like I will need to be replacing some belts on my 77FC35 > >> fairly soon. > >> > >> All are still working, but getting a bit loose. > >> > >> Do I understand correctly that getting to the belts on the 77FC35 involves > >> removing the bumper, front panel and radiator ? > >> > >> If it's going to be a big job like that, I presume I will want to replace > >> all belts and any hoses in that area while I have the radiator off. > >> > >> Can anyone who has done this task offer me some clues? If I were to pay > >> someone to do it, can anyone estimate what I should expect it to cost? > >> > >> Regards, > >> > >> Dorn Hetzel > >> 77FC35 > >> Hogansville, GA > >> > > > > > > >  |
					03-31-2009, 23:04
					Dorn,
			I installed a swing radiator on my FC about 9 years or so ago. Not having to drain antifreeze and transmission fluid when removing the radiator makes it well worth the effort. I live in GA but am still quite a ways away. E-mail me directly and I can perhaps provide some pointers or even set up a Saturday where I can show you my swing radiator setup since I need to be doing some PM work soon anyhow. John Stiles 1980 33FC "My Navion" --- In WanderlodgeForum@yahoogroups.com, Dorn Hetzel > > It looks like I will need to be replacing some belts on my 77FC35 fairly > soon. > > All are still working, but getting a bit loose. > > Do I understand correctly that getting to the belts on the 77FC35 involves > removing the bumper, front panel and radiator ? > > If it's going to be a big job like that, I presume I will want to replace > all belts and any hoses in that area while I have the radiator off. > > Can anyone who has done this task offer me some clues? If I were to pay > someone to do it, can anyone estimate what I should expect it to cost? > > Regards, > > Dorn Hetzel > 77FC35 > Hogansville, GA >  |
					04-01-2009, 09:44
				 I have a 82 35FC which has a swing out radiator with a drop swing bumper after the first time I opened it I did away with the long hoses, which are difficult to deal with and also I changed the air intake which was not sufficient for the air flow required for a 3208. I now have to drain the radiatorand remove the hoses by detaching the flanges, it might take a little longer, but I have less busted knuckles. A word or advise if you pull the radiator be sure to replace the oil filter to block hose. This is why I had to pull open the radiator the first time, on the road side on I-95 in South Carolina. good luck
Ron & Nita Roberts
95PT40WB
In a message dated 3/31/2009 6:56:38 P.M. Eastern Daylight Time, aeonix1@... writes:
 Worried about job security? Check out the 5 safest jobs in a recession.  |
					04-01-2009, 13:56
				 I have opened my swing radiator three times in the last year, Pete Goddu 2442 NW Market Street, #628 Seattle, WA 98107 pwgoddu@... M/V Rubenesque - Kadey Krogen 48009NS "Kingfisher" - '84 BlueBird 35' FCSB KE7JGU 425 466 6602 From: I have a 82 35FC which has a swing out radiator with a drop swing Ron & Nita Roberts 95PT40WB In a message dated 3/31/2009 6:56:38 P.M. Eastern Daylight Time,
 Worried about job security? Check  |
