Tire Shopping
06-04-2005, 02:10
Post: #21
Tire Shopping
Axle weight is the determining factor for inflation. A good indicator of tire
overheating is a dark stripe at the out side of the side wall close to the tread. That's not good. I got a heat stripe on a 16 ply Michelin properly inflated, 110 in the shade, other side out of the direct sun no stripe. I ran lower pressure on the front axle of the truck for a while but incountered what looked like tread squirm on the steers. Bernies Tire in Albany GA shaved and balanced the Michelin 14 plys I had at the time pointed out too much side wall bulge. He was right, I had 11,600 on a 12K axle and 85# inflation, not good. I'd match my inflation pressure to the amount of load on the tire relative to max sidewall pressure spec. Shaving tires is a lost art, not many shops have the equipment anymore. Mike Hohnstein Germantown, WI ----- Original Message ----- From: randydupree To: WanderlodgeForum@yahoogroups.com Sent: Saturday, June 04, 2005 6:03 AM Subject: Re: [WanderlodgeForum] Re: Tire Shopping now this should start a debate! on my 93 40'wb i have run the pressure as low as 80lbs in all positions,not just for a test,but for months at a time,with no problems.i try different pressures because the drivablity changes drasticly with more or less pressure.my coach drives better with 85lbs in the tires,but,it a heavy crosswind it does"wander" more.so,right now they are at 95lbs.i don't believe in doing anything because "they'' said too.(whoever they are?).so,i test everything for myself..now,having said all that,i will add that i travel about 20,000 miles per year in my coach. and i have had no tire problems at all..randydupree93wb ----- Original Message ----- From: DAY8293A@... To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 03, 2005 10:47 PM Subject: Re: [WanderlodgeForum] Re: Tire Shopping SAY, I have a tire pressure question. Since you have approximately the same front axle gross as I do,,, what air pressure do you run your tires at??? My DUNLOP SP-160's call for 120 lbs for a max load of 6610 lbs. Two on the front would be 13,220 lbs, close to my gross front axle wt. Another PT 40 bird owner told me he never runs over 105 lbs,,,,,,, What would you run ??? I have always been told to run the max cold pressure to avoid blowouts,,,, What is correct??? DAY 83 PT-40 Jax Fla,,,,,,,, [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-04-2005, 02:25
Post: #22
Tire Shopping
HI GEORGE,,,
YOU HAVE SAID EXACTLY WHY I DON'T LIKE MICHELINS EITHER, AND THAT IS THE ONLY ONES I HAVE EVER HAD A BLOW OUT ON. THEY REFUSED TO HONOR A FLAT ON MY VAN, THAT I THOUGHT SHOULD HAVE BEEN UNDER THE WARRANTY, AND THEY REFUSED. I SAID I WOULD NEVER OWN ANOTHER MICHELIN AFTER THAT, BUT MADE THE MISTAKE OF PUTTING ONE ON MY LAST COACH, AN ITASCA, AND THAT WAS THE ONE THAT BLEW OUT !! NOW, I WANT ANYTHING BUT A MICHELIN,,,,, DAY,,,,, JAX FLA, 83 PT-40 [Non-text portions of this message have been removed] |
06-04-2005, 03:06
Post: #23
Tire Shopping
I GUESS I NEED TO FIND SOME SCALES AND WEIGH MY COACH AXLES!!!!
THANKS FOR THE INFO,,, DAY JAX FLA 83 PT-40 [Non-text portions of this message have been removed] |
06-04-2005, 05:04
Post: #24
Tire Shopping
I suggest you go to
<http://www.trucktires.com/us_eng/technic...able04.asp> and see what the manufacturer says for the weight you have on your particular tire. While this chart is for Bridgeston/Firestone, I have found that all manufacturers seem to be the same. I learned the hard way. When I fist got the GM bus, I had them inflated to the 100 - 110 lb. recommended by the dealer. After ruing a pair of steer tires, I learned about "proper inflation". I dropped the drivers to 75 lb. and the steer to 85 lb. The difference in handling was tremendous. NOt only did the coach ride better, it tracked better and the tires wore better. I constantly see people with large coaches that are over inflated. The Factory reps tell me that teh hardest part of their job is trying to get dealers to learn how to read. Go to the web site of any tire manufacturer and get their recommendations. I still believe that the manufacturer has the best information available. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD randydupree wrote: > now this should start a debate! on my 93 40'wb i have run the > pressure as low as 80lbs in all positions,not just for a test,but > for months at a time,with no problems.i try different pressures > because the drivablity changes drasticly with more or less > pressure.my coach drives better with 85lbs in the tires,but,it a > heavy crosswind it does"wander" more.so,right now they are at > 95lbs.i don't believe in doing anything because "they'' said > too.(whoever they are?).so,i test everything for myself..now,having > said all that,i will add that i travel about 20,000 miles per year > in my coach. and i have had no tire problems at > all..randydupree93wb ----- Original Message ----- From: > DAY8293A@... To: WanderlodgeForum@yahoogroups.com Sent: Friday, > June 03, 2005 10:47 PM Subject: Re: [WanderlodgeForum] Re: Tire > Shopping > > > SAY, I have a tire pressure question. Since you have approximately > the same front axle gross as I do,,, what air pressure do you run > your tires at??? My DUNLOP SP-160's call for 120 lbs for a max load > of 6610 lbs. Two on the front would be 13,220 lbs, close to my > gross front axle wt. Another PT 40 bird owner told me he never > runs over 105 lbs,,,,,,, What would you run ??? I have always > been told to run the max cold pressure to avoid blowouts,,,, What > is correct??? DAY 83 PT-40 Jax Fla,,,,,,,, > > > [Non-text portions of this message have been removed] > > > > ------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > [Non-text portions of this message have been removed] > > > > ------------------------ Yahoo! Groups Sponsor > --------------------~--> In low income neighborhoods, 84% do not > own computers. At Network for Good, help bridge the Digital Divide! > http://us.click.yahoo.com/B9pRWD/3MnJAA/.../pkiolB/TM > --------------------------------------------------------------------~-> > > > > Yahoo! Groups Links > > > > > > > > > |
06-04-2005, 05:40
Post: #25
Tire Shopping
working good is good!! randydupree93wb
----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Saturday, June 04, 2005 1:19 PM Subject: Re: [WanderlodgeForum] Re: Tire Shopping farm kings are his " signature" series- maybe they are power kings- heck- they work good. ernie-in Texas [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-04-2005, 10:29
Post: #26
Tire Shopping
Thanks again,
In further reviewing tire mfg. web sites, Jeff makes a good point about the different spec. for the same sizes and load ranges for the different mfg. Michelin has a XZ2 and a XZE model, Does anyone know the difference?? The spec.s seem to be about the same. Bill 88 FC I like the tire debate, still deciding to decide, can't find FarmKing in Michigan --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > They're all round and black. > > There are differences between tires, such as the 1" difference in > tread width between brands of the same size & rating, ride, rolling > resistance, quality control, etc. > > Buy what brand makes you happy, you're the one that has to pay for > them and drive on them. > > - Jeff Miller > > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > wrote: > > Well, I am still investigating possible tire replacement brands. I > > read many of the previous archive postings on the ongoing tire > > debate. Many have a strong opinion about there favorite tire > > manufacturer, especially the loyal Michelin followers. There were > > also other brands mentioned such as: Kelly, Goodyear, BF Goodrich, > > Toyo, a Les Schwab tire called Double Coin, Bridgestone etc. > > > > The 12R 22.5 load range H Michelin tires are about $500.00 each, > > installed and out the door. > > They carry a seven year / 700,000 mile manufacturer defect > warranty. > > > > We presently are quite happy with our Firestone T575 tire. This > tire > > is obsolete and no longer manufactured, the replacement Firestone > is > > FS560 or Bridgestone R250 > > > > Our questions are: > > Does anyone have experience with the Firestone FS560?? ( In the 12R > > 22.5 LRH size) > > Why should an RV owner help subsidize a seven year / 700,000 > > warranty?? > > Which brand are you happy with ?? > > > > Maybe this should be a poll? > > > > Any inputs are appreciated, > > > > Bill 88 fc |
06-04-2005, 12:08
Post: #27
Tire Shopping
Ok this may sound stupid but do you weigh each axel one at a time or do you do
the frount two axils on a scale and them the back ones together? Jon DAY8293A@... wrote:I GUESS I NEED TO FIND SOME SCALES AND WEIGH MY COACH AXLES!!!! THANKS FOR THE INFO,,, DAY JAX FLA 83 PT-40 [Non-text portions of this message have been removed] Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Discover Yahoo! Find restaurants, movies, travel & more fun for the weekend. Check it out! [Non-text portions of this message have been removed] |
06-04-2005, 12:39
Post: #28
Tire Shopping
The best way is to weigh each wheel separately and then use the
heaviest weighed wheel on an axle for determining the pressure. If you can't get each wheel weighed separately, then weigh each axle separately. I usually start out by pulling just the front axle onto the scale and then each one separately. Some scales have separate platforms so you can have the whole rig on the scale and the can give you the individual weights. Check the inflation charts at <http://www.trucktire.com> or at the Michelin web site. Both give good instructions on how to do it. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD jon lechich wrote: > Ok this may sound stupid but do you weigh each axel one at a time > or do you do the frount two axils on a scale and them the back ones > together? Jon > > DAY8293A@... wrote:I GUESS I NEED TO FIND SOME SCALES AND WEIGH > MY COACH AXLES!!!! THANKS FOR THE INFO,,, DAY JAX FLA 83 PT-40 > > > [Non-text portions of this message have been removed] > > > > > > Yahoo! Groups Links > > > > > > > > > > One of my favorite sayings goes! "You never own anything, > everything owns you!" > > > > > --------------------------------- Discover Yahoo! Find > restaurants, movies, travel & more fun for the weekend. Check it > out! > > [Non-text portions of this message have been removed] > > > > ------------------------ Yahoo! Groups Sponsor > --------------------~--> Has someone you know been affected by > illness or disease? Network for Good is THE place to support health > awareness efforts! > http://us.click.yahoo.com/0xaSZB/UOnJAA/.../pkiolB/TM > --------------------------------------------------------------------~-> > > > > Yahoo! Groups Links > > > > > > > > > |
06-04-2005, 13:03
Post: #29
Tire Shopping
Just shows to go ya that tire experience can be really personal and
not always the best way to know what's hot and what's not. Starting in 1965, I've put M's on muscle cars, sports cars, light trucks, the odd bike, and most recently the BB. Only had one failure - busted the sidewall out of a pickup tire. My fault. The dealer replaced it anyway. M's are the only tires where I've never said: "Damn I wish I'd got something else!". And, almost every other brand I've owned has given me trouble. But, I'll be the first to say I've had very good luck - and my good luch is not a good reason for anyone else to buy Michelin's. I like Jeff's advice: "Buy what you like 'cause you hafta drive 'em and ride on 'em." Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, DAY8293A@C... wrote: > HI GEORGE,,, > YOU HAVE SAID EXACTLY WHY I DON'T LIKE MICHELINS EITHER, AND > THAT IS THE ONLY ONES I HAVE EVER HAD A BLOW OUT ON. THEY REFUSED TO HONOR A > FLAT ON MY VAN, THAT I THOUGHT SHOULD HAVE BEEN UNDER THE WARRANTY, AND THEY > REFUSED. I SAID I WOULD NEVER OWN ANOTHER MICHELIN AFTER THAT, BUT MADE THE > MISTAKE OF PUTTING ONE ON MY LAST COACH, AN ITASCA, AND THAT WAS THE ONE THAT BLEW > OUT !! > NOW, I WANT ANYTHING BUT A MICHELIN,,,,, > DAY,,,,, JAX FLA, 83 PT-40 > > > [Non-text portions of this message have been removed] |
06-04-2005, 15:02
Post: #30
Tire Shopping
Jon,
Try to find a truck stop that has a split scale, similar to the Cat Scale System, you can go to their web site and see if there is one close to you; http://www.catscale.com/ While you are at their site, you can see how to weigh your 'Bird, by clicking on HOW TO WEIGH, or for FC and SP model 'Birds, just click on; http://www.catscale.com/personalmoves.shtml#STAMV If some one is weighing a PT model go to; http://www.catscale.com/howtoweigh.shtml#STA Those weighing PT models will have to do this; Drive onto the scale so that your Steer axle is positioned on platform 1, your Drive axle on platform 2 and your Tag axle on platform 3. The wheelbase of the PT models should be long enough, so that the drive axle is at the end of platform 2 and the tag axle will be at the front of platform 3. It is easier if you have someone to help you get all of the axles on the appropriate platform of the split scale. After you have the total individual axle weights, pull off of the scale and drive back around and get back up on the scale again, but this time, pull to the right, or the left just enough to get one side s tires completely off of the scale and the other side on the scale in the same position that you were the first time you weighed, then tell the scale operator that this is a re-weigh, it should cost less for the re-weigh. When you get the final scale ticket, the weights that are on the re- weigh will be the weight for those tires on that axle that were on the scale for the re-weigh, now subtract the re-weigh weights in each position from the original weight of the full axle and that will be your tire position weights, for the side that was not on the scale. Some scales have a guard rail next to the platform scales and you will not be able to pull off to one side. If you are close to an Oregon State scale, in a Ste operated weigh station and it is closed, you can still use the scale to weigh your 'Bird, as their scales are active most of the time and they have a weighed results readout, on an over head sign that you can plainly see, at least that was the way they operated two years ago. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA ///////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, jon lechich wrote: > Ok this may sound stupid but do you weigh each axel one at a time or do you do the frount two axils on a scale and them the back ones together? Jon > > DAY8293A@C... wrote:I GUESS I NEED TO FIND SOME SCALES AND WEIGH MY COACH AXLES!!!! > THANKS FOR THE INFO,,, DAY JAX FLA 83 PT-40 > > > [Non-text portions of this message have been removed] > > > > > > Yahoo! Groups Links > > > > > > > > > > One of my favorite sayings goes! "You never own anything, everything owns you!" > > > > > > --------------------------------- > Discover Yahoo! > Find restaurants, movies, travel & more fun for the weekend. Check it out! > > [Non-text portions of this message have been removed] |
