FC Air System- info needed
03-17-2009, 13:03
http://www.cruisecontrolking.com/
Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > --- In WanderlodgeForum@yahoogroups.com, cfsomers@ wrote: > > > > Who makes an electric cruise control? Mine went out 4 years ago. How > much > > work is there to install? > > > > Chuck > > > > 81SBFC > > Florida > > > > > When my vacuum generator failed I did buy a couple of vacuum > generators > > > which I had planned to use to replace the original. My memory is > that I > > > chose not to use them because none of them had the built in shut off > > > diaphragm like the Wanderlodge original. All the ones I could find > would > > > have been running constantly whereas the OE shut off when the > appropriate > > > vacuum level was reached. The OE was a part used on old Ford trucks > as I > > > recall. Perhaps an old Ford truck forum might have info on a > suitable > > > replacement. I looked for a long time for a vacuum generator with a > built > > > in shut off valve and couldn't find one. I'm sure that someone with > the > > > skills of a Cuban mechanic could adapt some kind of generator to > work. I > > > concluded an electric cruise control was a better option > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > Kerry did you ever get your cruse control to work? I just took mine > apart and cleaned up the internals and now it works perfect. But I > don't think mine has any vacumm censor device that will turn it oft and > on at a certain vacumm pressure. If there is such a device I have > never seen it on my coach. > > > > Jon > > Rebel Bird > > Bremerton washington > > > > > > > > > > > > > > > > > > |
03-17-2009, 14:48
I never use a cruise control on anything after a elderly women driver pass my
truck doing 70 in a Volvo sound a sleep. I dont have faith in my ability to avoid the same. Good news was the rock she hit kept her reckless disreguard personal. Greg of Tim&Greg 94ptCa --- In WanderlodgeForum@yahoogroups.com, cfsomers@... wrote: > > Who makes an electric cruise control? Mine went out 4 years ago. How much > work is there to install? > > Chuck > > 81SBFC > Florida > > > When my vacuum generator failed I did buy a couple of vacuum generators > > which I had planned to use to replace the original. My memory is that I > > chose not to use them because none of them had the built in shut off > > diaphragm like the Wanderlodge original. All the ones I could find would > > have been running constantly whereas the OE shut off when the appropriate > > vacuum level was reached. The OE was a part used on old Ford trucks as I > > recall. Perhaps an old Ford truck forum might have info on a suitable > > replacement. I looked for a long time for a vacuum generator with a built > > in shut off valve and couldn't find one. I'm sure that someone with the > > skills of a Cuban mechanic could adapt some kind of generator to work. I > > concluded an electric cruise control was a better option > > > > Kerry > > 82 FC 35 > > Denver > > > > > > > > > > > |
03-17-2009, 15:40
--- In WanderlodgeForum@yahoogroups.com, "Robin"
> > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, cfsomers@ wrote: > > > > > > Who makes an electric cruise control? Mine went out 4 years ago. How > > much > > > work is there to install? > > > > > > Chuck > > > > > > 81SBFC > > > Florida > > > > > > > When my vacuum generator failed I did buy a couple of vacuum > > generators > > > > which I had planned to use to replace the original. My memory is > > that I > > > > chose not to use them because none of them had the built in shut off > > > > diaphragm like the Wanderlodge original. All the ones I could find > > would > > > > have been running constantly whereas the OE shut off when the > > appropriate > > > > vacuum level was reached. The OE was a part used on old Ford trucks > > as I > > > > recall. Perhaps an old Ford truck forum might have info on a > > suitable > > > > replacement. I looked for a long time for a vacuum generator with a > > built > > > > in shut off valve and couldn't find one. I'm sure that someone with > > the > > > > skills of a Cuban mechanic could adapt some kind of generator to > > work. I > > > > concluded an electric cruise control was a better option > > > > > > > > Kerry > > > > 82 FC 35 > > > > Denver > > > > > > > > > > > > Kerry did you ever get your cruse control to work? I just took mine > > apart and cleaned up the internals and now it works perfect. But I > > don't think mine has any vacumm censor device that will turn it oft and > > on at a certain vacumm pressure. If there is such a device I have > > never seen it on my coach. > > > > > > > > Jon > > > > Rebel Bird > > > > Bremerton washington > > JON- > > Did you just do your vac generator or did you do the whole cruise mechanism. Mine does not work either. Mechanic said it was not worth fooling with (probably true at his rate). I need another project to put on the list. > > John Churchill > 1980 FC33 > LARGE MARGE > Sanibel, FL Well it wouldn't hurt just to take it out and clean it up. Its not a very hard job to do and what the hell maybe it might just start working again. Mine was frozen up and just need the internal vains cleaned up and lubracated. Works like a champ. The only thing wrong with these old cruise controls it just takes it time to set the speed at which you want to set it at. If I want to set it at 60 mph I usally speed up to 65 and engage the cruse control and by the time it starts to go on cruse control its usally at 60 mph. Jon > |
03-18-2009, 02:03
