					Shock mount failure
					03-10-2009, 08:43
Post: #51
				Shock mount failure
					Dan,
			Additional stress is only created if you lift a tire off the ground via the jacks and the suspension is still aired up. Of course, under most circumstances, the height control valve should dump air, but this takes time and in the meantime the air spring is fighting against the shock and shock mount. David Brady '02 LXi, NC -----Original Message-----  |
					03-10-2009, 09:52
Post: #52
				Shock mount failure
					If I understand correctly, that raises the front of the coach. If the air bags are inflated, it can put 13,000 lbs pressure on the shock mount (from the air pressure in the bag) with the maximum pressure achieved if the front tires are lifted completely off the ground (as sometimes is the case).
			Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Mar 10, 2009, at 12:30 PM, Dan Williams wrote:
					03-10-2009, 11:56
Post: #53
				Shock mount failure
					I also believe that the stress cracking comes from extension not compression of
			the suspension. When my coach was lifted up on the front end the broken piece pulled away when lowered it you could barely see the fracture lines on the mounts. I just basically reseated itself in it's original position. I doubt that anything we could do intentionally would cause such a fracture. Air in or out of the airbags lifted with the jacks or not. A constant pressure of 13000 LB is not the same as 13000lb rebounding and extending at 60 MPH. Perhaps dropping the jacks on empty airbags could do it, when it hits bottom it hits hard, real hard. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > If I understand correctly, that raises the front of the coach. If the > air bags are inflated, it can put 13,000 lbs pressure on the shock > mount (from the air pressure in the bag) with the maximum pressure > achieved if the front tires are lifted completely off the ground (as > sometimes is the case). > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 (For Sale) > <http://www.aeonix.biz/BBforsale.html> > El Sobrante CA > aeonix1@... > > > > > On Mar 10, 2009, at 12:30 PM, Dan Williams wrote: > > > Pete, I may be getting in on this late, but how does lowering the > > leveling jacks with the suspension still aired up put stress on the > > front shocks and mounts? > > Dan Williams, 88WB38, Jackson, MS > > > > From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com > > ] On Behalf Of Pete Masterson > > Sent: Tuesday, March 10, 2009 12:20 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: Re: [WanderlodgeForum] Re: Shock mount failure > > > > There is a sub-frame that holds the shock mount, air bag, and other > > parts of the front end. It's a piece that's about 24 to 30 inches > > long. That piece comes from Ridewell. (Although Ridewell might claim > > that Blue Bird provided the specification.) The speculation is that > > the Ridewell piece is not thick enough (or otherwise not > > sufficiently strong) to take the constant hammering. > > > > > > Awhile back on one or the other WL lists, someone reported that > > lowering the leveling jacks with the suspension still aired up puts > > an unusually large stress on the front shocks and mounts. That may > > start the weakening process. However, I know that it was rare for me > > to forget to dump the suspension before I leveled the coach. > > > > Before the complete failure of my shock mount, I'd noticed a > > 'popping' noise in the front end when encountering the porpoising > > movement that occurs after passing over one of the multitude of > > ground subsidence undulations that are frequently found on the > > freeways, especially in the SF Bay Area where the highways are > > frequently built on fill (near the bay) or unstable clay soils > > (nearly everywhere else in the area). Later I realized that the > > noise was cause by the flexing of the split (and eventually broken) > > piece of the Ridewell sub-assembly. (The acoustics caused it to > > sound like it came from the opposite side.) > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 (For Sale) > > <http://www.aeonix.biz/BBforsale.html> > > El Sobrante CA > > aeonix1@... > > > > > > > > On Mar 9, 2009, at 7:40 PM, Don Bradner wrote: > > > > > > Did your tear look at all like mine (mine looks almost exactly like > > Pete's)? Presumption is that the slamming downward when the wheel > > bottoms into a pothole or similar is the issue. Countless slams, and > > the metal gives way. Note that it is not the frame, but rather the > > steel mounted to the frame - that steel is a part of the axle > > assembly and was presumably not welded by BB. > > > > The repair done on mine comes close to matching the original > > assembly, making it possible/likely that sometime in the next 20 > > years it will fail again. I'm going to try to remember to stick a > > camera in there for photos every few months (more often to begin > > with!) that it is driven. > > > > On 3/10/2009 at 2:22 AM Eric Perplies wrote: > > > > > > My front left shock mount broke just before the Q rally in 08. CCW in > >> Riverside fixed mine shortly after the Q rally. On my coach the > >> shock > >> mount ripped out a chunk of metal on the frame. A piece of steel > >> about > >> 1/2" x 8" x 6" was welded onto my frame. A hole was drilled in it to > >> accommodate the brake air line. The original shock mount with it's > >> three > >> gussets were removed from the broken out piece. That original > >> shock mount > >> was then welded back onto the 1/2" plate mentioned above. > >> > >> The welds made during the repair were VERY thorough. There was an > >> indication that the original BB welds may not have been as through > >> as they > >> could have been. (One side of one of the gussets had not been > >> welded onto > >> the frame.) That having been said this could not be the reason for > >> the > >> failure. After all the frame on my coach had a section ripped out > >> of it. > >> The shock mount itself did not fail. > >> > >> A far more interesting question is: What causes the failures on > >> the shock > >> mounts? > > > > > > > > > > >  |
					03-10-2009, 12:55
Post: #54
				Shock mount failure
					The primary jolt I hear/feel is when the wheel drops into a pothole. There are a
			lot of potholes in the US, and I feel like I've hit 80% of 'em! Dropping into a pothole at the full pressure of the airbag puts all of the force in the extension direction. Each of the breaks documented so far tear *down*, never up. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 3/10/2009 at 7:30 PM david brady wrote: >If the tires stay on the ground, not "getting air" on the Nimitz >in Ca, the max shock force is 4000lb (according to Justin at >Koni), and all of that force occurs under rebound; i.e, the Koni >shocks provide no, or negligible, compression dampening. >IOW's all the forces are in the extension direction. That's not >to say that the initial damage hadn't occurred under compression. >It's just that for it to occur under compression something weird >has to happen, like shocks that are too long, or dumping the >HWH jacks w/o air in the bags. Once the initial damage >has occurred, then normal shock loads add to the metal fatigue >and the ultimate failure.  |
					03-10-2009, 13:30
Post: #55
				Shock mount failure
				 If the tires stay on the ground, not "getting air" on the Nimitz in Ca, the max shock force is 4000lb (according to Justin at Koni), and all of that force occurs under rebound; i.e, the Koni shocks provide no, or negligible, compression dampening. IOW's all the forces are in the extension direction. That's not to say that the initial damage hadn't occurred under compression. It's just that for it to occur under compression something weird has to happen, like shocks that are too long, or dumping the HWH jacks w/o air in the bags. Once the initial damage has occurred, then normal shock loads add to the metal fatigue and the ultimate failure. Kurt Horvath wrote:
