Musical horn module
02-16-2009, 13:36
Musical horn module
Sorry,i posted this with wrong subject line
Trying to find the location of my musical hornmodule.There is a blue ribbon wire at the switches that goes into an abyss up under the dash and disappears.
I assume it is behind the lower dash but if someone knows for certain I might save a little time.
Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 |
02-16-2009, 14:37
Musical horn module
Our coaches are far apart year-wise, but mine is located behind the
panel in front of the co-pilot seat. It's a metal box about the size of 2 decks of cards side by side. Wouldn't surprise me if yours is there, too. Had mine reprogrammed 2 years ago. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote: > > Sorry,i posted this with wrong subject line > > Trying to find the location of my musical horn module.There is a blue ribbon wire at the switches that goes into an abyss up under the dash and disappears. > I assume it is behind the lower dash but if someone knows for certain I might save a little time. > > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > |
02-16-2009, 14:49
Musical horn module
Hi Scott
Thanks for responding,you are referring to the panel below the dashboard?
Fred & Jeanne Hulse
02-16-2009, 14:51
Musical horn module
Hi ya Fred,
Mine is located inside the small locker, below the the radio/rear view monitor. It is in the EXTREME rear of the locker, up high, on the right side. After removing the door I could just reach the module. I identified mine by the wide ribbon connector that plugs into it. If I recall correctly there is a second smaller ribbon connector also connected to the module. Good luck and happy trails, Eric Perplies 96 42 WBWL |
02-16-2009, 15:20
Musical horn module
Hey Eric,
Thank you for the location,
I just went out and waded through a/c ducting and other things under there and located it!
Tomorrow I will see how to get it out successfully.
Missed you guys @ Quartzsite.
Fred & Jeanne Hulse
02-17-2009, 02:37
Musical horn module
02-17-2009, 02:53
Musical horn module
Hi Ron
The fuse is labeled#50 outsidein the front load center.
Fred & Jeanne Hulse
02-17-2009, 03:05
Musical horn module
02-17-2009, 03:14
Musical horn module
Ron
You are correct.
The load center is behind that wide body panel above the headlites.
I think your coach has those aircraft style screws that twist90 degrees to release.
Fred & Jeanne Hulse
02-17-2009, 03:20
Musical horn module
