M380 hot water
05-31-2005, 21:00
M380 hot water
04 M380
I will be taking the coach to the factory for an appointment on 6 June. My wife Lindsey will be staying with it there. How does one do the hot water without having the whole hurricane heating system on, i.e. heating hot water with just electric without burning diesel? I thought I had it figured out by having two of the hot water circuit breakers on but was only able to get about 10 seconds of hot water. How does LX/LXI do it? Thanks, Jim |
06-01-2005, 01:10
M380 hot water
From what I was told by two other owners of M380s at the factory, no
Hurricane on not hotwater. Same with the M450 Tom 1982 FC35 Vernon Center,NYAt 09:00 AM 6/1/2005 +0000, you wrote: >04 M380 > >I will be taking the coach to the factory for an appointment on 6 >June. My wife Lindsey will be staying with it there. How does one do >the hot water without having the whole hurricane heating system on, >i.e. heating hot water with just electric without burning diesel? I >thought I had it figured out by having two of the hot water circuit >breakers on but was only able to get about 10 seconds of hot water. > >How does LX/LXI do it? > >Thanks, >Jim > > > > > > > > >Yahoo! Groups Links > > > > |
06-01-2005, 01:33
M380 hot water
Hi Jim,
--- scoggins_jim <scoggins.j@...> wrote: > 04 M380 > > How does one do > the hot water without having the whole hurricane > heating system on, > i.e. heating hot water with just electric without > burning diesel? I > thought I had it figured out by having two of the > hot water circuit > breakers on but was only able to get about 10 > seconds of hot water. > How does LX/LXI do it? I would guess the M380 would be similar to the LXi. The LXi Aqua-Hot system electric portion has a circuit breaker in the main panel and a diesel master control switch on the dash (generally labeled "hydronic..."). When the coach engine in not running, and all switches are on, electric is the primary heating source, next, diesel - meaning the diesel will fire to a certain temp (along with the elect) and the elect will "top it off," if necessary. Said another way, if hot water consumption reduces the temp below the elect temp maintenance level, the diesel unit will fire. During winter heating months, one way to reduce the chance of running out of hot water during a shower, is to use both diesel and elect to heat the water; and turn off the main coach heating control switch located in the kitchen wall thermostat. Trying to heat both the coach and the shower water for those few shower minutes using a 50,000 max BTU burner is "pushing string uphill." John Suter 2000 LXi __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
06-01-2005, 02:18
M380 hot water
John are you commenting on the older LXI or the M450 which I believe is
also designated as the LXI? I was told by an owner of a 2003 M450 at Ft. Valley in February that his coach did not have the capability to heat hot water other then the diesel. No electric element and no engine heating. I was told that it was an option. I still wonder if the man was correct? Tom 1982 FC35 \Vernon Center,NY At 06:33 AM 6/1/2005 -0700, you wrote: >Hi Jim, > >--- scoggins_jim <scoggins.j@...> wrote: > > 04 M380 > > > > How does one do > > the hot water without having the whole hurricane > > heating system on, > > i.e. heating hot water with just electric without > > burning diesel? I > > thought I had it figured out by having two of the > > hot water circuit > > breakers on but was only able to get about 10 > > seconds of hot water. > > > How does LX/LXI do it? > > I would guess the M380 would be similar to the LXi. >The LXi Aqua-Hot system electric portion has a circuit >breaker in the main panel and a diesel master control >switch on the dash (generally labeled "hydronic..."). >When the coach engine in not running, and all switches >are on, electric is the primary heating source, next, >diesel - meaning the diesel will fire to a certain >temp (along with the elect) and the elect will "top it >off," if necessary. Said another way, if hot water >consumption reduces the temp below the elect temp >maintenance level, the diesel unit will fire. > > During winter heating months, one way to reduce the >chance of running out of hot water during a shower, is >to use both diesel and elect to heat the water; and >turn off the main coach heating control switch located >in the kitchen wall thermostat. Trying to heat both >the coach and the shower water for those few shower >minutes using a 50,000 max BTU burner is "pushing >string uphill." > >John Suter >2000 LXi > > > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around >http://mail.yahoo.com > > > > >Yahoo! Groups Links > > > > |
06-01-2005, 04:54
M380 hot water
HI JIM,,,, I WISH I COULD HELP YOU, BUT I DON'T HAVE AN M380. MY
BIRD ONLY HAS AN ELECTRIC HOT WATER HEATER, SO I NEVER HAVE THAT PROBLEM. SORRY ,,,,, DAY,,,, [Non-text portions of this message have been removed] |
06-01-2005, 12:55
M380 hot water
--- In WanderlodgeForum@yahoogroups.com, DAY8293A@C... wrote:
> HI JIM,,,, I WISH I COULD HELP YOU, BUT I DON'T HAVE AN M380. MY > BIRD ONLY HAS AN ELECTRIC HOT WATER HEATER, SO I NEVER HAVE THAT PROBLEM. SORRY > ,,,,, DAY,,,, > > > yeah right now i wish i "just" had an electric hot water heater. |
06-01-2005, 13:12
M380 hot water
We have been moving and I have just gotten the computer hooked up and
noticed the thread on the M380 hot water. The M380 does have electric heating elements in the hot water system. I believe there are 2 breakers in the bedroom load center marked as such. I have never tried to use the alone to provide hot water but was told by the trainer at BlueBird that they were used to "boost" the hot water if needed. Believe me I have never needed to boost the hurricane heaters hot water, just the opposite. It might be worth a try to see if the electrical elements would provide adequate hot water. As an aside, I have never been able to store a coach at home until this move. I can already tell it is certainly going to be nice to be able to do those little things to the coach without having to spend so much time traveling back and forth. Nect comes the garage and shop. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "scoggins_jim" <scoggins.j@a...> wrote: > --- In WanderlodgeForum@yahoogroups.com, DAY8293A@C... wrote: > > HI JIM,,,, I WISH I COULD HELP YOU, BUT I DON'T HAVE AN > M380. MY > > BIRD ONLY HAS AN ELECTRIC HOT WATER HEATER, SO I NEVER HAVE THAT > PROBLEM. SORRY > > ,,,,, DAY,,,, > > > > > > yeah > right now i wish i "just" had an electric hot water heater. |
