					FEDERAL SMOG LAWS
					12-11-2008, 10:29
				FEDERAL SMOG LAWS
					Hi all,
			I'm going to jump in on this issue. I receive email updates from the California Air Resources Board regarding its regulations. Below are excerpts of the latest Draft Proposed Regulation (dated Dec. 11, 2008) update email from the California Air Resources Board: <http://www.arb.ca.gov/msprog/onrdiesel/d...ment_C.pdf> "DRAFT PROPOSED REGULATION TO REDUCE EMISSIONS OF DIESEL PARTICULATE MATTER, AND OTHER POLLUTANTS FROM IN-USE HEAVY-DUTY DIESEL-FUELED VEHICLES Adopt new section 2025, in title 13, article 4.5, chapter 1, California Code of Regulations (CCR) to read as follows: (Note that the entire text of section 2025 set forth below is new language proposed to be added to the California Code of Regulations.) Section 2025. Regulation to Reduce Emissions of Diesel Particulate Matter, Oxides of Nitrogen and Other Criteria Pollutants, and Greenhouse Gases from In-Use Heavy-Duty Diesel-Fueled Vehicles... © Exemptions This regulation does not apply to: (11) Motor homes for non-commercial private use... (d) Definitions For purposes of this regulation, the following definitions apply: (44) "Motorcoach (MC)" is a for hire, on-road motor vehicle having an under floor luggage compartment separate from the passenger cabin used for conveying passengers, is at least 35 feet in length, and is designed for and has seating capacity for 40 or more passengers. (45) "Motor Carrier" is the same as defined in California Veh. Code section 408 for fleets other than those that are comprised entirely of schoolbuses, which for the purposes of this regulation, means the registered owner, lessee, licensee, school district superintendent, or bailee of any schoolbus, who operates or directs the operation of any such bus on either a for-hire or not-for-hire basis. (46) "Motor Home" means a single vehicular unit designed for human habitation for recreational or emergency occupancy and built on, or permanently attached to, a self-propelled motor vehicle chassis, chassis cab, or van, which becomes an integral part of the completed vehicle." The bottom line -- SECTION 2025, ©(11) specifically exempts motor homes. SECTION 2025, (d)(44) and (45) defines a motorcoach and motor carrier that operates a motorcoach. SECTION 2025, (d)(46) defines a motor home. As clearly stated, motor homes ARE NOT required under the proposed regulations to modify, repower, or install any smog controls. HOWEVER, if you use your motor home to conduct a business, as defined by the California Code, you will probably be covered by the regulations. I'll be posting a link to the CARB site that lists all the draft regulation proposals on the SWBB website. Phil Corpus "iWander" 85PT40 Left Coast http://southwest-bluebirds.org  |
					12-11-2008, 10:53
				FEDERAL SMOG LAWS
					12-11-2008, 11:20
				FEDERAL SMOG LAWS
					Hi Wallace,
			Thanks. Christina and I are still hoping you'll make it to Quartzsite. It's going to be quite a party this time. I have a couple of surprises that I'm working on and hope to spring on everyone. Phil 'iWander' 85pt40 --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > Phil; many thanks for getting this information and passing it along. This seems to be the true word and should dispel much of the rumor mill. > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > --- On Thu, 12/11/08, iwander_85pt40 > > From: iwander_85pt40 > To: WanderlodgeForum@yahoogroups.com > Date: Thursday, December 11, 2008, 4:29 PM > > Hi all, > > I'm going to jump in on this issue. > > I receive email updates from the California Air Resources Board > regarding its regulations. > > Below are excerpts of the latest Draft Proposed Regulation (dated Dec. > 11, 2008) update email from the California Air Resources Board: > > <http://www.arb.ca.gov/msprog/onrdiesel/d...ment_C.pdf> > > > "DRAFT PROPOSED REGULATION TO REDUCE EMISSIONS OF > DIESEL PARTICULATE MATTER, AND OTHER POLLUTANTS > FROM IN-USE HEAVY-DUTY DIESEL-FUELED VEHICLES > > Adopt new section 2025, in title 13, article 4.5, chapter 1, > California Code of Regulations (CCR) to read as follows: (Note that > the entire text of section 2025 set forth below is new language > proposed to be added to the California Code of Regulations.) > > Section 2025. Regulation to Reduce Emissions of Diesel Particulate > Matter, Oxides of Nitrogen and Other Criteria Pollutants, and > Greenhouse Gases from In-Use Heavy-Duty Diesel-Fueled Vehicles... > > © Exemptions > This regulation does not apply to: > > (11) Motor homes for non-commercial private use... > > (d) Definitions > For purposes of this regulation, the following definitions apply: > > (44) "Motorcoach (MC)" is a for hire, on-road motor vehicle having an > under floor luggage compartment separate from the passenger cabin used > for conveying passengers, is at least 35 feet in length, and is > designed for and has seating capacity for 40 or more passengers. > > (45) "Motor Carrier" is the same as defined in California Veh. Code > section 408 for fleets other than those that are comprised entirely of > schoolbuses, which for the purposes of this regulation, means the > registered owner, lessee, licensee, school district superintendent, or > bailee of any schoolbus, who operates or directs the operation of any > such bus on either a for-hire or not-for-hire basis. > > (46) "Motor Home" means a single vehicular unit designed for human > habitation for recreational or emergency occupancy and built on, or > permanently attached to, a self-propelled motor vehicle chassis, > chassis cab, or van, which becomes an integral part of the completed > vehicle." > > The bottom line -- > > SECTION 2025, ©(11) specifically exempts motor homes. > > SECTION 2025, (d)(44) and (45) defines a motorcoach and motor carrier > that operates a motorcoach. > > SECTION 2025, (d)(46) defines a motor home. > > As clearly stated, motor homes ARE NOT required under the proposed > regulations to modify, repower, or install any smog controls. > > HOWEVER, if you use your motor home to conduct a business, as defined > by the California Code, you will probably be covered by the regulations. > > I'll be posting a link to the CARB site that lists all the draft > regulation proposals on the SWBB website. > > Phil Corpus > "iWander" 85PT40 > Left Coast > http://southwest-bluebirds.org > > > > > > ------------------------------------ > > Yahoo! Groups Links >  |
