					Parking brake knob
					05-26-2005, 14:10
Post: #21
				Parking brake knob
					Probably NAPA also.
			- Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > Any truck-part shop should be able to help you, I buy from a fleet > supplier but a Kenworth store, bus service, etc. You are looking for a > parking brake button for the Bendix PP-1 valve. > > - Jeff Miller > http://www.wanderlodge.net > > > --- In WanderlodgeForum@yahoogroups.com, jon lechich > wrote: > > Jeff where can I just locate the knob that goes on the shaft that > opperates the air brake? Right now I just have a shaft and a D ring and > that's it. Can you help me? Jon  |
					05-26-2005, 17:11
Post: #22
				Parking brake knob
					Thanks a heap! Jon
			Jeff Miller help you, I buy from a fleet supplier but a Kenworth store, bus service, etc. You are looking for a parking brake button for the Bendix PP-1 valve. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, jon lechich wrote: > Jeff where can I just locate the knob that goes on the shaft that opperates the air brake? Right now I just have a shaft and a D ring and that's it. Can you help me? Jon Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Yahoo! Mail Mobile Take Yahoo! Mail with you! Check email on your mobile phone. [Non-text portions of this message have been removed]  |
					05-27-2005, 15:19
Post: #23
				Parking brake knob
			wrote: > It's easiest from below the dash, it is open to the bottom. The hard > part is swinging the wrenches, a crow's-foot tubing wrench on a short > extension makes it work. > > Opening the front panel doesn't help, you can barely see it from the > front. Similarly, opening the top of the dash gives a good view of the > valve, but the fittings are on the bottom & side. Leave the dash in IMO. > > - Jeff Miller Jeff, I know what a crow's-foot wrench is...by tubing wrench do you mean a flare nut wrench? Is this a shop fabricated tool, a Snap On goodie or an off-the-shelf item from Sears, Napa or...? BTW, our parking brake is now working - 'Bird is going into the shop next week. Last mechanic who cut a water line to get the parking brake to work was fired. Seems he wasn't qualified!? I'm hoping the new guy can service the air dryer without disconnecting the LP tank :^0 Jim Owens 77 FC33SB (Gas) Lake of the Ozarks, MO  |
					05-27-2005, 15:30
Post: #24
				Parking brake knob
					look for rigid tubing wrenches they rachet and only need about a 10
			degree arc to work used primarily in hvac work Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jim Owens" wrote: > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > wrote: > > It's easiest from below the dash, it is open to the bottom. The > hard > > part is swinging the wrenches, a crow's-foot tubing wrench on a > short > > extension makes it work. > > > > Opening the front panel doesn't help, you can barely see it from > the > > front. Similarly, opening the top of the dash gives a good view of > the > > valve, but the fittings are on the bottom & side. Leave the dash in > IMO. > > > > - Jeff Miller > > Jeff, > > I know what a crow's-foot wrench is...by tubing wrench do you mean a > flare nut wrench? Is this a shop fabricated tool, a Snap On goodie or > an off-the-shelf item from Sears, Napa or...? > > BTW, our parking brake is now working - 'Bird is going into the shop > next week. Last mechanic who cut a water line to get the parking > brake > to work was fired. Seems he wasn't qualified!? I'm hoping the new guy > can service the air dryer without disconnecting the LP tank :^0 > > Jim Owens 77 FC33SB (Gas) > Lake of the Ozarks, MO  |
					05-27-2005, 22:44
Post: #25
				Parking brake knob
			wrote: > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > wrote: > > It's easiest from below the dash, it is open to the bottom. The > hard > > part is swinging the wrenches, a crow's-foot tubing wrench on a > short > > extension makes it work. > > > > Opening the front panel doesn't help, you can barely see it from > the > > front. Similarly, opening the top of the dash gives a good view of > the > > valve, but the fittings are on the bottom & side. Leave the dash in > IMO. > > > > - Jeff Miller > > Jeff, > > I know what a crow's-foot wrench is...by tubing wrench do you mean a > flare nut wrench? Jim, That's exactly what it is. It's a 6 point box-end wrench that's been cut enough to slip the tubing through so you can get a good grip on the flare nut, usually brass and soft. The tubing wrench is made a lot heavier on the end to keep it from opening up under a lot of stress. I've used the craftsman brand in the past and found them to fit too loosely to be any good. The Snap-On brand is a tight fit and works well. Haven't tried any other brands, but when you find the right one it will fit snugly on the nut. >Is this a shop fabricated tool, a Snap On goodie or > an off-the-shelf item from Sears, Napa or...? Uh, yeah. ;o) George Witt 81 FC 35 Lincoln, Nebraska--Huskers Host for the August 7 Nebraska Parking Lot Rally > > BTW, our parking brake is now working - 'Bird is going into the shop > next week. Last mechanic who cut a water line to get the parking > brake > to work was fired. Seems he wasn't qualified!? I'm hoping the new guy > can service the air dryer without disconnecting the LP tank :^0 > > Jim Owens 77 FC33SB (Gas) > Lake of the Ozarks, MO  |
					05-29-2005, 13:06
Post: #26
				Parking brake knob
					ok,must be something wrong............randy
			----- Original Message ----- From: "Curt Sprenger" To: Sent: Thursday, May 26, 2005 7:53 PM Subject: Re: [WanderlodgeForum] Parking brake knob > Randy, I just got this message and it's dated May 24...received a couple > other messages earlier today from you that were also dated a day or two > back. > > Curt Sprenger â87PT38, Anaheim, Calif. > > > randydupree wrote: > >> is it easier if you open the front panel? randydupree93wb >> ----- Original Message ----- >> From: racin41@... >> To: WanderlodgeForum@yahoogroups.com >> Sent: Tuesday, May 24, 2005 3:31 PM >> Subject: Re: [WanderlodgeForum] Parking brake knob >> > > > > > > Yahoo! Groups Links > > > > > > >  |
					05-29-2005, 13:06
Post: #27
				Parking brake knob
					ok! randy
			----- Original Message ----- From: Jeff Miller To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 26, 2005 7:55 PM Subject: [WanderlodgeForum] Re: Parking brake knob It's easiest from below the dash, it is open to the bottom. The hard part is swinging the wrenches, a crow's-foot tubing wrench on a short extension makes it work. Opening the front panel doesn't help, you can barely see it from the front. Similarly, opening the top of the dash gives a good view of the valve, but the fittings are on the bottom & side. Leave the dash in IMO. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, randydupree > is it easier if you open the front panel? randydupree93wb ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed]  |
