					PT 40, 42 & 43 owners. A ? about your tire size
					08-30-2008, 15:45
					After a 2 hour web search I can not find anybody that makes a tire in
			315 75R 22.5. Everybody has a 315 80R 22.5 they are about 1" wider than a 12R 22.5 & 11.3" Vs 12.5" in width, and the 315's are a little shorter,19.6" Vs 19.8" loaded radius, overall diameter is the same @ 42.4", they both use 9" rims, the 315's have a 1700lbs single wheel higher capacity and a 1465lbs higher dual wheel capacity, per tire. The only thing I see as a problem may be the dual wheel spacing. 13.2" for the 12R and 14.1" for the 315's. The only other difference is revolutions per mile, I'd say insignificant @ 2 RP Mile. Info from B.F.Goodrich. The only chart I could find without bouncing all over the web I've seen several size tires on comparable birds PT 40,42,& 43's, I've seen coaches with 11R 22.5, and the coach for sale on e-bay states it has 315's on it.. Convention wisdom states all tires should be of the same size & Mfg. I would like to have the heavier tires on the steer axles. I don't think 1/2 inch wider on each side of the tire in the front wheel wells would make a difference, though it is already a tight fit., and I'm not sure if the larger tires would have an adverse effect on the overall drive ability. I'm hoping for better control , higher capacity and the added safety in a more capable tire. Any thoughts? Kurt Horvath 95 PT-42 10AC  |
					08-30-2008, 17:34
					Are your wheels rated for the higher pressures and weight loading of
			the LRJ and LRL tires? My 8.25x22.5 wheels are only rated to 120 psi and 7000 lbs. I opted for 295/80R22.5 G670RVs recently when I couldn't find 12Rs from an acceptable manufacturer. M.R.Kane 1987 PT40 1985 PT40 for sale currently Clarkston, WA  |
					08-31-2008, 00:27
					Hi
			Prevost runs 365x 70 on the front and tag with 315x 80 on the drives Ross > Convention wisdom states all tires should be of the same size & Mfg. >  |
					08-31-2008, 03:17
					Kurt, proverbialy you always try and reinvent the wheel, now you
			crossed the line. Stay with 12's. steer tires on many commercial rigs are different than drive tires (tag and power axle). I stick with the 12R's because the actual size seem closer MFG to MFG and they are easier to find than metric (I think Sears started metric just to sell 2 sets and an extra drawer). If you set up a rotation purchase of tires you can always have new tires on the steer. I like to drop new upfront because I think slow turning and stationary turning on hot asphalt can cause ply adhersion/seperation issues. Regroovable tires always seem to be built for the market that puts the tires to the test so I try and find regroovables (but have never had them grooved). I always feared that the comfort ride claims of Mitch' tire design have compramised the build but that may just be a way for me to justify not paying the extra 100 per the tire Mitch charge. If you want my opinion, you have 8 good tires now. I would not add more than 2 per the year. new upfront, the old front to one side of the drive axle or the other side or split them up on the tags. This would leave you with only the choice for 12's. no need to rotate the tires around the back and height is not an issue from side to side because the differential knows not to spin both sides the same. Some think tire size overworks the diff ans screws with the ring gear, I think it is worked by bad shocks or uneven roads. --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" wrote: > > After a 2 hour web search I can not find anybody that makes a tire in > 315 75R 22.5. > Everybody has a 315 80R 22.5 they are about 1" wider than a 12R 22.5 > & 11.3" Vs 12.5" in width, and the 315's are a little shorter,19.6" > Vs 19.8" loaded radius, overall diameter is the same @ 42.4", they > both use 9" rims, the 315's have a 1700lbs single wheel higher > capacity and a 1465lbs higher dual wheel capacity, per tire. > The only thing I see as a problem may be the dual wheel spacing. > 13.2" for the 12R and 14.1" for the 315's. The only other difference > is revolutions per mile, I'd say insignificant @ 2 RP Mile. Info from > B.F.Goodrich. The only chart I could find without bouncing all over > the web > I've seen several size tires on comparable birds PT 40,42,& 43's, > I've seen coaches with 11R 22.5, and the coach for sale on e-bay > states it has 315's on it.. > Convention wisdom states all tires should be of the same size & Mfg. > I would like to have the heavier tires on the steer axles. I don't > think 1/2 inch wider on each side of the tire in the front wheel > wells would make a difference, though it is already a tight fit., and > I'm not sure if the larger tires would have an adverse effect on the > overall drive ability. I'm hoping for better control , higher > capacity and the added safety in a more capable tire. > Any thoughts? > > Kurt Horvath > 95 PT-42 > 10AC >  |
					08-31-2008, 04:35
					Kurt  is not reinventing the wheel Just trying to find the proper size
			Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Kurt, proverbialy you always try and reinvent the wheel, now you > crossed the line. Stay with 12's. > > steer tires on many commercial rigs are different than drive tires > (tag and power axle). I stick with the 12R's because the actual size > seem closer MFG to MFG and they are easier to find than metric (I > think Sears started metric just to sell 2 sets and an extra > drawer). > > If you set up a rotation purchase of tires you can always have new > tires on the steer. I like to drop new upfront because I think slow > turning and stationary turning on hot asphalt can cause ply > adhersion/seperation issues. Regroovable tires always seem to be > built for the market that puts the tires to the test so I try and > find regroovables (but have never had them grooved). I always > feared that the comfort ride claims of Mitch' tire design have > compramised the build but that may just be a way for me to justify > not paying the extra 100 per the tire Mitch charge. > > If you want my opinion, you have 8 good tires now. I would not add > more than 2 per the year. new upfront, the old front to one side of > the drive axle or the other side or split them up on the tags. This > would leave you with only the choice for 12's. no need to rotate the > tires around the back and height is not an issue from side to side > because the differential knows not to spin both sides the same. > Some think tire size overworks the diff ans screws with the ring > gear, I think it is worked by bad shocks or uneven roads. --- In > WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > wrote: > > > > After a 2 hour web search I can not find anybody that makes a tire > in > > 315 75R 22.5. > > Everybody has a 315 80R 22.5 they are about 1" wider than a 12R > 22.5 > > & 11.3" Vs 12.5" in width, and the 315's are a little > shorter,19.6" > > Vs 19.8" loaded radius, overall diameter is the same @ 42.4", they > > both use 9" rims, the 315's have a 1700lbs single wheel higher > > capacity and a 1465lbs higher dual wheel capacity, per tire. > > The only thing I see as a problem may be the dual wheel spacing. > > 13.2" for the 12R and 14.1" for the 315's. The only other > difference > > is revolutions per mile, I'd say insignificant @ 2 RP Mile. Info > from > > B.F.Goodrich. The only chart I could find without bouncing all > over > > the web > > I've seen several size tires on comparable birds PT 40,42,& 43's, > > I've seen coaches with 11R 22.5, and the coach for sale on e-bay > > states it has 315's on it.. > > Convention wisdom states all tires should be of the same size & > Mfg. > > I would like to have the heavier tires on the steer axles. I don't > > think 1/2 inch wider on each side of the tire in the front wheel > > wells would make a difference, though it is already a tight fit., > and > > I'm not sure if the larger tires would have an adverse effect on > the > > overall drive ability. I'm hoping for better control , higher > > capacity and the added safety in a more capable tire. > > Any thoughts? > > > > Kurt Horvath > > 95 PT-42 > > 10AC > > >  |
					08-31-2008, 05:06
					OH Gregg !,  I'm just trying to make what I've got better, Ya know be
			all that you can be and all that trash. I'll talk with my tire shop about rotational purchasing sounds like a winner. Anyway after a little more research I found that any advantage is lost with a 8.25 inch rim, which is the size on my coach. The capacities are reduced to MOL the same specs. I wish all my tires were good. I put two new steers on it last year and within 1000 mile hit a coral rock leaving an RV park in the Fla. Keys and put a nice slice in the side wall. That didn't bother me much until I measured the depth of the cut, over .250 thousandths, That's a ¼ " :{ I've been running on it, but now it's starting to bother me. The other issue is availability. 12R22.5's are or were hard to find, last Oct. I had a side wall blowout in Texas. The dealers could only find 2 Michelin XZE* in 12R22.5 in the country, they were in Sacramento. Now I've got an over priced Goodyear G149 RSA on the coach. Ticked me off I just had all the tires matched up and running good. So you are right gonna stick with the 12's, get two new steers and put the one good steer in place of my oldest tire. I guess I might throw the cut tire in the trailer for a spare. It would get me home and I wouldn't be held hostage to buy whatever is available on the side of the road. I've got a great picture of Cavemen beating on a square rock trying to turn it into a wheel, need to send to you LOL :} Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Kurt, proverbialy you always try and reinvent the wheel, now you > crossed the line. Stay with 12's. > > steer tires on many commercial rigs are different than drive tires > (tag and power axle). I stick with the 12R's because the actual size > seem closer MFG to MFG and they are easier to find than metric (I > think Sears started metric just to sell 2 sets and an extra > drawer). > > If you set up a rotation purchase of tires you can always have new > tires on the steer. I like to drop new upfront because I think slow > turning and stationary turning on hot asphalt can cause ply > adhersion/seperation issues. Regroovable tires always seem to be > built for the market that puts the tires to the test so I try and > find regroovables (but have never had them grooved). I always > feared that the comfort ride claims of Mitch' tire design have > compramised the build but that may just be a way for me to justify > not paying the extra 100 per the tire Mitch charge. > > If you want my opinion, you have 8 good tires now. I would not add > more than 2 per the year. new upfront, the old front to one side of > the drive axle or the other side or split them up on the tags. This > would leave you with only the choice for 12's. no need to rotate the > tires around the back and height is not an issue from side to side > because the differential knows not to spin both sides the same. > Some think tire size overworks the diff ans screws with the ring > gear, I think it is worked by bad shocks or uneven roads. --- In > WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > wrote: > > > > After a 2 hour web search I can not find anybody that makes a tire > in > > 315 75R 22.5. > > Everybody has a 315 80R 22.5 they are about 1" wider than a 12R > 22.5 > > & 11.3" Vs 12.5" in width, and the 315's are a little > shorter,19.6" > > Vs 19.8" loaded radius, overall diameter is the same @ 42.4", they > > both use 9" rims, the 315's have a 1700lbs single wheel higher > > capacity and a 1465lbs higher dual wheel capacity, per tire. > > The only thing I see as a problem may be the dual wheel spacing. > > 13.2" for the 12R and 14.1" for the 315's. The only other > difference > > is revolutions per mile, I'd say insignificant @ 2 RP Mile. Info > from > > B.F.Goodrich. The only chart I could find without bouncing all > over > > the web > > I've seen several size tires on comparable birds PT 40,42,& 43's, > > I've seen coaches with 11R 22.5, and the coach for sale on e-bay > > states it has 315's on it.. > > Convention wisdom states all tires should be of the same size & > Mfg. > > I would like to have the heavier tires on the steer axles. I don't > > think 1/2 inch wider on each side of the tire in the front wheel > > wells would make a difference, though it is already a tight fit., > and > > I'm not sure if the larger tires would have an adverse effect on > the > > overall drive ability. I'm hoping for better control , higher > > capacity and the added safety in a more capable tire. > > Any thoughts? > > > > Kurt Horvath > > 95 PT-42 > > 10AC > > >  |
					08-31-2008, 09:25
					"Proper size"   sound too adequate for a perfectionist .  his attention
			to detail is a great asset to the forum. Greg --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > Kurt is not reinventing the wheel Just trying to find the proper size > > > Stephen 77fc35 > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > Gregoryoc@ wrote: > > > > Kurt, proverbialy you always try and reinvent the wheel, now you > > crossed the line. Stay with 12's.  |
