					Bus Standing TALL
					08-25-2008, 05:54
				Bus Standing TALL
				 After airing up the suspension (air springs), the front and the rear of the coach height is about 2" taller than normal. Suspension was cycled three times and no change. I doubt the 3 ride-height valves would go bad at the same time. Thoughts?
				-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA  |
					08-25-2008, 06:11
				Bus Standing TALL
					It is just taller ???  This is odd ???
			If the coach is still level, I would suggest, that Curt is shorter, ( shrinking)?? Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > After airing up the suspension (air springs), the front and the rear of the > coach height is about 2" taller than normal. Suspension was cycled three > times and no change. I doubt the 3 ride-height valves would go bad at the > same time. Thoughts? > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA >  |
					08-25-2008, 06:24
				Bus Standing TALL
					08-25-2008, 06:30
				Bus Standing TALL
					Curt: Some times the ride height valves need to go to the negative side then return to the positive this resets the setting back to normal. Try undocking and take a tour around the block then another block with right and left turns and see if this corrects the problem. I agree, it is odd they would all fail at the same time but then Murphy says" if it can happen it will.?" Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 10:54 AM 8/25/2008 -0700, you wrote: After airing up the suspension (air  |
					08-25-2008, 08:01
				Bus Standing TALL
				 More Info...The height issue started a couple weeks back. Since then
the suspension has been lowered and raised several times, and the coach has been driven a hundred miles, turning many corners, etc. All during this time, when the suspension was aired up, it stood too tall. I just now went out and cycled the suspension. When aired up it still stands about 2" higher than normal. On Mon, Aug 25, 2008 at 11:30 AM, Ralph L. Fullenwider <"rlf47@swbell.net"> wrote:
					08-25-2008, 08:48
				Bus Standing TALL
				 Curt there is an airpressure regulator involved and the only common denominator for all the air bags.
				2008/8/25 Curt Sprenger <"curtsprenger@gmail.com">
 -- Rob, Sue & Merlin Robinson 94 WLWB  |
					08-25-2008, 10:28
				Bus Standing TALL
				 Right you are Rob. I picked up an Haldex pressure regulator. Now to get it installed.
				Greg, is it OK if I come out and use your pit? On Mon, Aug 25, 2008 at 1:48 PM, Rob Robinson <"wander.rob@gmail.com"> wrote:
					08-25-2008, 10:35
				Bus Standing TALL
				 Curt I'd like to take the credit but can't. I passed your problem by Randy Dupree and it was his expertise that came up with the solution.
					08-25-2008, 16:44
				Bus Standing TALL
					Curt, pit aint done but the keys are in the excavator and there is a
			stack of trench plates by my bus. I got to get past the design and just dig the hole. gunite and steel are paid for in swaps. kinda the reason I have two gunite swimmingpools. Greg --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Right you are Rob. I picked up an Haldex pressure regulator. Now to get it > installed. > > Greg, is it OK if I come out and use your pit? > > > On Mon, Aug 25, 2008 at 1:48 PM, Rob Robinson wrote: > > > Curt there is an air pressure regulator involved and the only common > > denominator for all the air bags. > > > > 2008/8/25 Curt Sprenger > > > > After airing up the suspension (air springs), the front and the rear of > >> the coach height is about 2" taller than normal. Suspension was cycled three > >> times and no change. I doubt the 3 ride-height valves would go bad at the > >> same time. Thoughts? > >> > >> > >> -- > >> Curt Sprenger > >> 1987 PT38 8V92 "MacAttack Racing" > >> Anaheim Hills, CA > >> > >> > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA >  |
