					steering box
					06-23-2007, 02:48
				steering box
					HAHAHAHAHA   welllllllllllllllllll duhhhhhhhhhh, if you DON'T remove the
			Captain's chair you had best be a gnome, because you will play hell pulling up the carpet otherwise.....somethings are just self-evident. But it falls in line with directions I saw this past winter. First: open box Second: take item out of box Third: with a sharp instrument bemove plastic from around item Fourth: yell for wife Fifth: at the same time as trying to remove sharp item from palm of the hand, attempt to prevent blood from spewing on carpet hahahahaha. So please be careful, that chair is heavy. Tom Meservey, USN (Ret) Ladson, SC --------------------------------- You snooze, you lose. Get messages ASAP with AutoCheck in the all-new Yahoo! Mail Beta. [Non-text portions of this message have been removed]  |
					08-23-2008, 20:10
				steering box
					My bus is in the shop as we speak sorting our suspension and handling
			issues. The fellows have told me that they have things in pretty good order but are concerned about some "free travel" which they have traced to the steering box. Now here is the issue. This steering box was a rebuilt box which the previous owner replaced about 20K miles ago. (The previous owner said this greatly improved the handling.) The guys are telling me that my options are to live with this free travel or get another remanufactured steering box. My concern is that I might get another only to find its no better then the one I have now. My fellows are also not really familiar with BB's and I wonder if they are expection the impossible with this old FC? Any suggestions or tricks which I might pass on to the shop. They did say there was some type of adjustment that they were going to try to make but it was "tricky" if they went just a little too far then the steering would potentially have a tight spot or a hitch in it.( I may not have that exactly right as to their discription but you likely get the point. They said what they were going to adjust but that didn't stick in the ole knoggin) The shop works on RV's and heavy equipment and is very well respected. They don't see a lot of BB'ds so if there is any thing I can pass along they are more then willing for my information. John Heckman central Pa 1973 FC  |
					08-24-2008, 02:25
				steering box
				 John,
				Ask the shop to get under the bus and tighten up about 13 or 14 bolt/nuts...the ones that hold the plate(s) assemble (starting at the coach frame) that the steering box is bolted. Many of us have done that and have reduced steering play. I did that on our previous 'Bird, 1974, and that took care of about 80 percents of the play (free travel). A visual inspection of those bolts/nuts is not good enough. They will look tight when they are not. They need to put wrenches on them and tighten them. The steering box can also be tightened up to the plate assemble. On Sun, Aug 24, 2008 at 1:10 AM, bubblerboy64 <"jehdds@hotmail.com"> wrote:
 -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA  |
					08-24-2008, 02:37
				steering box
					Thanks Curt, That is exactly the type of information I am looking
			for. Will do. John Heckman central Pa 1973 FC > > John, > > Ask the shop to get under the bus and tighten up about 13 or 14 > bolt/nuts...the ones that hold the plate(s) assemble (starting at the coach > frame) that the steering box is bolted. Many of us have done that and have > reduced steering play. I did that on our previous 'Bird, 1974, and that took > care of about 80 percents of the play (free travel). A visual inspection of > those bolts/nuts is not good enough. They will look tight when they are not. > They need to put wrenches on them and tighten them. The steering box can > also be tightened up to the plate assemble. > > > On Sun, Aug 24, 2008 at 1:10 AM, bubblerboy64 > > > My bus is in the shop as we speak sorting our suspension and handling > > issues. The fellows have told me that they have things in pretty > > good order but are concerned about some "free travel" which they have > > traced to the steering box. Now here is the issue. This steering box > > was a rebuilt box which the previous owner replaced about 20K miles > > ago. (The previous owner said this greatly improved the handling.) > > The guys are telling me that my options are to live with this free > > travel or get another remanufactured steering box. My concern is > > that I might get another only to find its no better then the one I > > have now. My fellows are also not really familiar with BB's and I > > wonder if they are expection the impossible with this old FC? Any > > suggestions or tricks which I might pass on to the shop. They did > > say there was some type of adjustment that they were going to try to > > make but it was "tricky" if they went just a little too far then the > > steering would potentially have a tight spot or a hitch in it.( I may > > not have that exactly right as to their discription but you likely > > get the point. They said what they were going to adjust but that > > didn't stick in the ole knoggin) The shop works on RV's and heavy > > equipment and is very well respected. They don't see a lot of BB'ds > > so if there is any thing I can pass along they are more then willing > > for my information. > > > > John Heckman > > central Pa > > 1973 FC > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA >  |
					08-24-2008, 03:39
				steering box
				 John,
I have been looking into improving my steering also. While seeing that all is tight I have been told by Blue Bird that the steering box (Ross HF654) used on my coach was referred to as a dump truck steering box and that play is normal and very little could be done to improve it. One Ross representative told me that a HFB64 box was much better and some of the people at Blue Bird indicated this was the box used on later model FCs to improve the steering. Blue Bird told me that they did change a few coaches to this new box and about 40 hours of labor a well as some modification were required. That is when I decided to live with what I had.
Chet Geist
1981 FC33, Austin, Texas
					08-24-2008, 04:22
				steering box
					If Curt has the cure for the box issue maybe it would be prudent to
			have the shop replace all the 14 bolts and nuts (or 7 of the 14) with larger diamater bolts. maybe go to the next larger size in metric (may involve less drilling). It would not be a matter of the mounts and joints lifting. the play would show up in a slide between flat ajoining surfaces. Curts theory: Several slides would have to be overcome each time the box's pitman arm changes direction. You can test for this fault with a Dial indicator http://www.dialindicator.com/custom_gage_photos.php or just placing your thumb on the frame up against the steering mounts and having someone turn the wheel back and forth. the center of the mounts may show less movement than the four ends as the plate twists (there should be no movement). Doing this on hot asphalt may be best as the smooth shop floor will give little turn resistance. It may be more evident with the rear jacks lifting up the ass. At the same time input to the box by the steeringwheel should be evident right away with equal movement at the pinion arm of the box (that is the play they can adjust with the wrench). I dont understand " tight spot" as a result of adjusting the box play??? unless they think the gear in the box is worn at the idle mating surfaces only???? At any event, if wear at the box is the repair, you still have to find out why it failed once again in only 20K. "box damage may be a result" If that bolts proves to be at fault, you are at the wrong shop. One other point to look at is the PS boil over issue the FC crowd (ForeverCatipillar) has. I often wonder if it is not boiling PS fluid as much as it is air making its way to the PSpump and expanding the volume of fluid to the point thet the air pushes the fluid out the resevoir???? If you get air in hydrolic fluid, the thing the fluid is moving will have a lag. you can not compress a volumn of fluid but you can compress air to the point that it displaces. air would have to build up pressure at each direction change. If the steering gets worse while you drive, air may be an issue????? air gets in at return lines or supply lines. those lines have suction and dont show leaks and never get changed with pressure lines because they dont have the outward appearance of needing leak repair. Folks dont realize how much stress is placed on steering components when they make a stationary turn (not rolling while changing direction of your wheels). Watch a commercial driver make a K turn. at the end of forward movement, the wheels are redirected to that required for the reverse movement. GregoryO'Connor 94pt RomolandCa --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > John, > > Ask the shop to get under the bus and tighten up about 13 or 14 > bolt/nuts...the ones that hold the plate(s) assemble (starting at the coach > frame) that the steering box is bolted. Many of us have done that and have > reduced steering play. I did that on our previous 'Bird, 1974, and that took > care of about 80 percents of the play (free travel). A visual inspection of > those bolts/nuts is not good enough. They will look tight when they are not. > They need to put wrenches on them and tighten them. The steering box can > also be tightened up to the plate assemble. > > > On Sun, Aug 24, 2008 at 1:10 AM, bubblerboy64 > > > My bus is in the shop as we speak sorting our suspension and handling > > issues. The fellows have told me that they have things in pretty > > good order but are concerned about some "free travel" which they have > > traced to the steering box. Now here is the issue. This steering box > > was a rebuilt box which the previous owner replaced about 20K miles > > ago. (The previous owner said this greatly improved the handling.) > > The guys are telling me that my options are to live with this free > > travel or get another remanufactured steering box. My concern is > > that I might get another only to find its no better then the one I > > have now. My fellows are also not really familiar with BB's and I > > wonder if they are expection the impossible with this old FC? Any > > suggestions or tricks which I might pass on to the shop. They did > > say there was some type of adjustment that they were going to try to > > make but it was "tricky" if they went just a little too far then the > > steering would potentially have a tight spot or a hitch in it.( I may > > not have that exactly right as to their discription but you likely > > get the point. They said what they were going to adjust but that > > didn't stick in the ole knoggin) The shop works on RV's and heavy > > equipment and is very well respected. They don't see a lot of BB'ds > > so if there is any thing I can pass along they are more then willing > > for my information. > > > > John Heckman > > central Pa > > 1973 FC > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA >  |
					08-24-2008, 04:50
				steering box
					If the steering has no play from the tire to the steeringwheel, the
			driver will feel every rock and often react to the point that they will oversteer. when your tires and frontend are balanced and aligned, you will not notice the float that must be there to maintain control. Motorcross bikes add 'steering dampeners' to add the play aiding control. It may be that you will feel better steering with more play in the box???? Biannualy the State sends techs to my house with guns and pull me over road side some 5 times a year to for one thing to check steering mechanics on my dump truck. I am given no allowance for excessive or lack of play. --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" wrote: > > John, > > I have been looking into improving my steering also. While seeing that all > is tight I have been told by Blue Bird that the steering box (Ross HF654) > used on my coach was referred to as a dump truck steering box and that play > is normal and very little could be done to improve it. One Ross > representative told me that a HFB64 box was much better and some of the > people at Blue Bird indicated this was the box used on later model FCs to > improve the steering. Blue Bird told me that they did change a few coaches > to this new box and about 40 hours of labor a well as some modification were > required. That is when I decided to live with what I had. > > Chet Geist > 1981 FC33, Austin, Texas > > > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of bubblerboy64 > Sent: Sunday, August 24, 2008 3:11 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Steering box > > > My bus is in the shop as we speak sorting our suspension and handling > issues. The fellows have told me that they have things in pretty > good order but are concerned about some "free travel" which they have > traced to the steering box. Now here is the issue. This steering box > was a rebuilt box which the previous owner replaced about 20K miles > ago. (The previous owner said this greatly improved the handling.) > The guys are telling me that my options are to live with this free > travel or get another remanufactured steering box. My concern is > that I might get another only to find its no better then the one I > have now. My fellows are also not really familiar with BB's and I > wonder if they are expection the impossible with this old FC? Any > suggestions or tricks which I might pass on to the shop. They did > say there was some type of adjustment that they were going to try to > make but it was "tricky" if they went just a little too far then the > steering would potentially have a tight spot or a hitch in it.( I may > not have that exactly right as to their discription but you likely > get the point. They said what they were going to adjust but that > didn't stick in the ole knoggin) The shop works on RV's and heavy > equipment and is very well respected. They don't see a lot of BB'ds > so if there is any thing I can pass along they are more then willing > for my information. > > John Heckman > central Pa > 1973 FC >  |
					08-24-2008, 04:58
				steering box
					Thanks Greg and Chet.  I printed out your helpful replies and will
			pass them along to the shop for their reading pleasure. Chet, I certainly know from where you are coming. It is my intention to do the best I can and to live with the rest. I spoke to another former FC owner (now has a PT) and he stated that the factory says about 10 years it's time to replace springs. He also reported that when he did that it helped with keeping her going straight on uneven pavement. So I believe I am going to do it if the $'s aren't too bad. I've got this coach quiet, and running well. It deserves what I can do within reason to make it drive as close to new as is practical. Actually the handling was never the main issue, it was ride quality. But if replacing the springs helps both ride and control that would be even better. Greg, thanks for the heads up on the power steering. I don't think it does get worse as I drive but I will pay attention to that as well. John Heckman central Pa 1973 FC > > John, > > I have been looking into improving my steering also. While seeing that all > is tight I have been told by Blue Bird that the steering box (Ross HF654) > used on my coach was referred to as a dump truck steering box and that play > is normal and very little could be done to improve it. One Ross > representative told me that a HFB64 box was much better and some of the > people at Blue Bird indicated this was the box used on later model FCs to > improve the steering. Blue Bird told me that they did change a few coaches > to this new box and about 40 hours of labor a well as some modification were > required. That is when I decided to live with what I had. > > Chet Geist > 1981 FC33, Austin, Texas > > > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of bubblerboy64 > Sent: Sunday, August 24, 2008 3:11 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Steering box > > > My bus is in the shop as we speak sorting our suspension and handling > issues. The fellows have told me that they have things in pretty > good order but are concerned about some "free travel" which they have > traced to the steering box. Now here is the issue. This steering box > was a rebuilt box which the previous owner replaced about 20K miles > ago. (The previous owner said this greatly improved the handling.) > The guys are telling me that my options are to live with this free > travel or get another remanufactured steering box. My concern is > that I might get another only to find its no better then the one I > have now. My fellows are also not really familiar with BB's and I > wonder if they are expection the impossible with this old FC? Any > suggestions or tricks which I might pass on to the shop. They did > say there was some type of adjustment that they were going to try to > make but it was "tricky" if they went just a little too far then the > steering would potentially have a tight spot or a hitch in it.( I may > not have that exactly right as to their discription but you likely > get the point. They said what they were going to adjust but that > didn't stick in the ole knoggin) The shop works on RV's and heavy > equipment and is very well respected. They don't see a lot of BB'ds > so if there is any thing I can pass along they are more then willing > for my information. > > John Heckman > central Pa > 1973 FC >  |
					08-24-2008, 07:14
				steering box
					John - The shop is talking about adjusting the play or "pre-load" on
			the steering box's Cross Shaft and Sector Shaft. It makes sense that these adjustments could be needed after a few miles on a rebuilt box. Also, re-torqing those mounting bolts mentioned in other posts may help. Bob Griesl '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > My bus is in the shop as we speak sorting our suspension and handling > issues. The fellows have told me that they have things in pretty > good order but are concerned about some "free travel" which they have > traced to the steering box. Now here is the issue. This steering box > was a rebuilt box which the previous owner replaced about 20K miles > ago. (The previous owner said this greatly improved the handling.) > The guys are telling me that my options are to live with this free > travel or get another remanufactured steering box. My concern is > that I might get another only to find its no better then the one I > have now. My fellows are also not really familiar with BB's and I > wonder if they are expection the impossible with this old FC? Any > suggestions or tricks which I might pass on to the shop. They did > say there was some type of adjustment that they were going to try to > make but it was "tricky" if they went just a little too far then the > steering would potentially have a tight spot or a hitch in it.( I may > not have that exactly right as to their discription but you likely > get the point. They said what they were going to adjust but that > didn't stick in the ole knoggin) The shop works on RV's and heavy > equipment and is very well respected. They don't see a lot of BB'ds > so if there is any thing I can pass along they are more then willing > for my information. > > John Heckman > central Pa > 1973 FC >  |
					08-24-2008, 10:28
				steering box
				 When I had my steering box rebuilt I discovered that there were two different boxes used in the FC. The older one has much more "free play" than the newer design. The difference is in the spool valve design.If the steering wheel input shaft movesup and down when you move the wheel with the engine off you have the older design. It's not really mechanical free play but the amount of movement requires for the hydraulic system to react. At the time we had ours rebuilt there were none of the newer design available to see if they were interchangeable. With the rebuilt steering box, new tie rod ends, and bushings in the front end suspension (totally gone) our FC handles very well now. There is still the free play, but not slack, in the steering system. Nowon a straight road there is very little correction required. You want to be careful adjusting the sector shaft preload, it is done with the box unloaded using a torque wrench on the input shaft. Many people mistake eliminating free play with putting the steering box in a bind which increases wear. The seals were worn out in our steering box, but all other parts were in good condition. We are all used to rack and pinion steering in our cars. Drive a 50s or early 60s vehicle that have steering boxes andthey havemuch the same feeling as our FCs.
- Chuck Wheeler-
FC 31SB Fort Worth TX
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of bubblerboy64 Sent: Sunday, August 24, 2008 3:11 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Steering box My bus is in the shop as we speak sorting our suspension and handling issues. The fellows have told me that they have things in pretty good order but are concerned about some "free travel" which they have traced to the steering box. Now here is the issue. This steering box was a rebuilt box which the previous owner replaced about 20K miles ago. (The previous owner said this greatly improved the handling.) The guys are telling me that my options are to live with this free travel or get another remanufactured steering box. My concern is that I might get another only to find its no better then the one I have now. My fellows are also not really familiar with BB's and I wonder if they are expection the impossible with this old FC? Any suggestions or tricks which I might pass on to the shop. They did say there was some type of adjustment that they were going to try to make but it was "tricky" if they went just a little too far then the steering would potentially have a tight spot or a hitch in it.( I may not have that exactly right as to their discription but you likely get the point. They said what they were going to adjust but that didn't stick in the ole knoggin) The shop works on RV's and heavy equipment and is very well respected. They don't see a lot of BB'ds so if there is any thing I can pass along they are more then willing for my information. John Heckman central Pa 1973 FC  |
