94pt 8v92 cooling lines to the aircompressor
08-08-2008, 15:14
the coolant lines to the engine mounted aircompressor have proven to
fail after 20 years. I think it is from the excess heat that gets
trapped above the transmission / below bedroom.(not vented to engine
bay, may be cause of heat in bedroom?). I replaced the coolant lines
today as a PM (preventativeMaintenance) measure.
there are two lines that run from the passanger side block to the
compressor which is mounted above the transmission bell housing. one
hose 28 inches long and the other about 8 inches long
Short hose. there is a trap door under the carpet between rear
dresser and the bed, just about center. I removed the carpeted
baceboard box that covers wires and pipes, lifted the carpet and
unscrewed a metal plate. under the wires is one more removable
plate. the wire plate attaches to the wall behind the wires and to
the floor. with both plates out you have easy access.
the compressor has several lines 2 coolant 2 oil and two air. the
coolant lines are at the top. a 7/8inch wrench is used to remove the
swival end ( oil uses a 3/4) the short hose attaches to back of the
block. when you remove the line you will see the coolant as a check
Long hose. at the other end of the compressor head is the long hose
attached to the compressor with a 7/8 swival fitting. the hose runs
past the tranny mount between the frame and the block and reattaches
to the block above the starter. I removed the compressor end and cut
the hose to make it easy to slip thru a strap. with the bus jacked
up wheels just on the ground,frame stands and chocks inplace, I
reached over the starter (removed battery power and unplugged
chargers) and found the attachement to the block. there are two
lines attached to the block above the starter one is oil to the
compressor. the one you want is the farthest reach and the swival is
7/8 and hose is larger than the oil. unable to get a full size
wrench on the fitting I uses a "stubby whench". A 7/8crows foot and
socket wrench would best serve to loosen the fitting but I used a
bathroom sink wrench(?) (cheap long handel with a flip/flop little
pipe wrench thing on the end). I made the long hose 5 inches longer
as the OEM was jammed against the frame and 'flex tube vent'.
Install the starter end fitting first to make it easy to line up
the thread. I pointed the '90 degree fitting out of the block'
downward a bit to help clear the 'frame pinch area'. I also bent the
flex tube away frm the block for the new line.
the hosefittings are reusable and I wanted to do so but I could not
get high temp quickie tube. I had hydrolic line made but wonder how
well hydrolic oil hose holds up to coolant product?
took about one hour to remove and 2 to install. it was hard to line
up the fitting above the starter and removal of the starter would
have saved an hour. removal of trap door took an hour also.
both hoses with pressed fittings cost about $60.00. SanDiego
Detroit charged $700. for a 88pt parts and labor (July'08). no trap
door access and required starter removal, sounds way fair.
GregoryO'Connor
94ptRomolandCa
08-08-2008, 16:02
Greg,
Good post. It should be saved in the Files Section.Yes, $700.00 does seem fair.
GregoryO'Connor
94ptRomolandCa
Curt Sprenger
Anaheim Hills, CA
08-24-2008, 17:41
here are some pics of the 8v92 aircompressor coolant lines. at the
fist pic chose next for the next 4 pics
Greg
http://www.pbase.com/gregoryoc/image/102145955
to
engine
lines
one
hose
runs
reattaches
cut
jacked
is
little
longer
not
how
line
trap
> GregoryO'Connor
> 94ptRomolandCa
08-25-2008, 03:42
Great pics Greg. They made that block mount hose above the starter
look almost easily accessible!
1991 WB40 "Texas Minivan"
> Greg
> to
> engine
> lines
> one
> the
> the
> hose
> runs
> reattaches
> cut
> jacked
> is
> and
> little
> longer
> the
> not
> how
> line
> trap
> > GregoryO'Connor
> > 94ptRomolandCa
