3208 T'Stats - What's The Drill
05-21-2005, 05:03
Changing some hoses and the thermostats on this 225T this morning.
First, am I looking in the right place: the stat housing is just below
the air conditioning compressor, correct?
The housing is not like the book, of course! Has a rad hose fitting
piggy-backed on it, apparently. Two of the housing bolts look like
studs that run out through the hose fitting. The nuts on those studs
(?) loosen and then the studs spin without turning out.
I'm probably missing something here. Anyone?
Bob Griesel '84 FC31 WLII WA
05-21-2005, 05:16
I struggled with this same problem.
The expert Mike H set me straight.
All that stuff is bolted to an assessory plate on our
300 hp turbo. We could easily reach the bolt/nuts from
inside the doghouse. There is also some confusion on
a one or two thermostat system. Our 88 has only one thermostat.
Just get dirty and crawl into the doghouse with a bright light.
Bill 88 FC Michigan Likes being in the doghouse
--- In WanderlodgeForum@yahoogroups.com, "freewill2008"
morning.
below
fitting
like
studs
05-21-2005, 10:32
nuts and bolts on the ones i've done..randydupree93wb
Sent: Saturday, May 21, 2005 1:03 PM
Subject: [WanderlodgeForum] 3208 T'Stats - What's The Drill
Yahoo! Groups Links
05-22-2005, 06:47
Yeah - *nuts* working on the engine and *bolts* holding it
together. Smile When I saw Bill's reply earlier I remembered reading a
while back about the bolt heads behind the stat housing.
Anyway, it was a good day's preventive maintenance. New stats, upper
rad hoses, oil cooler hoses, power steering return hoses. Found much
better routing for the PS hoses - no more loops and pinches. Also
fabricated a little vent for the PS fluid resevoir. Worked outdoors
and buttoned up the front just as the rain started.
100 mile test drive tomorrow to drop the rig off for the Telma
install.
Bob Griesel '84 FC31 WLII in showery western WA
--- In WanderlodgeForum@yahoogroups.com, randydupree
> From: freewill2008
morning.
below
fitting
like
studs
