A new problem for this group to ponder
04-02-2008, 14:49
Hello everyone,
I experienced a new "issue" on our way home from Alabama after taking 20 laps behind the wheel of a Nascar race car at Talladega. What a blast!
Here's the new problem. I had used the cruise control all day and also had the retarder switch on (but not using). I came to a stop at an intersection and when I applied the brakes my engine revved to 1000 RPM's (above the typical 550 RPM's when stopping & off the accelerator). I took my foot off the brake, engine kicks down back to 550 rpm's (normal). I applied the brake again, engine kicked back up to 1000 rpm's. Very very strange. I had this happen a few times, one time getting up to 1500 RPM's when trying to stop the coach which was a chore and very scary to think the coach wouldn't stop. I put the coach in neutral when applying the brake, didn't stop the high RPM's while having the coach brake applied. After being back underway, before the next stop, I switched the cruise to off and
the retarder to off. Coming to my next stop the coach braked normally until I got home. Yesterday, I went to move the coach, and it did the exact same thing with cruise and retarder off. Apply the brakes, engine revs to 1000 rpm's whether the coach is in reverse, drive or neutral. This is probably not an easy fix, but would appreciate any collective direction or thoughts on the matter.
Thank you in advance!!
Drew May
Conway, AR
'88 WB40
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
04-02-2008, 15:11
This may sound really stupid. I had a very similar problem but did not go through the sequence of events you have.
How big are your shoes?? I drive with a sock on my right foot to prevent my shoe from hitting the accelerator while braking. I am not spoofing.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
Drew May wrote:
Hello everyone,
blast!
Here's the new problem. I had used the cruise control all day and also had the retarder switch on (but not using). I came to a stop at an intersection and when I applied the brakes my engine revved to 1000 RPM's (above the typical 550 RPM's when stopping & off the accelerator). I took my foot off the brake, engine kicks down back to 550 rpm's (normal). I applied the brake again, engine kicked back up to 1000 rpm's. Very very strange. I had this happen a few times, one time getting up to 1500 RPM's when trying to stop the coach which was a chore and very scary to think the coach wouldn't stop. I put the coach in neutral when applying the brake, didn't stop the high RPM's while having the coach brake applied. After being back underway, before the next stop, I switched the cruise to off and the retarder to off. Coming to my next stop the coach braked normally until I got home. Yesterday, I went to move the coach, and it did the exact same thing with
Drew May
Conway, AR
'88 WB40
04-02-2008, 15:37
Leroy,
Size 11. I actually thought of the same thing, but made sure the carpet, my shoes, etc. were not pushing down on both at the same time. It was my first thought.
Drew
88WB40
Leroy Eckert
1990 WB-40 Smoke N
Mirrors
Dahlonega, GA
Royale Conversion
Drew May com> wrote:
Hello everyone,
chore and very scary to think the coach wouldn't stop. I put the coach in neutral when applying the brake, didn't stop the high RPM's while having the coach brake applied. After being back underway, before the next stop, I switched the cruise to off and the retarder to off. Coming to my next stop the coach braked normally until I got home. Yesterday, I went to move the coach, and it did the exact same thing with cruise and retarder off. Apply the brakes, engine revs to 1000 rpm's whether the coach is in reverse, drive or neutral. This is probably not an easy fix, but would appreciate any collective direction or thoughts on the matter.
Drew May
Conway, AR
'88 WB40
04-02-2008, 16:08
Hi Drew:
The exhaust port on the inversion valve is sticking or the double check
valve is sticking, either one will give you much the same symptoms. Both of
those valve are located on the curb side rear under the grill hatch. Need a
can of 3 in 1 oil or fish oil, remove the input air line and put a few
drops of air in the line, re connect, build the air and cycle the system.
Do this to both valves.
It should take care of the problem.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
At 07:49 PM 4/2/2008 -0700, you wrote:
>Hello everyone,
>Drew May
>Conway, AR
>'88 WB40
Safe travels,
Duncan, Oklahoma
04-02-2008, 16:10
Sorry this needs to read: put a few drops of oil in the line then re
connect the air line, start the engine to build air in the system and cycle
the system.
Sorry
At 10:08 PM 4/2/2008 -0600, you wrote:
>Hi Drew:
>Safe travels,
>Duncan, Oklahoma
> >Hello everyone,
> >Drew May
> >Conway, AR
> >'88 WB40
>Safe travels,
>Duncan, Oklahoma
>Yahoo! Groups Links
>No virus found in this incoming message.
>Checked by AVG.
>Version: 7.5.519 / Virus Database: 269.22.4/1355 - Release Date: 4/1/2008
>5:37 PM
Safe travels,
Duncan, Oklahoma
04-02-2008, 16:28
If I asked "how big are your feet?" Ernie and Mike would put me on
restrictive post. just aint fair.
Do you have an M&G toad suplemental braking system? Or any mods of
the sort?
I wonder what signals the cruise to kick off when the brakes are
applied?
I wonder if it has somthing to do with 'fast idle' and brake light
signal kicking in a false fast idle?
If you apply the brakes while in Allison "N" can you get the 1000R
responce?
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, Drew May
> Hello everyone,
What a blast!
> Drew May
> Conway, AR
> '88 WB40
04-03-2008, 01:19
Thanks Ralph!
"Ralph L. Fullenwider" wrote:
Hi Drew:
Safe
travels,
Duncan, Oklahoma
>Hello everyone,
>Drew May
>Conway, AR
>'88 WB40
Safe travels,
Duncan, Oklahoma
04-03-2008, 01:22
Nope, we do not have any supplemental braking systems or any other modifications. Yes, if I apply the brakes in Allison "N" I still get the same response of revving to 1000 rpm's. I'm going to take Ralph's suggestion and diagram this weekend to try and solve the problem. Once I've gotten to it, I'll give the group an update on resolution.
Thanks again for all of the help!
Do you have an
the sort?
applied?
responce?
GregoryO'Connor
94ptRomolandCa
--- In "WanderlodgeForum%40yahoogroups.com", Drew May .>
> Hello everyone,
What a blast!
in reverse,
> Drew May
> Conway, AR
> '88 WB40
04-03-2008, 01:22
Do you have an
the sort?
applied?
responce?
GregoryO'Connor
94ptRomolandCa
> Hello everyone,
What a blast!
in reverse,
> Drew May
> Conway, AR
> '88 WB40
04-03-2008, 01:30
Greg,
I just installed an M&G brake system on my 88 WBWL XXV did not think
that it would affect anything but possibly if air leak that the
brakes would not come off! what were you thinking that the M&G might
do?
Jim Riordan
> the sort?
> applied?
> responce?
> GregoryO'Connor
> 94ptRomolandCa
> > Hello everyone,
> What a blast!
at
back
I
matter.
> > Drew May
> > Conway, AR
> > '88 WB40
