LXI vs. WB's
02-13-2008, 07:21
LXI vs. WB's
We are still looking at larger BB's. I have seen a few LXI's of the 98
vintage 41,s and 43,s for sale as well as a few 90 to 96 WB's. I understand some of the differences such as the Detroit 60 and the dropped engine for the rear closet. But I am interested in knowing some of the possible problems with a 98. Is the 60 DD a good engine? Are he 98's overloaded on the FA? I remeber reading something about some BB's having this problem. Any other things I should be aware of? Would really appreciate some assistance. Bruce 1988 FC35 |
02-13-2008, 07:46
LXI vs. WB's
Bruce,
David Brady has been working with the front end of his LXi. Mine is not overloaded, but overbuilt. I don't think there is a better engine than the Series 60, but I like any Detroit. Mine has a standard non-slide bedroom without a rear closet, but the bed's a lot eaiser to get around. We have a full length closet on the front wall of the bedroom and 3 hall closets. Plenty of storage on board. Brad Barton 00LXiDFW bbartonwx@...
Connect and share in new ways with Windows Live. Get it now! |
02-13-2008, 08:16
LXI vs. WB's
I have to admit that the Series 60 in my '95 was a major attraction. Nothing wrong with the DD 8v92, but it's been nearly 20 years since 8vs and 6vs have been built. It's getting difficult to find experienced diesel mechanics who can work with them. Since the Series 60 is still in production -- and widely used -- there is little difficulty finding qualified mechanics.
FWIW, I've had no troubles with the engine and haven't needed any repairs on it -- just the usual preventive maintenance you'd expect.
When I had my coach weighed, I was a little surprised how heavy it was -- but it's still comfortably under the GVWR and no axle is close to being overloaded. I did, however, have to raise the tire pressures to keep the tires 'in spec' to somewhat above the recommended pressures on a plate found in one of the storage bays. Some of the 'purists' might suggest that the coaches with rivets in their skin are "better" than the later, adhesive bonded models -- but I wouldn't know how true that is. From an engineering perspective, adhesive bonding, if done correctly, gives a stronger connection with less concentrated stress on the connection points as is the case with rivets. But I can understand a concern that "glue" might not be as durable over time. (But I've never heard that anyone has had trouble with a 'bird in this regard.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Feb 13, 2008, at 11:46 AM, brad barton wrote: Bruce, |
02-13-2008, 08:25
LXI vs. WB's
Bruce, I'm with Brad - the S60 is a remarkable engine with a long successful history in the trucking industry. My axles, like the rest of the bus, are overbuilt too. GAWR: steer: 16K, drive: 23K, tag: 13K. My actual axle weights are steer: 14.5K, drive: 21K, tag: 11.5K for a vehicle weight 47K and a CCC of 5K lbs. I know that the steer axle on early LXi's had a GAWR of 14K lb, but I think they were all recalled and swapped with 16K lb units. (Definitely something to check). Some of the early units had steerable tags, a very cool option, but known to present it's own set of problems. A non-steer tag is probably preferable. My LXi has been great - reliable and spacious. The only issue I've had is ride quality. When I bought my coach it rode rough primarily at the steer axle. I found that the ride height was almost an inch low at all axles. Setting it up with the proper ride height, Koni FSDs, CrossFires, and Centramatics improved the ride significantly. Recently though, I discovered that BlueBird put an excessively stiff front anti-sway bar on the steer axle. I removed the steer axle anti-sway bar and now the ride is as close to a Prevost (and I've driven a few) as your likely to find. A lighter weight Roadmaster anti-sway bar is in the works.The non-slide LXi does use a lighter anti-sway bar (1.75" diameter versus my 2.125" bar), but I still think 1.75" is too stiff. I'll be going to a 1.5" bar. The great thing about BB's (as I'm sure you know) are the capacities, and the LXi follows in that BB tradition including a 40 gallon LPG tank and a dual fuel refrigerator. The non-slide LXi has the typical triangulated basement bays; the slide equipped LXi adds to this by incorporating longitudinal frame rails running the length of the basement. These rails are under the basement and are also triangulated (take a peek under any LXi and you'll see what I'm talking about). These were added to compensated for the slide opening. In addition, the inside of the bus has a layer of sheet metal riveted to the inner frame members spanning the length of the bus and spanning the distance from the floors to the bottoms of the windows. This is used to compensate for the rivet-less exterior look; i.e, hide the rivets on the inside. The slide equipped bus also has a set of triangulated frame members stretching from the top of the steer axle to the bottom of the basement longitudinal rails, which I discussed earlier. As Bruce Morris put it, your not losing any strength by going from a non-slide bus to a slide equipped LXi (lots of compensating strength was built in. David Brady '02 LXi, NC brad barton wrote:
02-13-2008, 08:35
LXI vs. WB's
Oops, I beg your pardon, I meant to write "George Morris", not Bruce. George is the ex-bluebird mechanic now working for Bleakley's at Unidilla. David Brady '02 LXi, NC David Brady wrote:
02-13-2008, 11:19
LXI vs. WB's
I will stick with rivets. Most aircraft are built with one inch or less rivet spacing. There are many 50 year old examples out there in fine condition. My BB has three inch spacing. Yes there are composites out there, all subject to UV problems over time. No offense to newer units.
Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Pete Masterson
Never miss a thing. Make Yahoo your homepage. |
02-13-2008, 12:19
LXI vs. WB's
I'm with you Leroy. I love the rivet-ed buses of the 40's, 50's & 60's, GM's, Flxible's, etc. Unfortunately they don't build 'em like that anymore. If you want the newer features, Series 60, etc, then you get the smooth sides. At least the LXi has rivets on the inside wall panels. David Brady '02 LXi, NC Leroy Eckert wrote:
02-13-2008, 13:20
LXI vs. WB's
My bus has rivets -- and a Series 60. I think the rivets went away in '96.
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Feb 13, 2008, at 4:19 PM, David Brady wrote: I'm with you Leroy. I love the rivet-ed buses of the 40's, 50's & 60's, |
02-13-2008, 14:18
LXI vs. WB's
Call me an old romantic.
I opted for the rivets for the classic look. 97 was the last year for riveted birds. Since neither my wife nor I wanted slides anymore, and since we wanted rivets, it became a no brainer for us. With the exception of slides and bonded sides, there isn't enough difference between the 1995-2003 WB43s and LXis to be concerned about. It really just comes down to what style and layout you prefer. I'm not getting into the bonded vs riveted wars, we bought what we liked and have been changing anything we didn't like and we REALLY like our bird. --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > My bus has rivets -- and a Series 60. I think the rivets went away in > '96. |
02-13-2008, 14:26
LXI vs. WB's
97 was the last year of the rivets. You can get a Series 60 w/rivets in the
95/96 42 footer, and the 97 41 and 43 footers. The 97 was when they dropped the engine down and gained some room at the back. My personal ideal would be a 97 41 ft with mid-entry, like the Hulse's have. Don Bradner 90 PT40 "Blue Thunder" Posting today by satellite from Casa Grande, AZ On 2/13/2008 at 5:20 PM Pete Masterson wrote: >My bus has rivets -- and a Series 60. I think the rivets went away in >'96. > >Pete Masterson >'95 Blue Bird Wanderlodge WBDA 42 >El Sobrante CA >aeonix1@... > > > >On Feb 13, 2008, at 4:19 PM, David Brady wrote: > >> I'm with you Leroy. I love the rivet-ed buses of the 40's, 50's & >> 60's, >> GM's, Flxible's, etc. Unfortunately they don't build 'em like that >> anymore. If you want the newer features, Series 60, etc, then you >> get the smooth sides. At least the LXi has rivets on the inside wall >> panels. >> >> Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
