turn signal switch
02-01-2008, 15:37
turn signal switch
My turn signal switch is not cancelling all the time. Doesnt look like
you can replace the switch. The whole stalk must be purchased. I know
this item is off some HD truck. Couldnt find it in my Grote catalog.
Does anyone know what vehicle uses this switch? Maybe a part #.
Looking in the BB catalog it appears that most units use the same
switch. I havent checked with BB for a price yet.
Bruce
1988 FC35
02-02-2008, 03:39
turn signal switch
Hi Bruce,
There are a couple of phillips screws that can loosen, One is visible
and I believe the other is under the steering columne cosmetic
covering, Tightening may help.
Also years ago there was a recall on this switch, They were available
at the Dealers at that time, Holland Michigan has a few , I acquired
one about 4 years ago and I believe the previous owner of the McGinnis
coach ,(BirdBraines) had one, The entire switch must be replaced and
it is not a simple task. Guessing there are atleast 20 wire connections
that need spliced, I chose to keep the replacement in the box it was
shipped in, for future turnsignal trouble.
Bill 88 FC Michigan
-- In WanderlodgeForum@yahoogroups.com, "birdshill123"
like
> Bruce
> 1988 FC35
02-02-2008, 07:12
turn signal switch
Thanks Bill:
I took the switch right off and applied some Lubriplate. That helped
some but it still acts up sometimes. The screws are very tight. On
Monday I will check with BB for a price. I just know it is off a HD
truck.
Bruce
1988 FC35
