Another compressor problem
12-30-2007, 16:25
John, if the belt is tight and the compressor is spinning check the
key in the pully shaft???? you can also check to see if the compressor head gets hot??? If it is a leak it must be big. you can not hear it because it wont build enough pressure to hiss and while the cat is running there is too much noise to hear a big leak hiss. I would hook the aux air up to a remote shop compressor and look for a leak that way. build a male to mail fitting for a remote compressor line's female end and try and build up the tanks in the bus that way?????? I have had valves hang up that just needed a jolt of reverse air to get thm free. It could also be that there is a blockage in the compressor output line to the first tank GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Upon trying to take the son-in-law for a turn in the bus I found that > the compressor would not bring the air up to release the brakes. > Checked and the belt is Ok and the compressors seems to be turning Ok. > Is there a solenoid or a switch which activates and deactivates the > compressor. I get about 30lbs on the air gauge but no more. The only > other clue is that when the compressor is running normally it makes > enough noise that I can hear it and it is not doing that. Don't know > beans about what I am dealing with but any help or suggestions as to > what to look at or for would certainly be appreciated. > > John Heckman > central Pa > 1973 FC converted to 3208 CAT > |
12-31-2007, 02:11
I haven't had a chance to look into this today as yet. I appeciate
the help to this point. My question is what regulates the compressor? The pulley is spinning all the time but I can tell by the sound that it cycles on an off as far as a load.The compressor mounting rattles rather noisily when it is changing the tanks. Does something close and open to fill the tanks? I have this idea again perhaps I am wrong that this is electrical? Or as Gregory said there is a valve sticking. Now where are the valves? In the top of the compressor. Remember this thing is bits and pieces of parts so that makes it even more interesting. I had this occur before one time and my shore batteries were down. I got the batteries charged up and the compressor kicked in. Could be just lucky or a coincidence? Seems like a leak would leak all the time rather then come and go. I plan on fooling around here today with it so I will be back and forth. I guess the first thing I will do is just start the bus and try again. I need to figure this out because at some point its going to stay broke. Likely at the worst possible time. So I need to understand the system a little better. John Heckman central Pa 1973 FC > > John, if the belt is tight and the compressor is spinning check the > key in the pully shaft???? you can also check to see if the > compressor head gets hot??? > > If it is a leak it must be big. you can not hear it because it wont > build enough pressure to hiss and while the cat is running there is > too much noise to hear a big leak hiss. I would hook the aux air up > to a remote shop compressor and look for a leak that way. build a > male to mail fitting for a remote compressor line's female end and > try and build up the tanks in the bus that way?????? I have had > valves hang up that just needed a jolt of reverse air to get thm > free. > > It could also be that there is a blockage in the compressor output > line to the first tank > > GregoryO'Connor > 94ptRomolandCa > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > Upon trying to take the son-in-law for a turn in the bus I found > that > > the compressor would not bring the air up to release the brakes. > > Checked and the belt is Ok and the compressors seems to be turning > Ok. > > Is there a solenoid or a switch which activates and deactivates > the > > compressor. I get about 30lbs on the air gauge but no more. The > only > > other clue is that when the compressor is running normally it > makes > > enough noise that I can hear it and it is not doing that. Don't > know > > beans about what I am dealing with but any help or suggestions as > to > > what to look at or for would certainly be appreciated. > > > > John Heckman > > central Pa > > 1973 FC converted to 3208 CAT > > > |
12-31-2007, 02:36
Well, I went out and started the bus and wouldn't you know it the
compressor immediately kicked on and functioned as it should. It cycled up to 125psi on the gauge and shut off and every thing seems fine. But we know that is not the case. Idea's thoughts anything on this with this little bit more information. John Heckman central Pa 1973 FC > > I haven't had a chance to look into this today as yet. I appeciate > the help to this point. My question is what regulates the > compressor? The pulley is spinning all the time but I can tell by the > sound that it cycles on an off as far as a load.The compressor > mounting rattles rather noisily when it is changing the tanks. Does > something close and open to fill the tanks? I have this idea again > perhaps I am wrong that this is electrical? Or as Gregory said there > is a valve sticking. Now where are the valves? In the top of the > compressor. Remember this thing is bits and pieces of parts so that > makes it even more interesting. I had this occur before one time and > my shore batteries were down. I got the batteries charged up and the > compressor kicked in. Could be just lucky or a coincidence? Seems > like a leak would leak all the time rather then come and go. I plan > on fooling around here today with it so I will be back and forth. I > guess the first thing I will do is just start the bus and try again. > I need to figure this out because at some point its going to stay > broke. Likely at the worst possible time. So I need to understand > the system a little better. > John Heckman > central Pa > 1973 FC > > > > > > > > John, if the belt is tight and the compressor is spinning check the > > key in the pully shaft???? you can also check to see if the > > compressor head gets hot??? > > > > If it is a leak it must be big. you can not hear it because it > wont > > build enough pressure to hiss and while the cat is running there is > > too much noise to hear a big leak hiss. I would hook the aux air up > > to a remote shop compressor and look for a leak that way. build a > > male to mail fitting for a remote compressor line's female end and > > try and build up the tanks in the bus that way?????? I have had > > valves hang up that just needed a jolt of reverse air to get thm > > free. > > > > It could also be that there is a blockage in the compressor output > > line to the first tank > > > > GregoryO'Connor > > 94ptRomolandCa > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > wrote: > > > > > > Upon trying to take the son-in-law for a turn in the bus I found > > that > > > the compressor would not bring the air up to release the brakes. > > > Checked and the belt is Ok and the compressors seems to be > turning > > Ok. > > > Is there a solenoid or a switch which activates and deactivates > > the > > > compressor. I get about 30lbs on the air gauge but no more. The > > only > > > other clue is that when the compressor is running normally it > > makes > > > enough noise that I can hear it and it is not doing that. Don't > > know > > > beans about what I am dealing with but any help or suggestions as > > to > > > what to look at or for would certainly be appreciated. > > > > > > John Heckman > > > central Pa > > > 1973 FC converted to 3208 CAT > > > > > > |
12-31-2007, 02:47
My guess is it's the governor, assuming there is a governor on your coach.
Myself, others, have reported like problems and resolved the problem by removing the old governor and installing a new (not rebuilt) governor. On Dec 31, 2007 6:36 AM, bubblerboy64 > Well, I went out and started the bus and wouldn't you know it the > compressor immediately kicked on and functioned as it should. It > cycled up to 125psi on the gauge and shut off and every thing seems > fine. But we know that is not the case. Idea's thoughts anything on > this with this little bit more information. > John Heckman > central Pa > 1973 FC > > > > I haven't had a chance to look into this today as yet. I appeciate > > the help to this point. My question is what regulates the > > compressor? The pulley is spinning all the time but I can tell by > the > > sound that it cycles on an off as far as a load.The compressor > > mounting rattles rather noisily when it is changing the tanks. > Does > > something close and open to fill the tanks? I have this idea again > > perhaps I am wrong that this is electrical? Or as Gregory said > there > > is a valve sticking. Now where are the valves? In the top of the > > compressor. Remember this thing is bits and pieces of parts so > that > > makes it even more interesting. I had this occur before one time > and > > my shore batteries were down. I got the batteries charged up and > the > > compressor kicked in. Could be just lucky or a coincidence? Seems > > like a leak would leak all the time rather then come and go. I > plan > > on fooling around here today with it so I will be back and forth. I > > guess the first thing I will do is just start the bus and try > again. > > I need to figure this out because at some point its going to stay > > broke. Likely at the worst possible time. So I need to understand > > the system a little better. > > John Heckman > > central Pa > > 1973 FC > > > > > > > > > > > > > > John, if the belt is tight and the compressor is spinning check > the > > > key in the pully shaft???? you can also check to see if the > > > compressor head gets hot??? > > > > > > If it is a leak it must be big. you can not hear it because it > > wont > > > build enough pressure to hiss and while the cat is running there > is > > > too much noise to hear a big leak hiss. I would hook the aux air > up > > > to a remote shop compressor and look for a leak that way. build > a > > > male to mail fitting for a remote compressor line's female end > and > > > try and build up the tanks in the bus that way?????? I have had > > > valves hang up that just needed a jolt of reverse air to get thm > > > free. > > > > > > It could also be that there is a blockage in the compressor > output > > > line to the first tank > > > > > > GregoryO'Connor > > > 94ptRomolandCa > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > "bubblerboy64" > > > wrote: > > > > > > > > Upon trying to take the son-in-law for a turn in the bus I > found > > > that > > > > the compressor would not bring the air up to release the > brakes. > > > > Checked and the belt is Ok and the compressors seems to be > > turning > > > Ok. > > > > Is there a solenoid or a switch which activates and deactivates > > > the > > > > compressor. I get about 30lbs on the air gauge but no more. > The > > > only > > > > other clue is that when the compressor is running normally it > > > makes > > > > enough noise that I can hear it and it is not doing that. > Don't > > > know > > > > beans about what I am dealing with but any help or suggestions > as > > > to > > > > what to look at or for would certainly be appreciated. > > > > > > > > John Heckman > > > > central Pa > > > > 1973 FC converted to 3208 CAT > > > > > > > > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-31-2007, 03:03
Ok, Where is the governor? You guys gotta remember I am pretty much
stupid on this stuff. The only thing on the compressor is what appears to be a small filter housing on right side of the thing looking into the engine bay from the front of the bus. Something obviously opens and or controls the compressor because when it is functioning I can hear it cycle on and off. John Heckman central Pa 1973 FC > > My guess is it's the governor, assuming there is a governor on your coach. > Myself, others, have reported like problems and resolved the problem by > removing the old governor and installing a new (not rebuilt) governor. > > On Dec 31, 2007 6:36 AM, bubblerboy64 > > > Well, I went out and started the bus and wouldn't you know it the > > compressor immediately kicked on and functioned as it should. It > > cycled up to 125psi on the gauge and shut off and every thing seems > > fine. But we know that is not the case. Idea's thoughts anything on > > this with this little bit more information. > > John Heckman > > central Pa > > 1973 FC > > > > > > I haven't had a chance to look into this today as yet. I appeciate > > > the help to this point. My question is what regulates the > > > compressor? The pulley is spinning all the time but I can tell by > > the > > > sound that it cycles on an off as far as a load.The compressor > > > mounting rattles rather noisily when it is changing the tanks. > > Does > > > something close and open to fill the tanks? I have this idea again > > > perhaps I am wrong that this is electrical? Or as Gregory said > > there > > > is a valve sticking. Now where are the valves? In the top of the > > > compressor. Remember this thing is bits and pieces of parts so > > that > > > makes it even more interesting. I had this occur before one time > > and > > > my shore batteries were down. I got the batteries charged up and > > the > > > compressor kicked in. Could be just lucky or a coincidence? Seems > > > like a leak would leak all the time rather then come and go. I > > plan > > > on fooling around here today with it so I will be back and forth. I > > > guess the first thing I will do is just start the bus and try > > again. > > > I need to figure this out because at some point its going to stay > > > broke. Likely at the worst possible time. So I need to understand > > > the system a little better. > > > John Heckman > > > central Pa > > > 1973 FC > > > > > > > > > > > > > > > > > > > > John, if the belt is tight and the compressor is spinning check > > the > > > > key in the pully shaft???? you can also check to see if the > > > > compressor head gets hot??? > > > > > > > > If it is a leak it must be big. you can not hear it because it > > > wont > > > > build enough pressure to hiss and while the cat is running there > > is > > > > too much noise to hear a big leak hiss. I would hook the aux air > > up > > > > to a remote shop compressor and look for a leak that way. build > > a > > > > male to mail fitting for a remote compressor line's female end > > and > > > > try and build up the tanks in the bus that way?????? I have had > > > > valves hang up that just needed a jolt of reverse air to get thm > > > > free. > > > > > > > > It could also be that there is a blockage in the compressor > > output > > > > line to the first tank > > > > > > > > GregoryO'Connor > > > > 94ptRomolandCa > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > "bubblerboy64" > > > > wrote: > > > > > > > > > > Upon trying to take the son-in-law for a turn in the bus I > > found > > > > that > > > > > the compressor would not bring the air up to release the > > brakes. > > > > > Checked and the belt is Ok and the compressors seems to be > > > turning > > > > Ok. > > > > > Is there a solenoid or a switch which activates and deactivates > > > > the > > > > > compressor. I get about 30lbs on the air gauge but no more. > > The > > > > only > > > > > other clue is that when the compressor is running normally it > > > > makes > > > > > enough noise that I can hear it and it is not doing that. > > Don't > > > > know > > > > > beans about what I am dealing with but any help or suggestions > > as > > > > to > > > > > what to look at or for would certainly be appreciated. > > > > > > > > > > John Heckman > > > > > central Pa > > > > > 1973 FC converted to 3208 CAT > > > > > > > > > > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
12-31-2007, 03:16
I wish I could answer your question. Here is a link to an air governor
picture. If there is a governor on your coach, I believe it will look like this one, probable an aluminum color, not gold. http://velvac.thomasnet.com/viewitems/ai...ernor\ -d-2-style- On Dec 31, 2007 7:03 AM, bubblerboy64 > Ok, Where is the governor? You guys gotta remember I am pretty much > stupid on this stuff. The only thing on the compressor is what > appears to be a small filter housing on right side of the thing > looking into the engine bay from the front of the bus. Something > obviously opens and or controls the compressor because when it is > functioning I can hear it cycle on and off. > > John Heckman > central Pa > 1973 FC > > > > > My guess is it's the governor, assuming there is a governor on your > coach. > > Myself, others, have reported like problems and resolved the > problem by > > removing the old governor and installing a new (not rebuilt) > governor. > > > > On Dec 31, 2007 6:36 AM, bubblerboy64 > > > > > Well, I went out and started the bus and wouldn't you know it > the > > > compressor immediately kicked on and functioned as it should. It > > > cycled up to 125psi on the gauge and shut off and every thing > seems > > > fine. But we know that is not the case. Idea's thoughts anything > on > > > this with this little bit more information. > > > John Heckman > > > central Pa > > > 1973 FC > > > > > > > > I haven't had a chance to look into this today as yet. I > appeciate > > > > the help to this point. My question is what regulates the > > > > compressor? The pulley is spinning all the time but I can tell > by > > > the > > > > sound that it cycles on an off as far as a load.The compressor > > > > mounting rattles rather noisily when it is changing the tanks. > > > Does > > > > something close and open to fill the tanks? I have this idea > again > > > > perhaps I am wrong that this is electrical? Or as Gregory said > > > there > > > > is a valve sticking. Now where are the valves? In the top of the > > > > compressor. Remember this thing is bits and pieces of parts so > > > that > > > > makes it even more interesting. I had this occur before one time > > > and > > > > my shore batteries were down. I got the batteries charged up and > > > the > > > > compressor kicked in. Could be just lucky or a coincidence? > Seems > > > > like a leak would leak all the time rather then come and go. I > > > plan > > > > on fooling around here today with it so I will be back and > forth. I > > > > guess the first thing I will do is just start the bus and try > > > again. > > > > I need to figure this out because at some point its going to > stay > > > > broke. Likely at the worst possible time. So I need to > understand > > > > the system a little better. > > > > John Heckman > > > > central Pa > > > > 1973 FC > > > > > > > > > > > > > > > > > > > > > > > > > > John, if the belt is tight and the compressor is spinning > check > > > the > > > > > key in the pully shaft???? you can also check to see if the > > > > > compressor head gets hot??? > > > > > > > > > > If it is a leak it must be big. you can not hear it because it > > > > wont > > > > > build enough pressure to hiss and while the cat is running > there > > > is > > > > > too much noise to hear a big leak hiss. I would hook the aux > air > > > up > > > > > to a remote shop compressor and look for a leak that way. > build > > > a > > > > > male to mail fitting for a remote compressor line's female end > > > and > > > > > try and build up the tanks in the bus that way?????? I have > had > > > > > valves hang up that just needed a jolt of reverse air to get > thm > > > > > free. > > > > > > > > > > It could also be that there is a blockage in the compressor > > > output > > > > > line to the first tank > > > > > > > > > > GregoryO'Connor > > > > > 94ptRomolandCa > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > "bubblerboy64" > > > > > wrote: > > > > > > > > > > > > Upon trying to take the son-in-law for a turn in the bus I > > > found > > > > > that > > > > > > the compressor would not bring the air up to release the > > > brakes. > > > > > > Checked and the belt is Ok and the compressors seems to be > > > > turning > > > > > Ok. > > > > > > Is there a solenoid or a switch which activates and > deactivates > > > > > the > > > > > > compressor. I get about 30lbs on the air gauge but no more. > > > The > > > > > only > > > > > > other clue is that when the compressor is running normally > it > > > > > makes > > > > > > enough noise that I can hear it and it is not doing that. > > > Don't > > > > > know > > > > > > beans about what I am dealing with but any help or > suggestions > > > as > > > > > to > > > > > > what to look at or for would certainly be appreciated. > > > > > > > > > > > > John Heckman > > > > > > central Pa > > > > > > 1973 FC converted to 3208 CAT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-31-2007, 03:22
While I'm thinking about it...The governor is most likely mounted on a frame
member, main channel or cross member. That is where they are located on the 1986 and 1987 PTs. Kevin McKeowns was so well hidden it took a lot of looking to find it. He relocated it to a convenient sport to make it accessible for any future work. On Dec 31, 2007 7:16 AM, Curt Sprenger > I wish I could answer your question. Here is a link to an air governor > picture. If there is a governor on your coach, I believe it will look like > this one, probable an aluminum color, not gold. > > > http://velvac.thomasnet.com/viewitems/ai...ernor\ -d-2-style- > > > On Dec 31, 2007 7:03 AM, bubblerboy64 > > > Ok, Where is the governor? You guys gotta remember I am pretty much > > stupid on this stuff. The only thing on the compressor is what > > appears to be a small filter housing on right side of the thing > > looking into the engine bay from the front of the bus. Something > > obviously opens and or controls the compressor because when it is > > functioning I can hear it cycle on and off. > > > > John Heckman > > central Pa > > 1973 FC > > > > > > > > My guess is it's the governor, assuming there is a governor on your > > coach. > > > Myself, others, have reported like problems and resolved the > > problem by > > > removing the old governor and installing a new (not rebuilt) > > governor. > > > > > > On Dec 31, 2007 6:36 AM, bubblerboy64 > > > > > > > Well, I went out and started the bus and wouldn't you know it > > the > > > > compressor immediately kicked on and functioned as it should. It > > > > cycled up to 125psi on the gauge and shut off and every thing > > seems > > > > fine. But we know that is not the case. Idea's thoughts anything > > on > > > > this with this little bit more information. > > > > John Heckman > > > > central Pa > > > > 1973 FC > > > > > > > > > > I haven't had a chance to look into this today as yet. I > > appeciate > > > > > the help to this point. My question is what regulates the > > > > > compressor? The pulley is spinning all the time but I can tell > > by > > > > the > > > > > sound that it cycles on an off as far as a load.The compressor > > > > > mounting rattles rather noisily when it is changing the tanks. > > > > Does > > > > > something close and open to fill the tanks? I have this idea > > again > > > > > perhaps I am wrong that this is electrical? Or as Gregory said > > > > there > > > > > is a valve sticking. Now where are the valves? In the top of the > > > > > compressor. Remember this thing is bits and pieces of parts so > > > > that > > > > > makes it even more interesting. I had this occur before one time > > > > and > > > > > my shore batteries were down. I got the batteries charged up and > > > > the > > > > > compressor kicked in. Could be just lucky or a coincidence? > > Seems > > > > > like a leak would leak all the time rather then come and go. I > > > > plan > > > > > on fooling around here today with it so I will be back and > > forth. I > > > > > guess the first thing I will do is just start the bus and try > > > > again. > > > > > I need to figure this out because at some point its going to > > stay > > > > > broke. Likely at the worst possible time. So I need to > > understand > > > > > the system a little better. > > > > > John Heckman > > > > > central Pa > > > > > 1973 FC > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > John, if the belt is tight and the compressor is spinning > > check > > > > the > > > > > > key in the pully shaft???? you can also check to see if the > > > > > > compressor head gets hot??? > > > > > > > > > > > > If it is a leak it must be big. you can not hear it because it > > > > > wont > > > > > > build enough pressure to hiss and while the cat is running > > there > > > > is > > > > > > too much noise to hear a big leak hiss. I would hook the aux > > air > > > > up > > > > > > to a remote shop compressor and look for a leak that way. > > build > > > > a > > > > > > male to mail fitting for a remote compressor line's female end > > > > and > > > > > > try and build up the tanks in the bus that way?????? I have > > had > > > > > > valves hang up that just needed a jolt of reverse air to get > > thm > > > > > > free. > > > > > > > > > > > > It could also be that there is a blockage in the compressor > > > > output > > > > > > line to the first tank > > > > > > > > > > > > GregoryO'Connor > > > > > > 94ptRomolandCa > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > "bubblerboy64" > > > > > > wrote: > > > > > > > > > > > > > > Upon trying to take the son-in-law for a turn in the bus I > > > > found > > > > > > that > > > > > > > the compressor would not bring the air up to release the > > > > brakes. > > > > > > > Checked and the belt is Ok and the compressors seems to be > > > > > turning > > > > > > Ok. > > > > > > > Is there a solenoid or a switch which activates and > > deactivates > > > > > > the > > > > > > > compressor. I get about 30lbs on the air gauge but no more. > > > > The > > > > > > only > > > > > > > other clue is that when the compressor is running normally > > it > > > > > > makes > > > > > > > enough noise that I can hear it and it is not doing that. > > > > Don't > > > > > > know > > > > > > > beans about what I am dealing with but any help or > > suggestions > > > > as > > > > > > to > > > > > > > what to look at or for would certainly be appreciated. > > > > > > > > > > > > > > John Heckman > > > > > > > central Pa > > > > > > > 1973 FC converted to 3208 CAT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, CA > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
12-31-2007, 03:43
The governor is mounted directly on the compressor. The governor
controls the compresser by recycling the air and thus the compressor does not work hard when not needed. The drier will be mounted elseware, perhaps in a frame member. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > While I'm thinking about it...The governor is most likely mounted on a frame > member, main channel or cross member. That is where they are located on the > 1986 and 1987 PTs. Kevin McKeowns was so well hidden it took a lot of > looking to find it. He relocated it to a convenient sport to make it > accessible for any future work. > > On Dec 31, 2007 7:16 AM, Curt Sprenger > > > I wish I could answer your question. Here is a link to an air governor > > picture. If there is a governor on your coach, I believe it will look like > > this one, probable an aluminum color, not gold. > > > > > > http://velvac.thomasnet.com/viewitems/ai...air-brake- valves/air-governor-d-2-style- > > > > > > On Dec 31, 2007 7:03 AM, bubblerboy64 > > > > > Ok, Where is the governor? You guys gotta remember I am pretty much > > > stupid on this stuff. The only thing on the compressor is what > > > appears to be a small filter housing on right side of the thing > > > looking into the engine bay from the front of the bus. Something > > > obviously opens and or controls the compressor because when it is > > > functioning I can hear it cycle on and off. > > > > > > John Heckman > > > central Pa > > > 1973 FC > > > > > > > > > > > My guess is it's the governor, assuming there is a governor on your > > > coach. > > > > Myself, others, have reported like problems and resolved the > > > problem by > > > > removing the old governor and installing a new (not rebuilt) > > > governor. > > > > > > > > On Dec 31, 2007 6:36 AM, bubblerboy64 > > > > > > > > > Well, I went out and started the bus and wouldn't you know it > > > the > > > > > compressor immediately kicked on and functioned as it should. It > > > > > cycled up to 125psi on the gauge and shut off and every thing > > > seems > > > > > fine. But we know that is not the case. Idea's thoughts anything > > > on > > > > > this with this little bit more information. > > > > > John Heckman > > > > > central Pa > > > > > 1973 FC > > > > > > > > > > > > I haven't had a chance to look into this today as yet. I > > > appeciate > > > > > > the help to this point. My question is what regulates the > > > > > > compressor? The pulley is spinning all the time but I can tell > > > by > > > > > the > > > > > > sound that it cycles on an off as far as a load.The compressor > > > > > > mounting rattles rather noisily when it is changing the tanks. > > > > > Does > > > > > > something close and open to fill the tanks? I have this idea > > > again > > > > > > perhaps I am wrong that this is electrical? Or as Gregory said > > > > > there > > > > > > is a valve sticking. Now where are the valves? In the top of the > > > > > > compressor. Remember this thing is bits and pieces of parts so > > > > > that > > > > > > makes it even more interesting. I had this occur before one time > > > > > and > > > > > > my shore batteries were down. I got the batteries charged up and > > > > > the > > > > > > compressor kicked in. Could be just lucky or a coincidence? > > > Seems > > > > > > like a leak would leak all the time rather then come and go. I > > > > > plan > > > > > > on fooling around here today with it so I will be back and > > > forth. I > > > > > > guess the first thing I will do is just start the bus and try > > > > > again. > > > > > > I need to figure this out because at some point its going to > > > stay > > > > > > broke. Likely at the worst possible time. So I need to > > > understand > > > > > > the system a little better. > > > > > > John Heckman > > > > > > central Pa > > > > > > 1973 FC > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > John, if the belt is tight and the compressor is spinning > > > check > > > > > the > > > > > > > key in the pully shaft???? you can also check to see if the > > > > > > > compressor head gets hot??? > > > > > > > > > > > > > > If it is a leak it must be big. you can not hear it because it > > > > > > wont > > > > > > > build enough pressure to hiss and while the cat is running > > > there > > > > > is > > > > > > > too much noise to hear a big leak hiss. I would hook the aux > > > air > > > > > up > > > > > > > to a remote shop compressor and look for a leak that way. > > > build > > > > > a > > > > > > > male to mail fitting for a remote compressor line's female end > > > > > and > > > > > > > try and build up the tanks in the bus that way?????? I have > > > had > > > > > > > valves hang up that just needed a jolt of reverse air to get > > > thm > > > > > > > free. > > > > > > > > > > > > > > It could also be that there is a blockage in the compressor > > > > > output > > > > > > > line to the first tank > > > > > > > > > > > > > > GregoryO'Connor > > > > > > > 94ptRomolandCa > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > "bubblerboy64" > > > > > > > wrote: > > > > > > > > > > > > > > > > Upon trying to take the son-in-law for a turn in the bus I > > > > > found > > > > > > > that > > > > > > > > the compressor would not bring the air up to release the > > > > > brakes. > > > > > > > > Checked and the belt is Ok and the compressors seems to be > > > > > > turning > > > > > > > Ok. > > > > > > > > Is there a solenoid or a switch which activates and > > > deactivates > > > > > > > the > > > > > > > > compressor. I get about 30lbs on the air gauge but no more. > > > > > The > > > > > > > only > > > > > > > > other clue is that when the compressor is running normally > > > it > > > > > > > makes > > > > > > > > enough noise that I can hear it and it is not doing that. > > > > > Don't > > > > > > > know > > > > > > > > beans about what I am dealing with but any help or > > > suggestions > > > > > as > > > > > > > to > > > > > > > > what to look at or for would certainly be appreciated. > > > > > > > > > > > > > > > > John Heckman > > > > > > > > central Pa > > > > > > > > 1973 FC converted to 3208 CAT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, CA > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
12-31-2007, 03:49
PeteM sent a link to a booklet on air brakes.
http://www.gnb.ca/0276/vehicle/pdf/ab_manual-e.pdf On page 12 of the 77 page pdf booklet is a good explanation of the compressor on and off operation. The book is generic which would be best with a 'as built' system like you have. Understanding of the contents of the book is a requirement for a Federal commercial drivers license CDL. This book may be a good pdf file to down load and save for reading. You hear the compressor strain when it is loading the tanks with air. The governer directs flow of the 'compressor discharge line' Governer is set to direct the discharge line to load the tanks when tank pressure falls to 85#. therefor when the gov starts refilling the tanks, it is pushing air against a pressure of 85 from the start and you hear the strain. When the tank is at max pressure the governer direction of air pumped by the full time compressor switches to 'Unload', there is no strain because unload is a circular path of air from and to the compressor. (the term unload is not a depletion of tank pressure) I do not believe that any component of the air brake system is electrical. <snip from page 12> The compressor is in constant drive with the engine. Whenever the engine is running, so is the compressor. When pressure in the system is adequate, anywhere from a low of 80 psi to a high of 135 psi it is not necessary for the compressor to pump air. A governor (2) controls the minimum and maximum air pressure in the system by controlling when the compressor pumps air. This is known as the "loading" or "unloading" stage. Most compressors have two cylinders similar to an engine's cylinders. When the system pressure reaches its maximum, which is between 115 and 135 psi, the governor places the compressor in the "unloading" stage. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Ok, Where is the governor? You guys gotta remember I am pretty much > stupid on this stuff. The only thing on the compressor is what > appears to be a small filter housing on right side of the thing > looking into the engine bay from the front of the bus. Something > obviously opens and or controls the compressor because when it is > functioning I can hear it cycle on and off. > John Heckman > central Pa > 1973 FC > > > > > > > > My guess is it's the governor, assuming there is a governor on your > coach. > > Myself, others, have reported like problems and resolved the > problem by > > removing the old governor and installing a new (not rebuilt) > governor. > > > > On Dec 31, 2007 6:36 AM, bubblerboy64 > > > > > Well, I went out and started the bus and wouldn't you know it > the > > > compressor immediately kicked on and functioned as it should. It > > > cycled up to 125psi on the gauge and shut off and every thing > seems > > > fine. But we know that is not the case. Idea's thoughts anything > on > > > this with this little bit more information. > > > John Heckman > > > central Pa > > > 1973 FC > > > > > > > > I haven't had a chance to look into this today as yet. I > appeciate > > > > the help to this point. My question is what regulates the > > > > compressor? The pulley is spinning all the time but I can tell > by > > > the > > > > sound that it cycles on an off as far as a load.The compressor > > > > mounting rattles rather noisily when it is changing the tanks. > > > Does > > > > something close and open to fill the tanks? I have this idea > again > > > > perhaps I am wrong that this is electrical? Or as Gregory said > > > there > > > > is a valve sticking. Now where are the valves? In the top of the > > > > compressor. Remember this thing is bits and pieces of parts so > > > that > > > > makes it even more interesting. I had this occur before one time > > > and > > > > my shore batteries were down. I got the batteries charged up and > > > the > > > > compressor kicked in. Could be just lucky or a coincidence? > Seems > > > > like a leak would leak all the time rather then come and go. I > > > plan > > > > on fooling around here today with it so I will be back and > forth. I > > > > guess the first thing I will do is just start the bus and try > > > again. > > > > I need to figure this out because at some point its going to > stay > > > > broke. Likely at the worst possible time. So I need to > understand > > > > the system a little better. > > > > John Heckman > > > > central Pa > > > > 1973 FC > > > > > > > > > > > > > > > > > > > > > > > > > > John, if the belt is tight and the compressor is spinning > check > > > the > > > > > key in the pully shaft???? you can also check to see if the > > > > > compressor head gets hot??? > > > > > > > > > > If it is a leak it must be big. you can not hear it because it > > > > wont > > > > > build enough pressure to hiss and while the cat is running > there > > > is > > > > > too much noise to hear a big leak hiss. I would hook the aux > air > > > up > > > > > to a remote shop compressor and look for a leak that way. > build > > > a > > > > > male to mail fitting for a remote compressor line's female end > > > and > > > > > try and build up the tanks in the bus that way?????? I have > had > > > > > valves hang up that just needed a jolt of reverse air to get > thm > > > > > free. > > > > > > > > > > It could also be that there is a blockage in the compressor > > > output > > > > > line to the first tank > > > > > > > > > > GregoryO'Connor > > > > > 94ptRomolandCa > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > "bubblerboy64" > > > > > wrote: > > > > > > > > > > > > Upon trying to take the son-in-law for a turn in the bus I > > > found > > > > > that > > > > > > the compressor would not bring the air up to release the > > > brakes. > > > > > > Checked and the belt is Ok and the compressors seems to be > > > > turning > > > > > Ok. > > > > > > Is there a solenoid or a switch which activates and > deactivates > > > > > the > > > > > > compressor. I get about 30lbs on the air gauge but no more. > > > The > > > > > only > > > > > > other clue is that when the compressor is running normally > it > > > > > makes > > > > > > enough noise that I can hear it and it is not doing that. > > > Don't > > > > > know > > > > > > beans about what I am dealing with but any help or > suggestions > > > as > > > > > to > > > > > > what to look at or for would certainly be appreciated. > > > > > > > > > > > > John Heckman > > > > > > central Pa > > > > > > 1973 FC converted to 3208 CAT > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > [Non-text portions of this message have been removed] > > > |
12-31-2007, 12:09
That is correct. The brake system has no electrical components other
than the switches that turn on/off the tail lights. All control and actuation is done through air pressure changes as controlled by various valves. Similarly, the air bags (suspension) also have no primary electrical components other than the valves that 'dump' the air and sensors that report pressure, or lack thereof, to the buzzers and dash panel gauges. A total electrical failure should not cause you any immediate problems in the safe handling or braking of your coach -- at least, not from either the brakes or suspension components. The other air operated items may have an electrically operated valve, such as the stair-well cover, the air-step, the bulk oil filler, the dump valves, and the dryer vent. Each of these has an electric switch that actuates an electrically operated valve to activate/deactivate the item. The air-step has a microswitch (under the coach) that can be a problem if it becomes clogged with dirt or otherwise is moved out of position. The main braking system is partially isolated from the non-essential appliances, but leaks in the auxiliary systems can lead to an eventual loss of brake pressure or the inability to air up the coach. When the air system is working properly, the coach should remain charged with air for several hours after shutting down, if the suspension isn't dumped. Frequent cycling of the air step will deplete the air more quickly. If the system doesn't hold air for 6 to 12 hours (or more), then it's time to go over all the air-actuated systems to hunt for leaks. Note: this is _much_ longer than the standard required by most DMVs. Here's the CA DMV air brake check procedure: In-Cab Air Brake Check NOTE: All items marked with an asterisk (*) are critical parts of the in-cab air brake test and must be demonstrated during DMV testing. They may be performed in any order. If these items are not performed correctly, it is considered an automatic failure of the pre-trip test. Test air leakage rate. (* second test only) * With a fully-charged air system (typically 125 p.s.i.), turn off the engine, release the service brake (brakes off), and let the system settle (air gauge needle stops moving). Time the air pressure drop. The loss rate should not be greater than: â 2 p.s.i. or less in one minute for single vehicles. â 3 p.s.i. or less in one minute for a combination of two vehicles. â 5 p.s.i. or less in one minute for a combination of three or more vehicles. If the loss is too much, check for air leaks and fix. * With roughly a fully charged air system (typically 100-125 p.s.i.), turn off the engine. Release all brakes and allow the system to settle (air gauge needle stops moving). Then apply full steady pressure to the brake pedal (brake on) and hold. After the system settles again, the air loss should not be more than: â 3 p.s.i. or less in one minute for single vehicles. â 4 p.s.i. or less in one minute for a combination of two vehicles. â 6 p.s.i. or less in one minute for a combination of three or more vehicles. If the air loss is too much, check for air leaks and fix. For testing purposes, identify if the air loss rate is too much. *Check air compressor governor cut-out pressure. Pumping should start at about 100 p.s.i. and stop at about 125 p.s.i. (130 p.s.i. maximum). Run the engine at a fast idle. The air governor should cut- out the air compressor at about the manufacturer's specified pressure. The air pressure shown by your gauge(s) will stop rising. For testing purposes, identify when the compressor cuts out. *Check air compressor governor cut-in pressure. Start with the air pressure above the governor cut-in level (no lower than 85 p.s.i.). With the engine idling, slowly pump the brake pedal to reduce the air tank pressure. Watch the air gauge between pumps to identify when the compressor cuts in (needle starts to rise). This should be at about the manufacturer's specified cut-in pressure. If the air governor does not work as described, it may not keep enough air pressure for safe driving. For testing purposes, identify when the compressor cuts in. NOTE: To perform this test correctly, the compressor cannot already be pumping air. If it is, allow the governor to cut-out before performing this test. A full discussion of air brakes and their operation from the CA DMV Commercial Drivers License booklet can be seen at: <http://www.dmv.ca.gov/pubs/cdl_htm/sec5_a.htm> Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Dec 31, 2007, at 7:49 AM, Gregory OConnor wrote: > <snip> > I do not believe that any component of the air brake system is > electrical. > [Non-text portions of this message have been removed] |
